today i change one dell latitude d430 lcd but the brightness is not same like orignal one any idea how to make it
dell lcd brightness problem
Re: dell lcd brightness problem
Sometimes if your connection cable for the LCD display is not plugged in tightly enough it can cause a dim display. Recheck your connection. Also, try adjusting the display contrast to the brightest setting. Disable any ambient sensor if equipped.Comment
actually dell laptops only support the lcds which comes with inverter and specially made for dell .i think by changing the bios or fermwire chip on lcd can solve this issue.any one can point out the location of that chipComment
what about measurements ? vin, brigthness and on/off =? i think you have vin = 19v and on/off ? 3.3 but dont have brightness signal, chek with schematics and if you dont have the brightness then solder a wire from nearest 3.3v.Comment
by toti24dell precision m4600 laptop
i7 2760qm
8gb ram 750gb HDD
intel hd 3000 integraded and nvidia quadro 2000m
pleasea bear with me english isnt my language and ill try to be as clear as possible
note i live in mexico in a very small town..
thank you.
laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
the brick happened when i was installing win 10 using usb.
used rufus and officia microsoft.iso
it finished copying files from usb...-
Channel: BIOS Requests ONLY!
by SDNarciaHello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
As additional information,... -
by Achille15Hello everyone,
so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be... -
by eltunisiei have dell insprion 3521
hdmi port it can good work but now not disply alot of screen and i used convert hdmi to vga but not work
i tray
windows 7, windows 10, orginal vga drivers from dell, update bios
i found 5v on th e socket
what a problem?...Yesterday, 06:24 AM -
by sartoHi everybody. I have a Getac S410 G1 with a screen brightness witch cannot be adjusted. It is at full brightness when the charger is plugged in (19V on the LCD connector) and at minimum under battery (12V on the LCD connector). Does anyone know where the problem is coming from ? Thank you.
- Loading...
