MacBook Air 2179 no sound
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    after replacing the T2 chip there is no sound on the built-in speakers! When connected via bluetooth or via a 3.5 mm jack, there is sound. the system sees the inside of the speakers but there is no sound! what could it be? what to pay attention to?
  • mon2
    • Dec 2019
    • 13955
    Review the headphone connector on the audio board. Use compressed air to blow out any gremlins.
    The audio board may need to be replaced for the same reason.
    https://youtu.be/oYbgYZhm_Dg?feature=shared
    • PITERPENY
      • Jul 2023
      • 455
      • Ukraine
      [QUOTE=mon2;n3232122]Review the headphone connector on the audio board. Use compressed air to blow out any gremlins.
      https://youtu.be/oYbgYZhm_Dg?feature=shared[/QUOTE
      The problem is not in the connector or in the sound board because I install another motherboard and there is sound! I also installed a 3.5mm jack card from another laptop and there is no sound.
      • anhbanxoi
        • Sep 2021
        • 171
        • VN
        Check diode value of R5300, R5301, R5305, R5306. Maybe the contact between T2 chip and the pad is not good.
        • PITERPENY
          • Jul 2023
          • 455
          • Ukraine
          the voltage across these resistors is 1.8 volts, in diode mode 0.365
          I remind you that the sound is output via bluetooth and through a 3.5mm jack, there is no sound only from the built-in speakers
          • obelix24
            • Jun 2023
            • 291
            • Slovakia
            check if the connector on motherboard where you connect audio board is ok. I have this issue on other macbook connector where audio board flex was connecting wasn't making good contact on one side (with naked eye it wasn't visible but under microscope it was clear that the issue is there) and therefore i was able to see speakers, increase / decrease audio, audio via headphone jack was working but internal speakers where not outputting any sound.
            • PITERPENY
              • Jul 2023
              • 455
              • Ukraine
              [QUOTE=obelix24;n3232965]check if the connector on motherboard where you connect audio board is ok. I have this issue on other macbook connector where audio board flex was connecting wasn't making good contact on one side (with naked eye it wasn't visible but under microscope it was clear that the issue is there) and therefore i was able to see speakers, increase / decrease audio, audio via headphone jack was working but internal speakers where not outputting any sound.[/QUOTEEverything has been checked under a microscope and everything looks new. just in case, I washed everything with alcohol and replaced the cable with a new one, to no avail (
              • PITERPENY
                • Jul 2023
                • 455
                • Ukraine
                if the sound works through the 3.5mm connector, then T2 initializes the sound to the board and the problem is not in T2!? I’m thinking correctly since I’ve already transplanted T2 2 times, it didn’t help either and there weren’t any unsoldered nickels
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
                • computeka
                  Macbook Air A2337 820-02016-07 No sound problem
                  by computeka
                  How about everyone, I have a MacBook Air which did not turn on, it had a lot of corrosion on the card where the sound plug and the fingerprint go, I have replaced it and the device now turns on but has no sound, if I connect a headphone through the plug, yes There is sound but the external speakers do not sound....
                  05-08-2024, 10:26 AM
                • Comp_Pro
                  Macbook Air 820-00165 Static Chime Sound
                  by Comp_Pro
                  Hello all,
                  I have a weird issue to solve here. This macbook air came in showing a black screen even though the backlight was lit. The display was not the issue as I tried another known good display. Upon trying to restart it, sometimes it boots up but freezes at the login page. More commonly however, the macbook will give the chime sound but then get stuck repeating the sound. The first chime sound is normal but the subsequent chimes sounds are crackly. Voltages seem normal, no liquid damage. I did find a blotch of something near one of the crystals on the other side of the CPU...
                  11-02-2023, 03:23 PM
                • tommy97
                  Apple MacBook A1707 No Audio/Sound
                  by tommy97
                  I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
                  I've also replaced U6300, but the problem persists.
                  Here are the current voltage readings:
                  • PPV18_S0: 1.8V
                  • R6402: 1V
                  • R6405: 1V
                  • R6403: 1V
                  • AUD_SPKRAMP_RESET_L: 1.3V
                  • PPBUS: 12.6V
                  03-10-2025, 11:22 AM
                • siuras676
                  MacBook Air A1932 820-01521 no sound
                  by siuras676
                  I got this MacBook after liquid damage, clean up the board replaced side I/O audio board with flex as it was liquid damaged I am getting now sound on headphones but no sound on speakers still. Machine is recognising speakers as there is a volume bar available.
                  Anyone had issue like this before ?
                  06-27-2024, 06:50 AM
