today get this one with complete dead condition.3v present on power switch and also on small 128kb chip. when connect with dc power supply the standby current is 0.03a...................any ideas or schematic
					lenovo v460 no power
 Re: lenovo v460 no power
 Check this and post results. The 128KB chips is the one I´d program first.
 Attached FilesComment
 try this oneAttached FilesComment
 Hi !
 dead board same model . no power at any coils no 3.3 or 5 volt switch has power .
 some power at ec bios pin no 1.
 changed tps51123.
 u2 SMSC EMC2103 had a HOLE or pop
 ThanksComment
 Assuming...7 Photos
			by PantherDaveHi all!
			by GLISITHi all,
			by Dr.dI have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
 Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
			by claws77hi guys, my motherboard will not start no matter what
 when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
 but rest nothing happens no sign of life.
 this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
 with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
 but now nothing happens no matter how much i wait/ charge/ press and hold power button.
 i have no knowledge of motherboards ....10-20-2024, 02:48 PM
- Loading...
 it power after
 it power after
