Mac Air A1466 2012 cpu 300%
  • smic717394
    • Jun 2017
    • 93
    • Spain
    I bought a mac air 2012 very cheap, because the customer didn't want to fix. After reflowing the ram chips the laptop works fine, I tested the ram and no error. But The fan goes at max speed after few seconds. Running the Apple diagnostic finds an error 4SNS/1/C0000008: Th1H--124. and the cpu usage is like 300%, After disconnecting the webcam cable that on the 2012 model is on the IO board, the laptop, the laptop runs fine, and running the apple diagnostic finds no errors. So the problem is related with the webcam, but I suspect the problem is no the webcam but the light sensor. Connecting the webcam cable runs very slow and if I test the webcam work but the light sensor no. Removing the problem cures the problem. I´m not going to chenge the screen in this 2012, I can either leave it without the webcam or maybe if there is anyway to disable the light sensor, maybe there is a resistor or something next to the camera connector. And yes I already replace the io board and the cable, same problem.
    Thank you.
  • mon2
    • Dec 2019
    • 14098
    Check the voltage to ground of the smbus lines (scl and also sda) for the ALS (ambient light sensor). Do so very carefully.
    I2C_CAM_SCK
    I2C_CAM_SDA
    SMBUS_SMC_1_S0_SDA
    SMBUS_SMC_1_S0_SCL
    • smic717394
      • Jun 2017
      • 93
      • Spain
      What connector is this? is where the ribbon from the io to main? because the camera conector only has 4 pins i think.
      • mon2
        • Dec 2019
        • 14098
        Post your 820-**** board number. The schematic I referenced may be a different version but is the same model.
        • smic717394
          • Jun 2017
          • 93
          • Spain
          Ok, I got it. I´m attaching the schematic and boardview in case someone needs it for the main board 820-3209-A and the schematics for the IO board. I see from the schematics that on the CAMERA/ALS connecter that pin 5 is scl and pin 6 is sda, I´ll check them tomorrow under the microscope they too small. Just to confirm pin 5 and 6 of the connector are the las 2 from the left wright? Maybe I can desolder pin 5 and 6 just to try.
          [MOD EDIT] Schematics -> https://www.badcaps.net/forum/troubl...-and-boardview
          Click image for larger version  Name:	image.png Views:	0 Size:	455.6 KB ID:	3211521Click image for larger version  Name:	image.png Views:	0 Size:	51.5 KB ID:	3211524
          • mon2
            • Dec 2019
            • 14098
            Suggest to measure the voltage to ground on each pin of this connector. We can figure out the rest. The expectation is that pin # 1 will be the one with zero volts. You can also confirm this by removing all power, meter in diode mode, short your meter probes and you will hear a tone beep. Then connect one meter probe to ground on the logic board (any metal shield) and other meter probe onto pin # 1. You should hear a tone beep again. Continue to test the rest of the lines in DIODE mode.
            In diode mode, connect the red meter probe to ground; black meter probe to the point to test. Post each measurement.
            Next, move to th DC volts mode on your meter (5 volts or higher scale is ok).
            Red meter probe to point to test; black meter probe to ground (shield is ok).
            Measure each pin again. Need to confirm that there is a voltage present on pins # 5 & # 6 unless these lines are stuck or defective. On I2C lines, there is always a pull-up resistor which goes to a pull-up voltage. It is that pull-up voltage we expect to see on a known good I2C SCL or SDA line. Anything too low will halt the I2C communication traffic which will cause all other devices / sensors on that communication network to fail and hence will result in a crazy high fan spin.
            • smic717394
              • Jun 2017
              • 93
              • Spain
              Thank you for taking the time to reply, good idea, pin 1 is GND so the opposite is i2c bus. I will measure the voltages tomorrow with the connector plugged and removed but I think desoldering the 2 i2c pins should fix the problem, I´ll update tomorrow. Thank you.
              • smic717394
                • Jun 2017
                • 93
                • Spain
                ok. Its working now. Pin 1 is the ground and its the first pin towards the speaker connector. I measured the voltages not on the pins so I dont short any but on the test points. Second and third pin was showing like 5V then droping same for pin 4. I should have measure the resistance with the camera cable connected on pin 5 and 6. Pin 5 or 6 i cant remember was showing 3,3v and the other 0,5v. Anyway what I did is desolder pin 5 and 6 that are the last 2 pins so they don´t make contact with the board, and now runs fine.
