DA0AX1MB6H1 (HP G62-358CA) - Does not turn on & Adapter Led light off when plugged
  • orientalsniper
    • Apr 2013
    • 461
    Re: DA0AX1MB6H1 (HP G62-358CA) - Does not turn on & Adapter Led light off when plugge
    Hello, is resistance test in SMD capacitor conclusive? I'm getting 8 ohms in most.
    • whaldsz
      • Apr 2013
      • 395
      • Philippines
      Of course. Your measurement indicates a problem. The next problem is how to identify which component is shorted.
      • orientalsniper
        • Apr 2013
        • 461
        Sorry to bother you, but how can I solve this next problem? The lab power supply I ordered should be coming soon next week, in the meantime I want to do the remaining tests possible. Thank you again.
        • whaldsz
          • Apr 2013
          • 395
          • Philippines
          the power supply you ordered will be very helpful in solving the next problem. You can spot the damaged component within a few minutes.
          But if you wish to do it the hard way, you need to trace all components connected to +PWRSRC (19v) and check them one by one until you found the damaged component. Sometimes corrosion on the motherboard or physical component damage will reveal the location of culprit. This manual process will take you many hours or even days. Just be patient.
          • orientalsniper
            • Apr 2013
            • 461
            Thank you very much once again, will report back when I get results.
            • bluestone
              • Jun 2011
              • 343
              • Ghana
              #26
              Originally posted by whaldsz
              You will know that the ec bios chip/sio chip is working if you get 3.3v at rsmrst#. If you dont have, flashing the bios is one of the possible solution. To do this, you need a spi programmer.
              I get 0v at pin 95 of U4 which should be rsmrst# even after pressing power button it still 0v at rmsrst# and S5_on. I don't really know about these programmers so can you recommend any for as it is my first time.
              • bluestone
                • Jun 2011
                • 343
                • Ghana
                #27
                First take off the processor and check for resistance again. focus more attention on these mosfets around PL9 and PL10, (PQ37, 38, 41 and 42) Notice if any of them reads 0hms
                • whaldsz
                  • Apr 2013
                  • 395
                  • Philippines
                  #28
                  What do you get at ac_in#?
                  About programmer, this one works for me - http://www.sofi-tech.com/en/product_view.asp?id=13
                  • orientalsniper
                    • Apr 2013
                    • 461
                    So, I get 0 in Diode Test in NIKOS P2003BVG which is PQ54 (close to PL5) and it doesn't appear in the schematic someone earlier uploaded.
                    I'm going to look for an equivalent replacement.
                    • orientalsniper
                      • Apr 2013
                      • 461
                      Can I replace it with this ?
                      • orientalsniper
                        • Apr 2013
                        • 461
                        So I swapped it anyways, but with the mosfet soldered doing Diode Test, I'm getting 0 too.
                        • khaahk
                          • Dec 2013
                          • 812
                          • Estonia
                          #32
                          Quanta AX1 schematics:
                          • whaldsz
                            • Apr 2013
                            • 395
                            • Philippines
                            #33
                            Diode test on what pin?
                            • bluestone
                              • Jun 2011
                              • 343
                              • Ghana
                              #34
                              These mosfets are normally 4 in number and it is only one of them would be shorted so check well.
                              • orientalsniper
                                • Apr 2013
                                • 461
                                Thank you, I think this is the right one.
                                I do Diode Test on pins 2-3 with 6-7. I followed the instructions from this video: http://www.youtube.com/watch?v=fOGAhaVH06I
                                • orientalsniper
                                  • Apr 2013
                                  • 461
                                  Alright, I just got the DC Controlled Power Supply, I had been testing it with random capacitors and with crayon all over to see which one gets hot, am I doing it right?
                                  • orientalsniper
                                    • Apr 2013
                                    • 461
                                    Hello all, to summarize what happened, using the right schematic in post #32 :
                                    1) Another mosfet Nikos P2003BVG (PQ67) failed the diode test. So I replaced it with another FDS8884.
                                    2) While unplugged from power, I was testing resistance in capacitors in the photo attached, they were shorted once and they went back to normal after re-testing, part of the reason I can't read any V in the battery terminals.
                                    3) Can someone explain to me how can I trigger the amber/white LED light in the DC Jack? (Check attachment for part in the schematic)
                                    4) With my DC Power supply I connected it to PC58 at 1A-6V, PC176 was getting extremely hot, but I took it out and it wasn't shorted out of circuit.
                                    Also, where is the initial 19V +PWRSRC?
                                    • whaldsz
                                      • Apr 2013
                                      • 395
                                      • Philippines
                                      #38
                                      See page 39 for +PWRSRC.
                                      • orientalsniper
                                        • Apr 2013
                                        • 461
                                        Hello whaldsz, I do see it in the schematic, I meant in the motherboard itself; or can I connect the power supply to "PC204", "PR228" or "PQ55"?
                                        • whaldsz
                                          • Apr 2013
                                          • 395
                                          • Philippines
                                          #40
                                          Yes you can.
                                          • serious_electron
                                            Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                            by serious_electron
                                            Hello Everyone!
                                            I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                            06-28-2025, 02:57 PM
                                          • Adogabriel100
                                            Macbook pro A1278 820-2936 No light/turn on
                                            by Adogabriel100
                                            Hey! how are you guys? i wonder if you could help me with this macbook 820-2936 that does not turn on. (Doesn't have green/orange light).
                                            History:
                                            this macbook came for a short on C6990 that blows D6990 and R6990 on his way. i re-placed the componets and it work again.
                                            A month later comes back again and has the actual problem (no green/orange light and dont turn on)
                                            The macbook can turn on with only the battery connected but in fact, dosent charge.
                                            Voltajes:
                                            PP3V42_G3H = 3.3v
                                            PPBUS_G3H = 12.2V
                                            PM_PWRBTN_L...
                                            06-28-2023, 07:41 PM
                                          • David Morel
                                            Latitude 5520 i7, adapter light goes off when plugged in
                                            by David Morel
                                            Hello! This is my very first post, thanks for accepting me on this forum.
                                            i have a 5520 latitude that suddenly stopped charging, the light from the adapter goes off when it’s plugged it, i tested different chargers, checked the ports and they seem to be fine, any help would be appreciated
                                            10-22-2025, 09:09 PM
                                          • popzeggey
                                            Dell Precision 7520 power issue
                                            by popzeggey
                                            Hello, I have the similar problem. My Dell Precision 7520 doesn't turn on with only battery. Below are the various scenarios and its symptoms
                                            1. With only battery, the laptop turns on but no display and shuts down after few seconds
                                            2. With battery and charger plugged in, the battery light comes on. But pressing the power button does nothing and laptop refuses to turn on. However, the battery led light blinks every 17seconds from when the charger is plugged in with or without battery. So whether the battery is inserted or not, the battery led light will turn when charger...
                                            06-07-2024, 09:23 PM
                                          • dionzarek
                                            PS5 Slim EDM-040 Only turn on 1 Sec, Blue light then immediate off.
                                            by dionzarek
                                            Hello everyone, I am new to this PS5 troubleshooting, I need help on diagnosing the problem. My PS5 Slim board EDM-040 that beep and only shows blue light then immediately turn off.
                                            I've checked the PSU its normal 12V. I've checked all the capacitors its all good no shorts, but there are 2 caps shorted, I think its near the SSD. You can look at the image attachment.
                                            When tested it only shows 0.003 while other caps show 0.4 to 1. WHen in continuity mode those 2 caps goes beep/shorted.
                                            Any help to where should I check on or suggestion would be very appreciated....
                                            02-08-2025, 11:00 PM
