DA0AX1MB6H1 (HP G62-358CA) - Does not turn on & Adapter Led light off when plugged
  • orientalsniper
    • Apr 2013
    • 461
    Re: DA0AX1MB6H1 (HP G62-358CA) - Does not turn on & Adapter Led light off when plugge
    Thank you, I just did, I applied current to PR228 and I hear a buzzing sound that doesn't stop, but I can't well place it, but it's in the area where I took the pictures from. I'm going to try to increase the voltage.
    • khaahk
      • Dec 2013
      • 812
      • Estonia
      #42
      If you are looking for shorts using lap power supply, keep the voltages low or you can trigger different semiconductors and get very confusing results (including buzzers in some other part of the mainboard). If the part of the circuit is in short, then 1V (limited to 1-2 Amps) is enough to sort out the shorted part.
      • orientalsniper
        • Apr 2013
        • 461
        You are right, RT8206B was buzzing, so I ordered a replacement already... lol
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          #44
          RT8206B is not a easy replace component, do you have some easy method for replacing this part?
          ...the quieter you become the more you are able to hear...
          • orientalsniper
            • Apr 2013
            • 461
            Yeah, I already desoldered it, I have Hot Air rework machine.
            • bluestone
              • Jun 2011
              • 343
              • Ghana
              #46
              have you been able to solve it now
              • orientalsniper
                • Apr 2013
                • 461
                Not yet, but I ordered the power IC, should be coming in 2-3 weeks. Had so much to repair this last week, I promise I will update with resolution.
                • orientalsniper
                  • Apr 2013
                  • 461
                  Alright, I'm back, I replaced RT8206B and I got the following readings:
                  1: 2V
                  3: 5V
                  4: 14.6V
                  6: 19V
                  7: 5V
                  14: 3V
                  19: 5V
                  27: 4.7V
                  Yet it won't turn on, DC jack still won't light on.
                  • orientalsniper
                    • Apr 2013
                    • 461
                    I left it unsupervised for a bit and the damn board was smoking, saw the KBC chip (KB3926QF) and the RT8206B burnt out.
                    Was the KBC chip damaged or did something else damage it?
                    • orientalsniper
                      • Apr 2013
                      • 461
                      Welp, I put it another new RT8206B without KBC and it got smoked too. I only bought 5 of these
                      • lgcyber
                        • Feb 2013
                        • 26
                        • Philippines
                        #51
                        Hi... I was just wondering... have you resolved this problem already? I'm curious because I have the same problem and maybe you can help me a bit with this. Thanks.
                        • orientalsniper
                          • Apr 2013
                          • 461
                          Sorry, I couldn't solve it, but you should check voltage regulator, charging IC, KBC and BIOS, use a lab power supply to detect shorts through heat.
                          • dycc
                            Vision
                            • Nov 2011
                            • 625
                            • Côte d'Ivoire
                            #53
                            got good flux like AMTEC , hakko tips for iron solder ,good hot air gun
                            • dycc
                              Vision
                              • Nov 2011
                              • 625
                              • Côte d'Ivoire
                              #54
                              those board have always the same issue . after flashing bios if the lapy still not turn on replace EC KB3926 by the same or by KB926
                              southbridge
                              1-check for +3VS5 when turning on (without this voltage the southbridge will not reply to the EC )
                              2-check EC RSMRST# 3.3v when turning on
                              3- check EC DNBSWON# if it is high(3.3v) it must be 0v when turning on or 3v if it is low(0v)
                              without those voltage assume EC is not good
                              4-check EC SUSC# 3.3v when turnin on
                              5-check EC SUSB# 3.3v when turnin on
                              if SUSC# SUSB# are not present assume southbridge is not good
                              for those who don't have +PRWSRC(19v pq52 pin3) check pin1 pq52(must be 28v) if not , replace pq55 P MOSFET(even if it seem to work).
                              • kuldeep
                                • Sep 2013
                                • 30
                                • india
                                #55
                                most probably CPU Section mosfet are faulty ..so pull out n check it ..19v at current limiting resistance(R020)..& generation of 5v & 3.3v
                                • serious_electron
                                  Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                  by serious_electron
                                  Hello Everyone!
                                  I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                  06-28-2025, 02:57 PM
                                • Adogabriel100
                                  Macbook pro A1278 820-2936 No light/turn on
                                  by Adogabriel100
                                  Hey! how are you guys? i wonder if you could help me with this macbook 820-2936 that does not turn on. (Doesn't have green/orange light).
                                  History:
                                  this macbook came for a short on C6990 that blows D6990 and R6990 on his way. i re-placed the componets and it work again.
                                  A month later comes back again and has the actual problem (no green/orange light and dont turn on)
                                  The macbook can turn on with only the battery connected but in fact, dosent charge.
                                  Voltajes:
                                  PP3V42_G3H = 3.3v
                                  PPBUS_G3H = 12.2V
                                  PM_PWRBTN_L...
                                  06-28-2023, 07:41 PM
                                • David Morel
                                  Latitude 5520 i7, adapter light goes off when plugged in
                                  by David Morel
                                  Hello! This is my very first post, thanks for accepting me on this forum.
                                  i have a 5520 latitude that suddenly stopped charging, the light from the adapter goes off when it’s plugged it, i tested different chargers, checked the ports and they seem to be fine, any help would be appreciated
                                  10-22-2025, 09:09 PM
                                • popzeggey
                                  Dell Precision 7520 power issue
                                  by popzeggey
                                  Hello, I have the similar problem. My Dell Precision 7520 doesn't turn on with only battery. Below are the various scenarios and its symptoms
                                  1. With only battery, the laptop turns on but no display and shuts down after few seconds
                                  2. With battery and charger plugged in, the battery light comes on. But pressing the power button does nothing and laptop refuses to turn on. However, the battery led light blinks every 17seconds from when the charger is plugged in with or without battery. So whether the battery is inserted or not, the battery led light will turn when charger...
                                  06-07-2024, 09:23 PM
                                • dionzarek
                                  PS5 Slim EDM-040 Only turn on 1 Sec, Blue light then immediate off.
                                  by dionzarek
                                  Hello everyone, I am new to this PS5 troubleshooting, I need help on diagnosing the problem. My PS5 Slim board EDM-040 that beep and only shows blue light then immediately turn off.
                                  I've checked the PSU its normal 12V. I've checked all the capacitors its all good no shorts, but there are 2 caps shorted, I think its near the SSD. You can look at the image attachment.
                                  When tested it only shows 0.003 while other caps show 0.4 to 1. WHen in continuity mode those 2 caps goes beep/shorted.
                                  Any help to where should I check on or suggestion would be very appreciated....
                                  02-08-2025, 11:00 PM
