how to check if xtal is working?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3634
    • slovakia
    Hello.
    I try to check some xtals wit my cheap osciloscope but i never get any good readings even when i measure working board.
    with my osciloscope i generated 32kh signal and can be easily check. but on xtals measure only some voltage
    How u measure it?
  • mon2
    • 14832
    https://electronics.stackexchange.co...ing-multimeter
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3634
      • slovakia
      found nothing usefull in that link
      • mon2
        • 14832
        It isn't possible. The crystal should be first inserted into an oscillator circuit and its output signal is to be read by a frequency meter or by a multimeter with the frequency meter function. The only instrument which is able to read a crystal frequency is a dip meter, a multi-purpose instrument used by radio amateurs.
        fom the selected best answer on the above webpage.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3634
          • slovakia
          but that is masuring outside of circuit. i need to measure inside circuit when start an i need to know why i cannot measure it
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Make sure you are using AC Coupling and not DC coupling. I can read them perfectly with my oscilloscope. Not a great one but just sufficient for my purpose. Its a UNIT 2102CEX
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3634
              • slovakia
              now i see there is a switch with marking AC/DC. Coupling. what is it for?
              • reformatt
                • Feb 2020
                • 1549
                If you are measuring a crystal circuit, it's important to use 10x probes. A lot of probes may have 1x/10x switch on them. The 10x increases the attenuation but also the impedance so it will not load down the circuit your measuring. The CRO normally has a 1x/10x setting that you set to correspond to what your probes are set to. There's also a a variable cap inside the probe you use to tweak compensation. You connect the probe to the CRO's internal 1khz signal and tweak the probe till you get a flat square wave.
                Xtal circuits usually have some kind of DC bias on them, so you use AC coupling in the scope to remove the DC from the measurement and then you only see the oscillations. Hard to see a 50mv AC signal superimposed on 1V of DC as your waveform will be off the screen.
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3634
                  • slovakia
                  Mate i owe u BIG one for teach me this secrets. i just repaired my first laptop by replaced my first crystal just by blind because it signal was bad.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    It was just simple basics about using DSO. Glad it helped you.
                    PS: Tip for those guys who dont own a DSO about checking crystal-Measure voltage on both ends of crystal and if the voltage differs by 0.1V approx-90% chance crystal is ok.
                    • dreico33
                      TL866 II Plus Check ID Error on various IC
                      by dreico33
                      Hellow guys , i really need your help here.
                      Lately i have a problem with My TL 866 II Plus programmer, and to be more specific many times on various IC ( Winbond, Gigadevice Mx) i get Check ID Error while i am trying to read the IC. Has already been detected without any kind of problem, but the only to read them is to uncheck every time the "Check ID " option. After that i can read it erase it and re-program it only to get another error at then end saying that can not verify the programing went well so i have program failed. So i am trying to find out what is going on? I...
                      11-04-2024, 03:13 PM
                    • hasel17
                      CH341a can erase and read but can't write and blank check
                      by hasel17
                      So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                      Code:
                      Checking for blank...
                      (Press
                      10-26-2023, 06:20 AM
                    • pb1911nt
                      820-4924-A Runs suspiciously slow - what could you measure?
                      by pb1911nt
                      Hi
                      I have now a 820-4924 (with a i7 and 16GB).
                      I would like to get the device working again for me.
                      The Problem is the Device comes to me with a "dead" ssd. I tested on a other 820-4924 (i5-8gb) board and the MAC OS Installation stopped working with this SSD.
                      Well i hope/guess its was a easy peasy Fix - New SSD And its working again.. But No!
                      I don't know exactly how the procedure should start. But the LCD panel goes dark - then the "chime"(?!) sound comes and only 2 or 3 seconds later the apple comes.
                      it doesn't...
                      10-27-2025, 08:48 AM
                    • Spider1211
                      Weird but interesting issue with DELL 3542 (intel mb 13269-1)
                      by Spider1211
                      Hey guys, need help fixing a weird issue with DELL 3542 with board cedar intel mb 13269-1
                      Schematic from here: https://www.badcaps.net/forum/showthread.php?t=52924
                      Backstory:
                      Laptop came in as completely dead. I opened it and removed the top half of the casing (as well as battery) and tried to power it again and it turns on and post. I turned it off, unplug charger, plugged back in and nothing. No boot, no nothing. I tried resetting CMOS but no dice.
                      Power supply draw:
                      Voltage: 19.40V
                      Amp draw: 0.006 - 0.007A
                      Amp draw...
                      04-07-2021, 03:21 PM
                    • EvazX
                      ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                      by EvazX
                      I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                      Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                      For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                      However, after some time, the replacement motherboard...
                      08-25-2025, 06:09 PM
