HP G6 DA0R13MB6E1 QUANTA R13 REV. E / No power, No LEDs...
  • KvnTM
    • May 2018
    • 434
    Re: HP G6 DA0R13MB6E1 QUANTA R13 REV. E / No power, No LEDs...
    Originally posted by antony.ag
    yes thank you very much very kind ... but I had to take them in another motherboard how can I measure if they can go well? because on the cards the value is not marked ... with the tester how can I measure the value of the capacitor that I would like to take from another motherboard?
    This would impractical. You'd have to desolder every component you want to test. A resistor could be easy to find though.. Just look for a 220 marked resistor in the same package.
    Capacitors are another thing.. You can't measure them if you don't have a capacitance meter. You could get a schematic for your donor board and search one.
    • antony.ag
      • Nov 2019
      • 59
      • Italia
      #82
      I have this motherboard with this scheme ... where can I get the parts I need?
      01015pm00-600-g schematic
      • KvnTM
        • May 2018
        • 434
        just search for 100nF and 220pF in the schematic.
        As example:
        C1372 => 220pF / 50V
        C1324 => 100nF / 10V
        • antony.ag
          • Nov 2019
          • 59
          • Italia
          #84
          sorry for the bad welds but having the soldering iron with a big tip I can't do better ... sorry ... anyway I inserted the capacitors and a resistance with bigger dimensions not as a value but as a measure but as soon as I put the current it goes to smoke
          • KvnTM
            • May 2018
            • 434
            I really hope that this is your personal laptop and please invest into a proper soldering station.
            Anyways.. Look at the image and measure resistance.
            • antony.ag
              • Nov 2019
              • 59
              • Italia
              #86
              ehehehe ... thank you so much for the advice ... as soon as I have the chance :-( ... I have measured red where you have marked you and black where the vito go to 2000k but I'm not giving any value ...
                • 21017
                C26 not on straight,EC4 end cap missing needs replacing,PC103 needs replacing, PC48 needs replacing . Do yourself a favour,buy another soldering iron or a smaller tip and some good quality flux, use lots of flux don`t be sparing with it.
                • antony.ag
                  • Nov 2019
                  • 59
                  • Italia
                  #88
                  sorry you are right ... can you tell me the values of the capacitors to change in order to take them from another motherboard?
                  • antony.ag
                    • Nov 2019
                    • 59
                    • Italia
                    #89
                    c26 is not right in the sense I have to redirect it or is it upside down? ec4 do you think it is wrong and should it be changed? pc103 has already been changed but I thought the component was c20 and not pc103 putting a 220pF / 50v capacitor ... pc48 is shorted?
                    • antony.ag
                      • Nov 2019
                      • 59
                      • Italia
                      #90
                      hi, I wanted to ask in order to solve the problem I have to change all those components?
                      • antony.ag
                        • Nov 2019
                        • 59
                        • Italia
                        #91
                        I have done better the welds now the pubto of the resistance on the left + gnd brings me 150.5 and goes to increase I put the tester to 200k
                        • antony.ag
                          • Nov 2019
                          • 59
                          • Italia
                          #92
                          any suggestions ?
                          • KvnTM
                            • May 2018
                            • 434
                            any suggestions ?
                            Do you have a bench power supply ?
                            • antony.ag
                              • Nov 2019
                              • 59
                              • Italia
                              #94
                              Unfortunately no
                              • KvnTM
                                • May 2018
                                • 434
                                Unfortunately no
                                Ok..
                                Remove PC16 and try to power it up. If PR12 still smokes PU2 is most likely dead and needs to be replaced.
                                • antony.ag
                                  • Nov 2019
                                  • 59
                                  • Italia
                                  #96
                                  ok ... i try and let you know....thanks
                                  • KvnTM
                                    • May 2018
                                    • 434
                                    Also measure voltage across the resistor. Put each probe on one side of PR12. Meter should be set to DC Volts.
                                    Do that while it is on of course.. Do it quick so it doesn't burn the board.
                                    • antony.ag
                                      • Nov 2019
                                      • 59
                                      • Italia
                                      #98
                                      ok ... I have to change the resistance first ... measuring before he smoked he took me with the rester in ohm 22.6 now smoking he brings me 00.1 or 00.2 so I think it must be changed ... I change it and then I measure the resistance again with volt cc
                                      • KvnTM
                                        • May 2018
                                        • 434
                                        Usually resistors fail open circuit. Are you sure that the resistor is 0Ohm? Desolder it and measure.
                                        • antony.ag
                                          • Nov 2019
                                          • 59
                                          • Italia
                                          #100
                                          I have just measured the resistance in volt cc without removing it and it brings me 023
                                          • Pipolups
                                            Corsair K70 LUX RGB dying LEDs
                                            by Pipolups
                                            Hi there !
                                            I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                            Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                            10-08-2024, 11:58 AM
                                          • Anooc7
                                            Samsung UN75NU6950 no backlight but leds works when checked individually!
                                            by Anooc7
                                            Hi, This model has bottom mounted leds . Got it with right ride 1/3 of the display black. So I checked the 6 + and - wire that powers 6 different zones and found that the 5th zone was open, which opens 6th zone too makes the right 1/3 of the display dark. Opened it and found one blown led on the 5th zone and shorted that path using solder. So now all the zones works when I check it using the bl tester , but when I put everything back together there is no backlight! The voltage I am getting when neg to chassis is 387v. How does that happen? Still individual zones working with bl tester .
                                            09-16-2021, 06:16 PM
                                          • lpraderi
                                            Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
                                            by lpraderi
                                            Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
                                            In some cases to use LVDS screen PCB use converter IC RTD2132/6
                                            Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
                                            at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
                                            Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
                                            11-25-2023, 09:31 AM
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
