HP G62-A70sv white picture on lcd
  • lefos
    • Nov 2013
    • 321
    • Greece
    Hello everybody,
    I need your help on this one. It powers on for a while and the picture on the lcd is white. On hdmi output I don't have picture. After nearly 20 secs it shuts down. I have changed both vga + a smaller ati chipset (not the southbridge). Any advice on this?
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: HP G62-A70sv white picture on lcd
    did you try a good lcd panel ?
    • dj_ricoh
      • 2073
      there are 2 cases with white screen:
      1.bad screen or cable( change the screen with a smash one and see if its the same)
      2. video card problem( i try yesterday to reflow a acer with black screen and after it give me a white screen ; no signal on external)
      • lefos
        • Nov 2013
        • 321
        • Greece
        Thanks for your replies. Yes I have already tried its panel to another device and it works.
        I have already changed the vga with new one.
        • dj_ricoh
          • 2073
          you change the gpu chipset?
          and still white screen?
          • lefos
            • Nov 2013
            • 321
            • Greece
            Yes! It has exactly the same behavior. The strange thing is that it turns off after ~20secs. I don't have much experience on hp's laptops. On a vaio white picture problem was from the gpu.
            • dj_ricoh
              • 2073
              shutdown in bios? safe mode? or normal boot?
              • lefos
                • Nov 2013
                • 321
                • Greece
                I guess during post. Powers on, waits for a few secs then white screen and finally shuts down.
                • spleenharvester
                  • Mar 2010
                  • 921
                  I would be checking voltage lines. If the VGA and chipset have been changed I doubt it's a BGA fault.
                  Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                  • dj_ricoh
                    • 2073
                    he change only the vga chip;
                    maybe a reflow on the chipset will do the trick
                    • lefos
                      • Nov 2013
                      • 321
                      • Greece
                      Happy new year to everybody and thanks a lot for your answers! I have changed the chipset also and have done a fast reflow on the southbridge chipset. Is there for any chance for somebody to have the service manual for this? I searched but found only with intel's chipset.
                      • Mgiffune
                        by Mgiffune
                        06-09-2024, 10:28 AM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • EazyBone
                        Sharp LC-65Q620U White Screen
                        by EazyBone
                        Another TV topic!!
                        I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                        The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                        Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                        08-21-2024, 12:56 PM
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
                      • hcinne
                        Dell G15 ryzen edition black screen 2 amber 1 white
                        by hcinne
                        I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                        07-23-2024, 07:56 AM
