Mac T2 after update(There was an error activating your device)
    Macbook Pro 2019 T2
    iCloud OFF
    MDM unlocked by changing Serial Number
    worked fine but after latest update see (There was an error activating your device. Please try again).
    Erased and boot in internet recovery, same error.
    changed to original serial number (iCloud OFF & MDM ON), same error.
    tested with others serial number, same error.
    tested (CMD+R), (Option+CMD+R), (Shift+Option+CMD+R), same error
    Revived and restored by Apple Configurator and same error.
    Any help ?
    Change the serial to the original SN then activate again. (Try reset NVRAM/PRAM by pressing Option + Command + P + R before activate)
      Changed the serial to the original and already reset nvra/pram same error !
        It's on lost or stolen mode I think! Check serial on icloud clean status servers Luke gsm servers¡
          Already checked with full GSX Report, Clean and off !
            I think Apple found a way to patch our serial number change method of removing MDM. I also did a serial number swap (to remove MDM) and boom, the Mac is now icloud locked (with the new serial number). It seems Apple now revalidates the new serial number if it is linked to pre-existing FMI, which is now being triggered to lock the device on the new bridgeOS update.
              For now, I'd advise everyone to pend all Serial swap (unless you're sure the new SN is iCloud free) until we find a fix.
                but i changed the serial number with others sn icloud off and mdm off, and same error, i know that the new bridgeOS or the new update it's the problem
                  it's the new bridgeOS.
                    Any solution ?
                      Any solution ?
                      Don't upgrade BridgeOS
                        did you manage to sort this out? could be a bad wifi connection?
                        worth to try with ethernet cable connected...
                          If you're keep the MacBook, it might be worth trying one of the paid bypass services. That should skip the activation page.
                            tested with ethernet same
                              maybe need the original serial number and maybe the the back cover its not original
                                Usually i change one letter in SN. It is locked now? I have to unlock MDM from A2251 Macbook pro.
                                  Hi All,
                                  Hope everyone is doing well. Do I understand correctly that an MDM unlock for T2 machines is no longer possible because of a BridgeOS update?
                                  I was just about to learn this but if it is no longer possible then there is no point :-)
                                  Thanks in advance!
                                    Originally posted by TechSplendid View Post
                                    Hi All,
                                    Thanks in advance!
                                    Still possible. Just change your SN
                                      Hi anhbanxoi,
                                      Thank you!!! And what I understood is that you do have to use an existing serial right? Does that have to be a serial from the same model or can it be a serial from another (older) model for example? What I am afraid of is that if you use a serial of an existing model and it is later linked to an icloud that the other also gets an icloud. Or is that not the case?
                                      Thanks again!
                                        Hi anhbanxoi,
                                        Thanks again!
                                        You can use any other sn with no MDM even it's currently icloud locked.
