Macbook A1278 LCD backlight problem
  • salawayon
    • Nov 2012
    • 577
    • philippines
    Macbook a1278 unibody, aluminum body... 3.3vdc is present at pin 2, 3 and 4, both at lcd connector and at main board connector.... Tried already replacing the lcd.... I need schematics for this one. Or anyone could share some infos on this problem.
    Thanks....
  • cyberhack
    • Feb 2013
    • 466
    • Uk
    Re: Macbook A1278 LCD backlight problem
    here you go
    • salawayon
      • Nov 2012
      • 577
      • philippines
      Thanks... But it's not the same with the board... BTW, it is a non-pro model. And the WLED DRIVER (APP_1A) chip doesn't have an input voltage.... Fuse is ok.
      • cyberhack
        • Feb 2013
        • 466
        • Uk
        have a look at this link
        http://forums.macrumors.com/showthread.php?t=972699
        if not allowed please remove
        • salawayon
          • Nov 2012
          • 577
          • philippines
          i've been reading that pages before i posted here for schematics.... i still didn't get the right schematics.... i'm on page 32 already...
          • salawayon
            • Nov 2012
            • 577
            • philippines
            anyone could share? Macbook 13" unibody, aluminun case, non-pro version, schemaitcs is needed.
            Thanks...
            • spidey
              climbs
              • Dec 2012
              • 644
              • Cyprus
              to get the right schematic you must supply the board code like 820-2530.
              • salawayon
                • Nov 2012
                • 577
                • philippines
                Motherboard model: 820-2327-A
                Thanks....
                • spidey
                  climbs
                  • Dec 2012
                  • 644
                  • Cyprus
                  here it is.
                  • mamoime
                    • Apr 2014
                    Originally posted by cyberhack
                    here you go
                    Where can I download .brd files of other macbook mainboard to use with this software viewer?
                    Many thanks in advance
                    • dspok
                      • Jan 2014
                      • 553
                      • Nepal
                      @salawayon
                      did you fixed it.
                      I have same problem. I want to figure out the location of LCD Backlight Driver.
                      Can anybody tell the exact location please.
                      • dellxps15
                        • Feb 2014
                        • 1596
                        • italy
                        what is macbook model ? 820-xxxx
                        • dspok
                          • Jan 2014
                          • 553
                          • Nepal
                          @dellxps
                          I found it & measured 12.44v for backlight. Is it normal?
                          Can see apple logo but still no backlight.
                          • dellxps15
                            • Feb 2014
                            • 1596
                            • italy
                            edit: ok we are talking about a a1278.
                            edit2: 12.5volt on backlight fuse are ok. if you can try another lcd, and inspect if lcd cable is all ok.
                            • Macman1974
                              • Jun 2015
                              Here you go hope this helps.
                              • BCConnectionLLC
                                • May 2015
                                • 47
                                Get everything in one post
                                At the LVDS you have 12v on the PPVOUT_S0_LCDBKLT line?
                                IF YES
                                Sounds like your boost circuit isnt working
                                Start looking at U9701
                                What do you have on Pin 1, 2, and 3?
                                • saifi
                                  • Feb 2015
                                  • india
                                  thanksssss
                                  • Comp_Pro
                                    No Backlight Macbook A1990 820-01041
                                    by Comp_Pro
                                    Hello all,
                                    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                    Tests performed:
                                    There is no backlight even with a good screen.
                                    Backlight IC is receiving the correct support voltages.
                                    Fuse F8400 ok
                                    Current sense resistor R8400 ok
                                    Backlight IC is receiving 3.3V on enable pin.
                                    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                    Backlight IC receiving 5V from PP5V_G3S
                                    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                    05-06-2024, 10:23 PM
                                  • rounin
                                    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                    by rounin
                                    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                    🛠 Original Issue
                                    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                    04-19-2025, 01:18 AM
                                  • psdavid65
                                    Macbook Air A1466 820-3437-B Booting Problem
                                    by psdavid65
                                    I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                                    06-20-2024, 12:27 AM
                                  • Rezendes
                                    Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                                    by Rezendes
                                    Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                                    I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                                    The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                                    05-10-2024, 02:18 PM
                                  • pcbmaniac
                                    MacBook A1278 (3115) No PPBUS_G3H Issue
                                    by pcbmaniac
                                    Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                                    I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                                    1. U7000 Measurements:
                                      • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                                    2. Resistors:
                                      • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                                    Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                                    • If I also decide to replace the SMC, do I need to order it pre-programmed,
                                    12-02-2024, 04:12 PM
