CQ61-310EJ No Power
  • s_henya
    • Jan 2011
    • 480
    • Israel
    CQ61-310EJ No Power
    Hey guys,
    got this laptop, with bad contacts on DC jack (didnt power at all finally)
    found some corrosion both on charger connector and dc jack (comes with harness of 6 pins).
    cleaned them both but with no power at all,
    the led on the jack wont ever light.
    tested voltages on ouput pins:
    2 blacks are shorted
    2 reds are shorted
    between yellow to black 18.22v
    between yellow to red 17.55v
    between yellow to white 15.95v
    the specs on charger shows 18.5v 3.5a
    so i figured the charger and harness are OK,
    when the harness is connected got almost nothing on the outputs.
    i saw this chip confused to be mosfet SD840S
    but by the datasheet its a 2 diode form.
    tested between too legs got short,
    lifted one leg but still got short bewteen pads,
    now between two legs got nothing, so im gussing its fine.
    im pretty cluless right now. so any help will be very appriciated.
    Shai.
  • dj_ricoh
    • 2073
    Re: CQ61-310EJ No Power
    unsolder the bios and see if the light from the power jack its restored.
    the board its like g61 like a mirror.
    i ahd a problem like that and usually 90% got bios problem.
    don`t ask me why but i manage to find the problems here on the forum.
    • s_henya
      • Jan 2011
      • 480
      • Israel
      hey dj_ricoh,
      thanks for the reply,
      i tried removing the bios chip
      but still got no power dc jack led didn't came on.
      any more ideas before ordering a replacement board?
      • fddizon
        • Sep 2011
        • 555
        • Philippines
        download schematic of this mobo first and check signals on bios and ene chip to confirm if its bios issue.
        by the way... s_henya, do you sell untouched scrap mobos? (when i say untouched, parts are complete, nothing taken from it)
        • s_henya
          • Jan 2011
          • 480
          • Israel
          hey fddizon
          thanks the the reply,
          i ruled out the bios chip, i still got a short between 2 pads of the sd804s
          and a major voltage drop when the bios chip was out.
          im gussing something else failed,
          using a schematic would help, il try to find one but so far no luck...
          by the way about dead mobos,
          i usually gather them for a while to a pile and sell them to scrap yards for 5$ a kilo.
          • fddizon
            • Sep 2011
            • 555
            • Philippines
            can i buy them @ $8 per kilo?
            • fddizon
              • Sep 2011
              • 555
              • Philippines
              try this one... might be the same
              • s_henya
                • Jan 2011
                • 480
                • Israel
                thats looks good,
                its my first real challenging fix on a laptop mobo,
                so where do i start from?
                fddizon pm me about the boards later i will help as much as i can..
                • s_henya
                  • Jan 2011
                  • 480
                  • Israel
                  well i didnt find a solution so i ordered a used mainboard on ebay (a little less than 100$)
                  but i think i made a mistake.
                  im starting to think that the charger is BAD,
                  between outer circle (-) and center pin(+) i get 17.52v
                  between inner circle (-) and center pin(+) i get 17.35v
                  between outer circle (-) and inner circle(+) i get 0.076v
                  is this reasonable?
                  i got today a hp probook with charging problems
                  (wont charge the baterry, replaced to new original battery but won't charge)
                  it has a universal charger
                  between outer circle and center pin i get 0
                  between outer circle (-) and inner circle(+) i get 19.37v
                  so i tested the CQ61 with the universal adaptor there is a light for 3 secs on dc jack.
                  i think that both of them are faulty.
                  please HELP!
                  • khaahk
                    • Dec 2013
                    • 756
                    • Estonia
                    The outer circle is GND
                    Inner circle is +V
                    Center pin is ID (when not connected shows about +V, when connected to mainboard, should be 7-8 V)
                    When ID voltage is less, machine won't turn on.
                    You can emulate a smart adapter by connecting a resistor of ~200kOhm from V+ to ID pin.
                    • s_henya
                      • Jan 2011
                      • 480
                      • Israel
                      thank you khaahk, so that means that the original charger was BAD,
                      (were where you when i started this thred) :-)
                      (stupid charger wasted me hours)
                      So there is some progress, the charging light now lights!
                      but still no power when i press the power button.
                      (without the universal adaptor on battery only)
                      when i press the power button all 3 lights blinks 3 times
                      • dj_ricoh
                        • 2073
                        usually i`ll start with bios.
                        i`ll see tomorrow if i got a dump file so you can reprogram and test it.
                        • vinkos
                          • Jul 2013
                          • 51
                          • Netherlands
                          Blinking 3 times is problem with memory !
                          Maybe you forgot to put memory stick back !
                          http://h10010.www1.hp.com/ewfrf/wc/d...name=c01443366
                          • s_henya
                            • Jan 2011
                            • 480
                            • Israel
                            no the laptop wont ever power on
                            im not talking about power on with black screen
                            anyway the memory is inside.
                            i will try to get another charger in a couple
                            of hours and report back.
                            if it wont work i will open it back to check
                            bios voltages
                            • dj_ricoh
                              • 2073
                              its not a bad investment if you buy another bios from the web.
                              or maybe you got a spare one
                              • aknet_pc
                                • Dec 2013
                                • Türkiye
                                i have cq61.dc jacks light is on. but the computer doesn't work i think this problem is bios can you help me.please?
                                • PantherDave
                                  by PantherDave
                                  Hi all!
                                  05-29-2024, 02:01 PM
                                • GLISIT
                                  by GLISIT
                                  01-16-2025, 02:29 PM
                                • Mita99
                                  Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                                  by Mita99
                                  Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                                  Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                                  Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                                  04-27-2025, 07:20 PM
                                  by sam_sam_sam
                                  03-31-2024, 02:12 PM
