Macbook Pro A1286 power on problem
  • Simpletek
    • Mar 2011
    • 35
    • Italy
    Hi all, i have an issue with this Macbook, MB code 820-2850
    Magsafe light always green, battery not charging, pressing power button nothing happend....
    tried smc bypass, not work
    take apart motherboard :
    tested voltage, magsafe connected 12v on PPBUS_G3H (all 12v rail) changes between 7v and 12v continuously
    only battery connected 12v ok but no power
    tried 16,5 volts from universal notebook adapter, soldered on ground and first fuse, 12v rail ok and not change but no power
    any ideas?? thanks
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: Macbook Pro A1286 power on problem
    is there any liquid trace under keyboard ?
    • Simpletek
      • Mar 2011
      • 35
      • Italy
      No, MBP seems like new....
      • xalu
        • Mar 2015
        • 37
        Hi, I am also looking for the board view
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          chek with boardview , were to find SMC_ONOFF_L or SMC_ON_OFF_L
          you will see ++3ghot power signal 3.42 volts
          short with GND , it should turn on
          reove keyboard , and remove battery , without battery macbook should turn on alone as well
          if not , could be bad SMC or bad SMC contact
          meanwhile here it is , BDV and schematic for the board you need
          • MikkiG
            • Feb 2016
            Thanks for this!
            • SarcasticOP
              General question about MacBook power rails for repair.
              by SarcasticOP
              I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
              • PPBUS_G3H (12.6V-12.8V)
                • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
              • PP3V42_G3H (3.42V)
                • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
              • PPVRTC_G3H (3.3V)
                • This
              12-12-2024, 05:50 PM
            • durchfall
              MacBook 2011 A1286 power cycle, no chime
              by durchfall
              I have a MacBook Pro 15" late 2011, it has a dead GPU and was sent to a repair center for this issue multiple times, the last time the original owner of this machine decided to not fix it anymore. The repair center returned the machine, but they desoldered the GPU and VRAM, it just physically isn't there anymore. The machine did originally work, we'll get to it.
              What it does now: does not turn on in SMC bypass mode, the fans just twitch and I can hear a ticking sound from the board, almost like there was a short circuit. But in normal mode it does start, fans spin for about 10 seconds,...
              01-11-2023, 05:56 AM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • Duranitron
              Asus x512dk rev 2.1 power on problem
              by Duranitron
              When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
              Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
              11-26-2024, 10:22 PM
            • EazyBone
              LG OLED55C9PUA power problem
              by EazyBone
              Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
              Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
              I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
              The power supply to t con is different story.
              This...
              06-23-2023, 07:43 AM
