HP 650 G1 - works only with battery+charger but not detecting battery
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello.
    Have this HP 650 G1 that works ONLY when battery first and then attach charger. otherwise it not work with charger or battery only.
    i cannot fing what is wrong with it. ACDET - ok, ADP_A_ID - 3.3V ACPRESS, Mosfets looks ok. even when working board dont see battery . data link on battery is ok 3.3V
    this charging circuit is hard. anybody knows what to measure?
    HP 650 G1
    6050A2566401-MB-A04
    sn - 5CG52238HF
  • Sephir0th
    • Oct 2020
    • 1289
    Could be a faulty diode at charging controller VCC pin. Check what voltage appears there with all three conditions (charger only, battery only, battery + charger)
    FairRepair on YouTube
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Its wiser to share more details like which charging IC is used,measurements of charging IC for voltage.Are you powering it with dc supply or original adapter? Some elitebook/probook simply dont like the dc supply. If you are using dc supply,is 19V crossing the 1st dc -in fet?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        https://www.badcaps.net/forum/troubl...probook-650-g1
        charging ic is BQ24736RGR
        it have vcc , acdet, I have 3.3 and 5V, 19V ALW
        try chargind with several adapters and PSU
        mosfets on charging and powering looks ok
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Try replacing the BTST capacitor and resistor even if it measures correctly.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • bykanovm
            Thinkpad W541 Works from the mains and charges the battery only when it is turned off
            by bykanovm
            Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
            If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
            If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
            even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
            Also, the laptop does not turn on without...
            04-02-2025, 02:45 AM
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            09-14-2023, 11:10 PM
          • ZixuTech
            Lenovo Ideapad 700-15ISK shuts down shortly after it starts. Works on battery
            by ZixuTech
            Hi Guys, a weird case here.
            This laptop came with damaged hinges, but no liquid signs.
            It will loop between battery charging/not charging/charging/... Now the original battery is completely drained it won't turn on with it. The orange light keeps blinking nonstop.
            I have replaced the battery with a newly charged battery and it turns on but doesn't charge. The orange charging light blinks three times indicating charging issues.
            I have replaced bq24780S battery charging chip, no difference.
            With a connected new battery,...
            04-03-2022, 04:03 AM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
