Remove liquid inside laptop cpu socket S1 AMD
  • whaldsz
    • Apr 2013
    • 395
    • Philippines
    Re: Remove liquid inside laptop cpu socket S1 AMD
    Why don't you disconnect PL12 and check again, if it will pull down the 19v B+ rail to 2V.
    • Dimitrios
      • Nov 2013
      • 127
      • Greece
      A small update. I found that when I insert CPU PQ35 and PQ36 are getting very hot, like 70C. Also coil PL13 is getting very hot (page 38)! I did a search and noticed that PC105 capacitor is completely missing! Thought that it was normal not to be a capacitor there as a lot of components on motherboards are not necessary and missing like on other mobos.
      Take a look it looks corroded but I really don't know where the capacitor went!! It wasn't inside case anywhere I think...
      So could this cap be the reason of short circuit I am having on CPU power feed or it is irrelevant and should be working anyway? What do you think?
      SHOULD BE LIKE THIS:
        master hoarder
        • May 2008
        • 12175
        That cap is not a cause for the short circuit. However, you definitely DO need it there, otherwise there is nothing to absorb the energy from the coil in the buck circuit. This can lead to big voltage spikes, which can sometimes kill whatever is attached to that line. Add the cap in and check again. If your MOSFETs and coil still overheat, it's probably too late, and whatever that line powers may be now dead.
        • Dimitrios
          • Nov 2013
          • 127
          • Greece
          Yes I was afraid of that cause I know that a capacitor acts mainly as a filter. This circuit is feeding power to the ATI chipset/GPU... Oh well I will change it with a new one and see from there! Will keep you updated! Thanks again momaka for replying!
          • Dimitrios
            • Nov 2013
            • 127
            • Greece
            A small update: I installed PC105 capacitor and removed completely Coil PL13 (page 38) and now LED power on has appeared with CPU inserted. So I found the short and it is on the side of power CPU and northbridge. Motherboard cannot start of course because I have removed coil and no power goes to NB and CPU.
            What do you think?
            • Tea_4_2
              • Mar 2014
              • 5
              • Portugal
              #26
              In the past i did wash some boards in my dishwasher machine with success and then dried them in the oven at a temperature around (and alittle above) 100 degrees celsius i did also pre spayed them with a mild cleaner no clorine nor amonia to spray the board with air is also a good idea before et it dry completely.
              • Dimitrios
                • Nov 2013
                • 127
                • Greece
                #27
                Here is a diagram of the shorted path: Maybe CPU or Northbridge is busted/burnt?
                  master hoarder
                  • May 2008
                  • 12175
                  #28
                  Often times, it is normal for a large BGA chip such as the NB, GPU, and CPU to read as "shorted".
                  How many Ohms is the NB showing when you try to measure it with the multimeter (and what is the lowest your multimter can measure when you short its leads)?
                  • Dimitrios
                    • Nov 2013
                    • 127
                    • Greece
                    #29
                    The lowest when shorted the leads is 0.2 Ohms and when I touch the probe to PC105 is 0.3 Ohms with and without CPU inserted. Also PC105 cap is new because it was completely blown from the short I am guessing when spillage occurred. +VDDNBP goes to CPU and Northbridge power section.
                    It is a very rare motherboard so it is not easy to replace. Only in India have seminars and classes about Laptop Chip Level Repair. I wish it could be closer to where I am living...!!
                    Thanks for replying!
                      master hoarder
                      • May 2008
                      • 12175
                      #30
                      If you can obtain a NB from another dead board, you may try replacing yours. Or alternatively, if you are comfortable with lifting/reballing/reflowing, remove your NB and see if short disappears. Slight chance there may be a shorted ceramic capacitor instead of the NB being shorted. If you have a low-voltage, high current power supply, you can apply that to the NB +VDDNBP line and see if any of the ceramic caps around it get hot. However, if you do that, make sure your NB has a neatsink on it (if it had one in the first place) and also ramp the current from the power supply slowly rather than cranking it on high from the start. You will need to check a spec sheet or schematic for the laptop as well to see what the +VDDNBP is supposed to be - you definitely don't want to go higher in voltage. Lower is okay and a good idea.
                      • Dimitrios
                        • Nov 2013
                        • 127
                        • Greece
                        #31
                        Thank you for well written instructions! I am building an electronic lab in my basement because of lack of space. I am definitely planning to buy a bench lab Power Supply to be able to find shorts with variable voltages. One question. How will I pass the voltage to where I want eg at a pin of a Mosfet or at a resistor? Could I solder it? Most power supplies are using crocodile clips, correct?
