MacBook Air A1932 820-01521 no sound
  • siuras676
    • May 2018
    • 15
    • ireland
    I got this MacBook after liquid damage, clean up the board replaced side I/O audio board with flex as it was liquid damaged I am getting now sound on headphones but no sound on speakers still. Machine is recognising speakers as there is a volume bar available.
    Anyone had issue like this before ?
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    Hello ! Here is my topic on Rossman with the same problem, replacing T2 helped! The recommended solution is to use Bluetooth audio! the sound is still disgusting. and the cost of replacement is like a hompod🤣
    Hello . fully working macbook. There is sound via Bluetooth and there is sound through the 3.5 mm jack, but the sound itself is not reproduced on the built-in speakers! Replacing the sound card did not help. displayed on devices!
    • bouch
      unlock macbook air A1932 2019
      by bouch
      hi
      i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
      i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
      i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
      have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
      I need help or information?
      Does anyone have the minat2 activator 1.4 software?
      Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
      Thank yo...
      03-12-2025, 10:14 AM
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • computeka
      Macbook Air A2337 820-02016-07 No sound problem
      by computeka
      How about everyone, I have a MacBook Air which did not turn on, it had a lot of corrosion on the card where the sound plug and the fingerprint go, I have replaced it and the device now turns on but has no sound, if I connect a headphone through the plug, yes There is sound but the external speakers do not sound....
      05-08-2024, 10:26 AM
    • nikolayu
      MacBook Air A1932 internet recovery loop
      by nikolayu
      I have A1932 that is going to internet recovery every time.
      i tried nvram and smc reset but it looks that MacBook is not reacting to that.
      i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
      keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
      also won’t open option to boot from usb device.
      and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
      07-22-2025, 02:55 AM
    • mitchw
      MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
      by mitchw
      Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
      It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
      I quickly took it apart and washed the liquid residue off the mainboard.
      The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
      The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
      Now the laptop...
      07-16-2025, 07:55 AM
