How to replace nec/tokin OE128 in laptop motherboard?
  • selldoor
    Slow Learner
    • 7870
    #61
    Re: How to replace nec/tokin OE128 in laptop motherboard?
    Post a picture so we can see what you have done.
    • spleenharvester
      • Mar 2010
      • 921
      As above. Also:
      1) Use a multimeter to check for shorts between your positive side and ground. Set it to 200ohms and place one lead on the positive side and one lead on the negative side.
      2) Did you remove that NEC Tokin? In its current melted state it could be shorted.
      3) Check your polarity.
      4) Did you test it after the NEC Tokin was melted in the first place?
      It's possible one of the caps you added are shorted or that there is a bridge between the two sides.
      Best of luck!
      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
      • hitmen
        • Oct 2013
        • 79
        • Pakistan
        #63
        Originally posted by spleenharvester
        As above. Also:
        Best of luck!
        Yes, I removed nec tokin.
        Yes, I checked polarity.
        May be it is shorted. Becoz using multimeter, when i placed one lead on +ev and one on -ev side, it show zero ohm resistence.
        But how i identify which cap is short?
        • spleenharvester
          • Mar 2010
          • 921
          We need a picture really buddy. Did you solder the caps over where NEC tokin was or on the surrounding pads?
          That short will almost definitely be your problem. If you soldered over the Tokin, check for bridges between the two conductive strips on each side. If you didn't, remove the caps one by one and check for shorts each time.
          • hitmen
            • Oct 2013
            • 79
            • Pakistan
            #65
            Is this idea right? I want to remove all caps and sold 4 wires 2 one side and 2 other side. On these wires i check caps 4 by 4.
            • hitmen
              • Oct 2013
              • 79
              • Pakistan
              #66
              note. One thing is more that i dont set the leads of lcd and inverter when i checking. I want to see that fans or hdd run or not. I think, If they run, it will be ok.?
              Is this matter or not??
              • hitmen
                • Oct 2013
                • 79
                • Pakistan
                #67
                I see, there is a lettel diode between + and -. U can see in this pic.
                I think if it burnt or short? Can i remove it?
                There are 4 lines under nec tokin 2 +ev -ev and 2 -ev +ev, And i identified that 2 internal lines r -ev and this is same for both side and 2 external external lines r +ev which is different for both sides. I identified that 2 infra lines r not short but 2 ultra lines r seemed to short and lettel diode is there between + and- which i mentioned above.
                Is this matter????
                • hitmen
                  • Oct 2013
                  • 79
                  • Pakistan
                  #68
                  im waiting for ur replies and my laptop is opened and my work is still stop for ur best suggestion.
                  Please please. . .
                  • hitmen
                    • Oct 2013
                    • 79
                    • Pakistan
                    #69
                    I found a new thing about my problem is that, in my laptop nec tokin was near the processor and other side the PCB, when i removed processor, there is no shortness in both pair of lines where was nec tokin and multimeter show 400 resistence in the lines but when i putt processor then one pair of line which lower and more near the processor is short and multimeter show zero resistence in the lines.
                    What is reason of that????
                    Please please help me experts. . .
                    I am waiting thirstily. . . .
                    • rievax_60
                      • May 2012
                      • 897
                      • australia
                      #70
                      It is normal for the CPU to measure a few ohms like 5 ohms.
                      • hitmen
                        • Oct 2013
                        • 79
                        • Pakistan
                        #71
                        Then what is problem.
                        Please read my whole thread.
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          #72
                          You say you have removed the NEC/TOKIN capacitor. Are the pads for the outer 2 strips connected to each other?
                          Send another picture so we can see what has been done.
                          • hitmen
                            • Oct 2013
                            • 79
                            • Pakistan
                            #73
                            Yes, i removed nec tokin.
                            No, outer + lines r not connected each other but inner - lines r already same for both. I will try to upload pic.
                            What i do now??
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              #74
                              What i do now??
                              It seems that the NEC/TOKEN capacitor is being used as "Filter circuit design"
                              It is explained here,
                              Take a look at the PDF so you will understand.
                              • hitmen
                                • Oct 2013
                                • 79
                                • Pakistan
                                #75
                                Is i have to connect 2 outres strips also??
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  #76
                                  Yes, I think so but first take note of which side goes to the CPU. It will measure low resistance to ground with the CPU installed.
                                  • hitmen
                                    • Oct 2013
                                    • 79
                                    • Pakistan
                                    #77
                                    Thanks for ur swift reply.
                                    Okay i m trying this. . . . .
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      #78
                                      You will need to add extra capacitors of the correct type to replace the NEC/TOKIN capacitor. Are you going to do this?
                                      • hitmen
                                        • Oct 2013
                                        • 79
                                        • Pakistan
                                        #79
                                        Perhaps u dont read my whole thread????
                                        Please read it.
                                        Then i will tell u that which type of combinations of caps i already checked. Please. . . .
                                        • hitmen
                                          • Oct 2013
                                          • 79
                                          • Pakistan
                                          #80
                                          I tried these combination
                                          5*220uf,4v.
                                          6*220uf,4v.
                                          3*330uf,2.5v+1*220uf,4v.
                                          3*22uf,4v+2*330uf,2.5v.
                                          2*330uf,20v+2*220uf,2.5v.
                                          But nothing.
                                          By do all this, when i press power button, indicators light up for one time and off, no fans , no hdd run. Laptop looking like to died.
                                          • acedogblast
                                            by acedogblast
                                            11-02-2024, 05:13 PM
                                          • Geeker007
                                            Friend messed up my laptop motherboard while working on my bench
                                            by Geeker007
                                            Hi All,
                                            So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                                            So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                                            I have not tried putting...
                                            06-16-2025, 01:40 PM
                                          • Username338
                                            Laptop BA92-09470B motherboard schematics
                                            by Username338
                                            Thank you for deciding to read this topic!
                                            Laptop: NP700Z3A-S02RU
                                            Motherboard: BA92-09470B
                                            I was trying to fix my old laptop that has stopped displaying image a long time ago. It boots up, lights light up, fan spins but no image. Conned it to TV by HDMI cable, but it was unsuccessful. Components look intact, no water damage/corrosion on the board.
                                            I don't really value this laptop too much, so I wanted to ask anyone for a schematic/boardview file or anything that describes motherboard in a simillar faison. I want to experience a challenge of figuring...
                                            03-09-2025, 03:52 PM
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
