dell lcd brightness problem
  • alihomee
    • Dec 2012
    • 1580
    • malaysia
    today i change one dell latitude d430 lcd but the brightness is not same like orignal one any idea how to make it
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: dell lcd brightness problem
    try another
    • Techn0pro
      • Oct 2013
      Sometimes if your connection cable for the LCD display is not plugged in tightly enough it can cause a dim display. Recheck your connection. Also, try adjusting the display contrast to the brightest setting. Disable any ambient sensor if equipped.
      • masud
        • Jul 2011
        • 317
        • Bangladesh
        i faced the same problem. i had to replace with another dell latitude lcd. then only it fixed. i tried on changing the ccfl tube but no result.
        • alihomee
          • Dec 2012
          • 1580
          • malaysia
          actually dell laptops only support the lcds which comes with inverter and specially made for dell .i think by changing the bios or fermwire chip on lcd can solve this issue.any one can point out the location of that chip
          • Kiriakos GR
            Banned
            • May 2012
            • 940
            • Greece
            No shit ? Shame to Dell about making your life hard.
            • spidey
              climbs
              • Dec 2012
              • 644
              • Cyprus
              what about measurements ? vin, brigthness and on/off =? i think you have vin = 19v and on/off ? 3.3 but dont have brightness signal, chek with schematics and if you dont have the brightness then solder a wire from nearest 3.3v.
              • dycc
                Vision
                • Nov 2011
                • 625
                • Côte d'Ivoire
                disconnect the brightness pin first from the connector before solder a wire from nearest 3.3v on it . do this to avoid return current on the board .
                • dycc
                  Vision
                  • Nov 2011
                  • 625
                  • Côte d'Ivoire
                  agree to spidey . LCD screen with LVDS connector is a standard .
                  only Vin , on/off and brightness signals are necessary to light up the screen
                  • toti24
                    (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
                    by toti24
                    dell precision m4600 laptop
                    i7 2760qm
                    8gb ram 750gb HDD
                    intel hd 3000 integraded and nvidia quadro 2000m
                    pleasea bear with me english isnt my language and ill try to be as clear as possible
                    note i live in mexico in a very small town..
                    thank you.
                    laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
                    the brick happened when i was installing win 10 using usb.
                    used rufus and officia microsoft.iso
                    it finished copying files from usb...
                    03-06-2022, 08:39 PM
                  • SDNarcia
                    Dell 15R-5521 keyboard problem (KBC?)
                    by SDNarcia
                    Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                    As additional information,...
                    07-20-2024, 10:47 PM
                  • Achille15
                    Dell N5110 problem
                    by Achille15
                    so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
                    03-29-2025, 04:41 PM
                  • sarto
                    GETAC S410 G1 brightness problem
                    by sarto
                    Hi everybody. I have a Getac S410 G1 with a screen brightness witch cannot be adjusted. It is at full brightness when the charger is plugged in (19V on the LCD connector) and at minimum under battery (12V on the LCD connector). Does anyone know where the problem is coming from ? Thank you.
                    03-08-2025, 04:30 AM
                  • masoksian
                    Dell latitude e7470 not turn on .power buton on off and Run Power problem
                    by masoksian
                    I am dealing with the problem of turning on and off my Dell e7470 notebook.
                    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                    The system does not turn on, there is no post.
                    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                    The problem continues in the same way.
                    I tried to turn on the Fn key, nothing came to the screen....
                    02-15-2025, 12:08 PM