                          master hoarder
                          • May 2008
                          • 12175
                          #32
                          Yes, you can solder a piece of wire and attach the crocodile clip (we call it aligator clip, but it's the same thing ) to that. I have a small box of short scrap wires (mostly 26 to 18 AWG) I use for that and other similar purposes like testing voltages on a small IC but not wanting to risk shorting the pins with my multimeter leads.
                          • Dimitrios
                            • Nov 2013
                            • 127
                            • Greece
                            #33
                            Oh I see! Can you link to a picture or eBay just to have a visual?
                              master hoarder
                              • May 2008
                              • 12175
                              #34
                              This what you mean?
                              http://en.wikipedia.org/wiki/Crocodile_clip
                              • Dimitrios
                                • Nov 2013
                                • 127
                                • Greece
                                #35
                                no about the wire. It is insulated, right?
                                • atsio
                                  • Oct 2013
                                  • 819
                                  • Greece
                                  #36
                                  +VDDNB is only NB power (not CPU). Remove and check C42 C43 and C49 decoupling capacitors. Also check resistance on all coils of power regulators to see if there is a short elsewhere that causing NB to short (that is, without CPU inserted to slot)
                                  The best and fastest way to test smt's, is by replacing the probes on DMM with needles.
                                  • Dimitrios
                                    • Nov 2013
                                    • 127
                                    • Greece
                                    #37
                                    Can't find C42 C43 and C49 cause there is no numbering on most capacitors at PCB as you can see from the pictures which is very frustrating. I can take a detailed picture of southbridge section if you want!
                                    You have to hold needles with both hands to power up the specific section and the how will you use multimeter? Excuse my noob questions!!
                                    • atsio
                                      • Oct 2013
                                      • 819
                                      • Greece
                                      #38
                                      There should be near K16, M6, P16, T16, V16 of NB (probably the other side). You can find them by checking which capacitors are shorted.
                                      I was just referring on testing smt's with DMM without worrying of causing a short.
                                      Of course and you need cables to supply voltage to smt's in order to activate them or check for shorts (heat) and you have to use good quality one's because the current maybe high.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        #39
                                        Oh, I don't know what's in that box. It's whatever leftovers I've collected over the years from various projects. Some is insulated, some not, some is stranded, some solid-core... long pieces, short piece... it's a wire "junk box" really .
                                        That, or you can buy a set of fine probes. There are cheap ones on eBay (though their quality is hardly any good... but they do okay if you are carefull with them).
                                        Also, sometimes I need to make measurements over a long period of time. In such cases, holding the multimter with my hands all the time is not practical. That's where I solder in wires and use jumper leads to connect my multimeter probes.
                                        • Dimitrios
                                          • Nov 2013
                                          • 127
                                          • Greece
                                          #40
                                          Removed northbridge/gpu ATI 216-0752001 RS880 but short remains on +VDDNBP rail. Can anyone confirm that +VDDNBP power rail is the same with +VDDNB on page 38 of schematics that uploaded earlier??
                                          I think that the shorted capacitor must be on page 8, bottom left, one of C42, C43 or C49 but cannot locate those cause there is no numbering on the board for most of the capacitors...
                                          Will try what Atsio mentioned in earlier post.
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • Flaku_34
                                            Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                                            by Flaku_34
                                            Introduction:
                                            Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                                            04-18-2024, 12:47 PM
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • AJ847.63e
                                            LGA 1700 Socket Replacement Tips & Tricks
                                            by AJ847.63e
                                            Hi All,
                                            Just wanted to see if I can get some advice on techniques and equipment I should use to try replace the socket on a Gigabyte H610M h v2ddr4 I have.
                                            I was planning on using a heat mat I have that's used for phone, tablet screens, as a base heater than use hot air with a square nozzle on top. Yes I should get a proper preheater but I'm not in the position to go spend 300+ bucks on something I will use every 6 months if I'm lucky. Next expense I need to get is a decent programmer like the RT809H but again it would get used infrequently so hard to justify.
                                            07-24-2025, 06:57 PM
                                          • longmt1990
                                            Panasonic Cf-w5 bios password remove
                                            by longmt1990
                                            Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                                            I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                                            Please help me remove bios password.
                                            Thank you so much
                                            07-06-2025, 10:50 PM
