Remove liquid inside laptop cpu socket S1 AMD
  • Dimitrios
    • Nov 2013
    • 127
    • Greece
    Hello everyone! I have another problem which might help other experience the same or identical issue!
    I have a Toshiba Satellite C660D LA-6843P motherboard, extremely rare that has a liquid milk spilled. After thorough testing I found out that most of the liquid spilled on top of its heatsink and inside cpu socket S1.
    Now if I remove CPU (AMD V140 2.3GHz) all lights working and power is properly flowing on motherboard. I even charged the battery completely with cpu off. As soon as I screw in cpu on socket immediately my charger -on power socket not inside laptop- light blinks and 2 Volts are passing from the main connector instead of 19V, a short circuit.
    My actions were to spray a lot of contact cleaner to cpu socket and brush it but to no avail.I also tried different cpu. Same symptoms persist.
    What do you think should I do next?? I am thinking maybe hot distilled water on socket to remove sugar from pins. I can't find a replacement mobo, it is a rare model I guess!
  • cheapie
    null
    • Jul 2010
    • 849
    Re: Remove liquid inside laptop cpu socket S1 AMD
    Try washing both the CPU and motherboard, see here for instructions on how to do this. Make sure to remove all batteries before doing this, and to let it dry completely before putting them back in.
      It could be that the CPU is shorted. They can fail in such a way, if you can locate the datasheet for it, try testing from VCORE to GND.
      • Dimitrios
        • Nov 2013
        • 127
        • Greece
        Nice post, although I am sure that I won't be able to find "Mean Green" cleaner here in Greece. Hot water is on my mind because I need to remove the remaining sugar at cpu socket pins. I think I can hear it making a crunching nois when I turn the screw to secure the CPU!
        At page 5 of datasheet that I upload has the cpu pinouts. Can you point me to the correct?? At A7 POWER OK (PWROK) I get no voltage without CPU.
        Also tried with different CPU a Turion x64 for 1st gen s. S1 but still the same symptoms! V140 is a 4th generation S1.
        • cheapie
          null
          • Jul 2010
          • 849
          Most mild cleaners should work, but hot water is probably worth a try if you can't find anything.
          • Dimitrios
            • Nov 2013
            • 127
            • Greece
            Yeah, I am gonna ask about a proper mild cleaner for the job! Thank you all for your help. Will try all this cause I think that if the socket get a good clean inside, I have many chances to resurrect this motherboard. I really hope that the short hasn't damaged any mosfets...
            • Francisco.s
              • 685
              • Spain
              You can be almost sure that VCORE pwm circuit is damaged.
              This voltage should not be present in S5 state.
              • Dimitrios
                • Nov 2013
                • 127
                • Greece
                You mean that the proccessors Vcore has some kind of damage? Can you take a look at the schematics I posted in my first post to point me where to test?? Thank you for replying!
                • Dimitrios
                  • Nov 2013
                  • 127
                  • Greece
                  I mean when CPU is removed 19V passes from charger to connector. It is normal in S5 state. As soon as I insert CPU in socket charger is giving 2Volts and there is a problem there, either in CPU contacts or in CPU Vpower supply, correct?
                    master hoarder
                    • May 2008
                    • 12170
                    Yes, but NOTHING WITH CHLORINE! I'm not sure if ammonia-based cleaners can damage traces too, so I'd steer clear from those as well.
                    Hot water and dish detergent usually works well for me. I have washed several electronics with that, and all are still working.
                    • Dimitrios
                      • Nov 2013
                      • 127
                      • Greece
                      I found a good liquid in my local shop. A good mild cleaner. I want to dissolve sugar inside the cpu socket and see if the old CPU still works and also I hope that CPU circuit still works...!
                      • Francisco.s
                        • 685
                        • Spain
                        Yes, VR_ON signal can't be active in S5 state, so if you have 19 volts at cpu socket, there must be a mosfet in short-circuit, so check mosfet at CPU_CORE circuit. (PQ37 and PQ40)
                        • Dimitrios
                          • Nov 2013
                          • 127
                          • Greece
                          As I said the input dc power jack PJP1, page 32 gives 19V and not on VR_ON signal. But as soon as I insert CPU the dc power jack gives 2 Volts only and I really hope to be the sugar that is inside CPU socket from the milk spill and not a busted component, although I know that would be the best possible scenario!
                          • eyezopen
                            • Feb 2014
                            • austria
                            Hello everyone
                            I found this Forum by searching for bad Caps and i´m glad to have found this.
                            I´m sure i´ll find one or the other solution here
                            • Francisco.s
                              • 685
                              • Spain
                              VR_ON signal enables pwm output for CPU_CORE circuit.
                              What about PQ37 and PQ40?
                              • Dimitrios
                                • Nov 2013
                                • 127
                                • Greece
                                Will test PQ37 and PQ40 on diode mode in my multimeter. I will also check VR_ON with and without CPU and will post back results, thank you very much!
                                • inspirim
                                  • May 2013
                                  • 282
                                  • Italy
                                  pulire con ultrasuoni
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    Clean with ultrasonic
                                    • Francisco.s
                                      • 685
                                      • Spain
                                      CPU shouldn't receive any voltage until power button is pressed, if you put cpu and 19 volts goes down, there'll be a mosfet in short-circuit.
                                      http://en.wikipedia.org/wiki/Buck_converter
                                      • Dimitrios
                                        • Nov 2013
                                        • 127
                                        • Greece
                                        Well I finding 500 Ohms in one direction and 750 Ohms in the other direction tested on diode mode with no CPU inserted. With CPU inserted I am getting 0 Ohms So CPU is toast or socket has been in short circuit and busted?? With CPU removed all voltages are correct as far as I measured, power led is on and I even charged the battery well...
                                        That's a good idea, althought it must be a big ultrasonic machine capable of fitting the whole motherboard inside!
                                        Again I am referring to dc_in jack that must be 19V in power off to give supply to always_5V and always_3.3V.
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • Flaku_34
                                          Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                                          by Flaku_34
                                          Introduction:
                                          Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                                          04-18-2024, 12:47 PM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • longmt1990
                                          Panasonic Cf-w5 bios password remove
                                          by longmt1990
                                          Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                                          I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                                          Please help me remove bios password.
                                          Thank you so much
                                          07-06-2025, 10:50 PM
                                        • almamater
                                          Samsung NP350v5c
                                          by almamater
                                          In case anyone has any ideas.. BIOS Freezing..
                                          One friend asked me to see a very slow laptop with strange behavior on windows.
                                          In fact the laptop is old, it was very badly treated and the strange behavior is because the keyboard is broken (random cursor movements in windows).
                                          But it also has a broken DVD Drive, which causes a very slow BOOT at the beginning and for this reason I physically disabled it (I removed the Sata connector that connects to the board)
                                          The notebook must have been dropped a few times, some liquid must have...
                                          03-21-2022, 05:26 AM