                The fan speed its normal, the webcam works fine, the cpu usage is normal. Thank you for the guidance.
                • mon2
                  • Dec 2019
                  • 14098
                  Good to hear of your progress. You will probably lose out on some I2C bus device function by removing the respective lines. At this time, not sure what exactly. Suggest to seek out a used but known good LIO board as a replacement. Suspecting that there will be an ESD TVS diode on these I2C lines on the LIO board somewhere. Perhaps SC-70 or SOT-23 package. Some of the parts used by Foxconn / Apple can be tiny and the black solder mask does not help. Either way, it is probably that ESD diode that is shunting the line from an ESD event. Just an educated guess as we wasted (invested?) 3 days on a similar repair where multiple local shops said was a no fix. Came down to a < $ 0.50 USD TVS dual diode that is sacrificial by design. This part, after an ESD event, will shunt the lines they protect to ground which will halt all I2C traffic on the network.
                  • smic717394
                    • Jun 2017
                    • 93
                    • Spain
                    I did replace the IO board and the cable before, with the same result, so the problem must be on the screen itself. I checked the track from the scl/sda pins and they pass to a test point and from there i see it gows directly to the big connecter, nothing in between, so its either the main board or the screen, either way since the only problem is the auto brightness and for its age, its good as it is for now. Just to education purpose I will check where this lines goes from the logic board,
                    • mon2
                      • Dec 2019
                      • 14098
                      Well noted. Good investigative work. This is one of the screens where we actually carved open to fix a defective LVDS cable and then sealed it back up again. There are YT videos on this exact display for the LCD replacement. Not impossible but took 2 of us to perform this surgery. As you have noted, leave it alone if it works for you.
                      • xloomx
                        • Oct 2020
                        • 49
                        • Argentina
                        Thanks for the files!
                        • CapLeaker
                          AcuRite 5 in 1 temperature sensor replacement repair
                          by CapLeaker
                          Got a new victim:
                          AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                          A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                          B: stuck at some temperature and maybe updating once in 12 hrs or so.
                          Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                          04-15-2025, 01:32 PM
                        • mferna14
                          MacBook Air A1466 webcam not detecting
                          by mferna14
                          I am working on a MacBook Air A1466 (Board # 820-00165-A). The initial problem was liquid spill near the ROM chip & after cleaning & re-programmed (ME Region cleaned) all worked fine without any problems. It boots up fine, & the only problem now it is not detecting the Webcam. 1st I tested with a know good camera, same issue. I was reading forums & they say about this resistance R2042 (0 Ohms) & U1900. There was corrosion on R2042, I replaced the resistor & even U1900 on the safe side. No Luck. L4007 & L4009 are perfect too. Then I had one Known good U3900, replaced...
                          02-19-2022, 05:37 PM
                        • groomit
                          Google Pixel 5 - Proximity Sensor Issues - Reflow/Replacement procedure tipps wanted
                          by groomit
                          I just replaced the battery on a Google Pixel 5.
                          After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
                          Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
                          The rubber seal is on again (as mentioned in various suggestions in other forums).
                          This smells like a cold or broken solder joint. So I'd like to reflow...
                          06-11-2025, 02:21 AM
                        • Gcnewbie
                          Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
                          by Gcnewbie
                          Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
                          I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
                          My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
                          I opened the...
                          03-29-2024, 06:55 AM
                        • otoluk
                          Auriol weather station humidity sensor
                          by otoluk
                          I have two Lidl LD6273 Auriol units with DCF77 radio for time update.
                          I really like the idea but the cheap moisture sensor(guess HR202L) inaccuracies make the device unreliable. Also not clear why indoor and outdoor unit sensors being same type doesn't match. For example I place both units on same table and indoor unit shows 23% humidity while outdoor sensor shows 39%. What I found out is that I get better readings if cleaning the solder points of sensor inside with isopropyl alcohol.
                          Looking for replacement sensor which I could solder in place of HR202L resistive sensor but need...
                          11-06-2024, 07:57 AM
