Mac T2 after update(There was an error activating your device)
+ More Options
Posts
  • medinfo
    • May 2016
    • 328
    • Morocco
    Macbook Pro 2019 T2
    iCloud OFF
    MDM unlocked by changing Serial Number
    worked fine but after latest update see (There was an error activating your device. Please try again).
    Erased and boot in internet recovery, same error.
    changed to original serial number (iCloud OFF & MDM ON), same error.
    tested with others serial number, same error.
    tested (CMD+R), (Option+CMD+R), (Shift+Option+CMD+R), same error
    Revived and restored by Apple Configurator and same error.
    Any help ?
  • anhbanxoi
    • Sep 2021
    • 170
    • VN
    Change the serial to the original SN then activate again. (Try reset NVRAM/PRAM by pressing Option + Command + P + R​ before activate)
    • medinfo
      • May 2016
      • 328
      • Morocco
      Changed the serial to the original and already reset nvra/pram same error !
      • m041633n
        • Oct 2020
        • 21
        • india
        It's on lost or stolen mode I think! Check serial on icloud clean status servers Luke gsm servers¡
        • medinfo
          • May 2016
          • 328
          • Morocco
          Already checked with full GSX Report, Clean and off !
          • curiositymaster
            • Apr 2021
            • 45
            • Nigeria
            I think Apple found a way to patch our serial number change method of removing MDM. I also did a serial number swap (to remove MDM) and boom, the Mac is now icloud locked (with the new serial number). It seems Apple now revalidates the new serial number if it is linked to pre-existing FMI, which is now being triggered to lock the device on the new bridgeOS update.
            • curiositymaster
              • Apr 2021
              • 45
              • Nigeria
              For now, I'd advise everyone to pend all Serial swap (unless you're sure the new SN is iCloud free) until we find a fix.
              • medinfo
                • May 2016
                • 328
                • Morocco
                but i changed the serial number with others sn icloud off and mdm off, and same error, i know that the new bridgeOS or the new update it's the problem
                • curiositymaster
                  • Apr 2021
                  • 45
                  • Nigeria
                  it's the new bridgeOS.
                  • medinfo
                    • May 2016
                    • 328
                    • Morocco
                    Any solution ?
                    • curiositymaster
                      • Apr 2021
                      • 45
                      • Nigeria
                      Any solution ?
                      Don't upgrade BridgeOS
                      • shlomim412
                        • May 2018
                        • 43
                        • israel
                        did you manage to sort this out? could be a bad wifi connection?
                        worth to try with ethernet cable connected...
                        • kevingill
                          • Jun 2013
                          • 152
                          • England
                          If you're keep the MacBook, it might be worth trying one of the paid bypass services. That should skip the activation page.
                          • medinfo
                            • May 2016
                            • 328
                            • Morocco
                            tested with ethernet same
                            • medinfo
                              • May 2016
                              • 328
                              • Morocco
                              maybe need the original serial number and maybe the the back cover its not original
                              • pehol193
                                • Oct 2019
                                • 8
                                • Poland
                                Usually i change one letter in SN. It is locked now? I have to unlock MDM from A2251 Macbook pro.
                                • TechSplendid
                                  • Oct 2023
                                  • 14
                                  • Gelderland
                                  Hi All,
                                  Hope everyone is doing well. Do I understand correctly that an MDM unlock for T2 machines is no longer possible because of a BridgeOS update?
                                  I was just about to learn this but if it is no longer possible then there is no point :-)
                                  Thanks in advance!​
                                  • anhbanxoi
                                    • Sep 2021
                                    • 170
                                    • VN
                                    Originally posted by TechSplendid
                                    Hi All,
                                    Thanks in advance!​
                                    Still possible. Just change your SN
                                    • TechSplendid
                                      • Oct 2023
                                      • 14
                                      • Gelderland
                                      Hi anhbanxoi,
                                      Thank you!!! And what I understood is that you do have to use an existing serial right? Does that have to be a serial from the same model or can it be a serial from another (older) model for example? What I am afraid of is that if you use a serial of an existing model and it is later linked to an icloud that the other also gets an icloud. Or is that not the case?
                                      Thanks again!
                                      • anhbanxoi
                                        • Sep 2021
                                        • 170
                                        • VN
                                        Hi anhbanxoi,
                                        Thanks again!
                                        You can use any other sn with no MDM even it's currently icloud locked.
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
                                        • rmjimenez455@gmail.com
                                          Sumsour station 8586D error H-E
                                          by rmjimenez455@gmail.com
                                          Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
                                          09-07-2024, 09:33 AM
                                        • Dannyx
                                          Hilti PD30 Laser Range meter Error 276
                                          by Dannyx
                                          Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
                                          So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing...
                                          07-30-2023, 05:05 AM
                                        • ChattFix
                                          PS5 Slim Beep No Light UART DDR4 Error
                                          by ChattFix
                                          Hello everyone, I need some help with a PS5 Slim board EDM-040 that will beep but no light or fan spin.
                                          When I connect my bench power supply, (12v 0.500amp) the amps go between .135-.035 then back to .005.
                                          When I attach UART I get the error code below. I have replaced the DDR4 ram IC with one from a donor board. Cannot verify is the IC was working or not, still same error.
                                          [Slot #] [Date Time] [Error Code] [Priority] [Error Message]
                                          00 5/27/2024 4:25:40 PM 80871001 Low DDR4 Error (Power Failure or Short Circuit)
                                          |-(OK 00000000 80871001 17554CCE...
                                          05-27-2024, 02:51 PM
