2009 MPB pro no lights on mag safe
  • stonewall
    • Jan 2014
    • 9
    • US
    2009 macbook pro 15"
    Could someone tell me if this is the power fuse?
    I've put my ohm meter across this and there is
    no continuity. Should there be? If this is a fuse
    does anyone know what part number I would use
    to replace it?
    Picture is attached below. Thanks.
    story:
    water damaged, won't boot, completely dead,
    no green or orange light on magsafe charger
    I'm looking for some help finding the first thing
    to check, supposedly there are surface mount fuses
    somewhere on the logic board. It would be great if
    someone could point the first one out to me.
    I have beed using a disconnected keyboard and
    a thunderbolt to hdmi for the monitor, and of course
    a magsafe charger. Sort of a test setup.
    I've used this on a second, working logic board to
    make sure this actually works.
    So, I'm down to the logic board. And this is new territory
    for me.
    Thanks in advance.
  • stonewall
    • Jan 2014
    • 9
    • US
    Re: 2009 MPB pro no lights on mag safe
    Okay, I think I've found the schematic.
    Looks like 6A - 24v --- now I still have no
    idea how to find this, like say on digi-key,
    I need some type of part number. I'm
    not to familiar with what this package is
    or what I need in a surface mount component.
    I'm referring to schem1 attachment below.
    Thanks.
    BTW, I was using my meter to check other things
    that I was guessing were fuses. Can an ohm meter,
    on ohm meter setting, blow these fuses?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      that looks like a mlcc not a fuse.
      • trebo
        • 514
        • Wales, UK
        I agree with kc8
        some fuses look like that but usually have a letter printed on them to give you a amp value (not that colour thou)
        • stonewall
          • Jan 2014
          • 9
          • US
          I'm not sure what a micc is,
          but my picture is of a capacitor.
          I found the fuses and they both have
          continuity.
          I'm not sure what to check next.
          Thanks.
          • stonewall
            • Jan 2014
            • 9
            • US
            So, these are the two objects that I believe to be the power fuses.
            I checked each one with my ohm meter, and they both have
            continuity.
            I guess I would first like to know why my magsafe lights
            do not come on, either the green or the orange. It looks like
            it's not getting any power. So any landmarks to check
            would be very helpful.
            I have already checked the DC IN board to be OK.
            Looks like there's not much interest in this,
            thanks for any hints. I probably wouldn't be
            able to fix it anyway.
            I sprayed the board down with contact cleaner,
            and then air hosed it off. It's still kind of dirty
            and I'm going to scrub it down with alcohol now.
            • khaahk
              • Dec 2013
              • 786
              • Estonia
              Look like this ic has been damaged already by liquid. Some of contacts have been destroyed. Might be charger ic, hard to tell from the picture. Take magnification glass and look closely.
              • stonewall
                • Jan 2014
                • 9
                • US
                Thanks for your response. I will take some better pictures,
                after I do some cleaning. (next week)
                I have a schematic, but I cannot tell where anything
                is on the circuit board.
                I think the first step is to get lights on my magsafe
                working, indicating power is getting through. Does
                all this start with the charger IC ?
                Does this charger IC send the sense line to
                the DC IN board?
                I can't sleep, so I took a picture. I cleaned
                up the IC discussed. And I put power on and
                measured vDC of 24.2 on both sides of the
                white fuse, reference the blue lines. So I think
                the fuse is good, if that's a fuse.
                • dj_ricoh
                  • 2073
                  thats not a fuse. not even a cap maybe coil.
                  if that was on a normal notebook it will have a mark like L or PL
                  • trebo
                    • 514
                    • Wales, UK
                    is that a burnt hole in the top left of that IC ???
                    just under the L of the bottom lettering
                    • stonewall
                      • Jan 2014
                      • 9
                      • US
                      That's not a hole, it doesn't go down.
                      It looks like a reference dot. But it's
                      hard to tell with only a magnifying glass.
                      I'm going to look for a microscope so
                      I can clearly see if there are any bridged pins
                      or rusted off pins, or whatever.
                      I just don't know what's what yet.
                      I have identified the fuse for the LCD
                      display, it's a much smaller package than
                      the white things, and it has a dot. I haven't found
                      anything with an L or PL.
                      I measured the voltage on both sides of the white
                      things, and it was the same. That's why I think it's
                      a fuse. But I really don't know.
                      • khaahk
                        • Dec 2013
                        • 786
                        • Estonia
                        Follow the planes, where the white "thing" comes and goes.
                        If it starts from adapter + and goes to some sop8 mosfet, then it is most probably fuse on + side.
                        If it comes from the adapter - side and ends in mainboard GND planes then it is also fuse.
                        If it stands in parallel, then it is cap.
                        At the end of the white "thing" there are 7 vias through the plate to the othe side. Where does it go from there?
                        By the way on the othe picture the ic looks rather good, so not sure about earlier statement.
                        • stonewall
                          • Jan 2014
                          • 9
                          • US
                          I'm adding 2 more pictures.
                          Following the traces from my hypothetical fuse
                          there is really nothing on the other side of the board
                          but a series of vias that do not have traces on
                          the visible back side. pic F_1
                          The other picture of the VM97 chip, is a
                          L8543SQ WLED backlight chip. I'm not sure if
                          this is just for the backlight or if
                          it's also for the display.
                          Anyway.
                          • khaahk
                            • Dec 2013
                            • 786
                            • Estonia
                            The 8543 looks ok. Do you have a working battery? Does it turn on with battery only?
                            If it works on battery, then there is max9940 overvoltage protection chip.
                            Next you have to find charger ic and see if it gets power.
                            If it does not work with battery either, then standby voltages, ec voltage ...
                            If you have schematcs, post it...
                            • chth96
                              Is it possible to test small ceramic disc capacitor with analogue meter?
                              by chth96
                              I read EBOOK of Testing Electronic Component and found that
                              "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                              Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                              It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                              Is it really possible to test small ceramic disc capacitor with analogue...
                              03-09-2024, 10:03 PM
                              Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                              by sam_sam_sam
                              I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                              I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                              12-31-2023, 06:04 AM
                            • ohren
                              by ohren
                              09-08-2023, 05:24 PM
                            • korben_dallas
                              Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                              by korben_dallas
                              Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                              I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                              I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                              MY QUESTION:
                              I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                              02-14-2024, 12:23 AM
