lenovo v460 no power
  • alihomee
    • Dec 2012
    • 1594
    • malaysia
    today get this one with complete dead condition.3v present on power switch and also on small 128kb chip. when connect with dc power supply the standby current is 0.03a...................any ideas or schematic
  • alihomee
    • Dec 2012
    • 1594
    • malaysia
    Re: lenovo v460 no power
    any body
    • are-red
      • Feb 2013
      • 24
      • malaysia
      its 5v present? try to re-flash the bios first
      • robrock1
        • Jul 2013
        • 129
        • Ghana
        see if something is getting hot somewhere, standby current is mostly around 0.01 - check around power and charging ic maybe a capacitor or diode is leaking?
        • alihomee
          • Dec 2012
          • 1594
          • malaysia
          i do not have the files to flash bios. one chip is 128kb and one is 4mb....
          • Francisco.s
            • 686
            • Spain
            Check this and post results. The 128KB chips is the one I´d program first.
            • dj_ricoh
              • 2073
              • uk
              last time i try to find out why it did not power up i ended up reflowing and it when back to normal.
              • alihomee
                • Dec 2012
                • 1594
                • malaysia
                which chip u reflow
                • dj_ricoh
                  • 2073
                  • uk
                  which chip u reflow
                  cuz i run out of ideas i cook the board
                  it power after
                  • alihomee
                    • Dec 2012
                    • 1594
                    • malaysia
                    hahah funny repair
                    • alihomee
                      • Dec 2012
                      • 1594
                      • malaysia
                      today done it by reflashing both chips
                      • jtamad44
                        • Apr 2013
                        • 145
                        • israel
                        Good job! Can you please share the bios.bin file..
                        • tomodachi
                          • Apr 2012
                          • 610
                          • Turkey
                          a few days ago I fixed a no power problem reflashing the eprom.
                          • alihomee
                            • Dec 2012
                            • 1594
                            • malaysia
                            try this one
                            • jtamad44
                              • Apr 2013
                              • 145
                              • israel
                              Thanks alihomee!
                              • ravi_1617
                                YY Solutions
                                • Jan 2012
                                • 348
                                • India
                                Hi !
                                dead board same model . no power at any coils no 3.3 or 5 volt switch has power .
                                some power at ec bios pin no 1.
                                changed tps51123.
                                u2 SMSC EMC2103 had a HOLE or pop
                                • ravi_1617
                                  YY Solutions
                                  • Jan 2012
                                  • 348
                                  • India
                                  Thanks alihomee!
                                  display came it was ec bios problem
                                  with your B560 worked in my v460
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
                                  • PantherDave
                                    by PantherDave
                                    Hi all!
                                    05-29-2024, 02:01 PM
                                  • GLISIT
                                    by GLISIT
                                    01-16-2025, 02:29 PM
                                  • Dr.d
                                    Help please..Lenovo ideapad 5 14itl05 power and charging problem
                                    by Dr.d
                                    I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                                    Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                                    04-05-2024, 11:48 AM
                                  • claws77
                                    lenovo flex 5 14itl05 power sequence issue
                                    by claws77
                                    hi guys, my motherboard will not start no matter what
                                    when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                    but rest nothing happens no sign of life.
                                    this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                    with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                    but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                    i have no knowledge of motherboards ....
                                    10-20-2024, 02:48 PM
