Asus U57A Backlight Fuse on Motherboard
  • Rolin
    • Apr 2007
    • 174
    I have an Asus U57A laptop that would not turn on - completely dead. I troubleshot and found the LCD cable was causing the problem (pretty unusual) - it appeared the cable was kinked and most likely shorting out the motherboard. I ordered another cable and the laptop now turns on, but no display - OK on external monitor though - so now I suspect the backlight is out, and I'm suspecting the shorted cable blew the backlight fuse on the motherboard.
    But I don't see any fuses around the LCD connector. Here's a pic of the area, can anyone help me find the fuse?
    BTW: The motherboard is printed with K55VD part number.
  • jetadm123
    • 2169
    Re: Asus U57A Backlight Fuse on Motherboard
    The fuse might be on the circuit board mounted inside the LCD panel.
    • Rolin
      • Apr 2007
      • 174
      Thanks for the reply. I know about the fuse on the back of the panel and I should probably check it, but I swapped another screen I have (cracked, but backlight works) and it still fails. The fact that the entire motherboard/laptop was dead when the original faulty LCD cable was connected (even when I disconnected it from the screen!) concerns me that some damage to the motherboard occured. Again, after replacing the cable the computer fires up properly on an external monitor. It is possible the new LCD cable is faulty, but I would like to check any obvious things (like fuses) before I consider ordering another cable. Can you see any fuses on the picture I uploaded??
      • trebo
        • 514
        • Wales, UK
        no fuses in photo
        • Rolin
          • Apr 2007
          • 174
          I guess that's why I didn't see any fuses either...
          I just uploaded a picture of the complete front and back of board. Maybe that will help.
          I thought there was always a fuse on the motherboard for the newer LED backlight screens. I've had to replace a couple in the past on other boards, but this one I just cannot find. If it's not a fuse, then I guess it must be another component that blew with the shorted LCD cable. But an easy fuse is always preferred!
          Let me know if you need a zoomed in shot of a particular area.
          • dj_ricoh
            • 2073
            i think you will have to give a ultimatum in this case.
            1.your board and you need to make it for yourself then you will take all the components near the connector and try to go backwards to find the problem and the purpose of each component.
            2.others board you need to tell him that its time wasting and you will not make any progress very fast identifying each comp. fast; needs a new board.
            • alihomee
              • Dec 2012
              • 1577
              • malaysia
              can u see the picture on the lcd
              • Rolin
                • Apr 2007
                • 174
                Not really, it's too dark. I suppose the shorted LCD cable could have blown something other than a fuse. Again, works great on external monitor. Since I don't see any fuse related to the backlight on the motherboard - I guess it's time to look for something else.
                Does anyone know if there's a schematic available for this board? I'm lousy at component level troubleshooting, but I'd be up for it if someone wants to help a bit. With the help of some of the members in the past, I've been able to repair a few monitors and a couple of motherboards - I learned a lot and really enjoyed the challenge. How complicated is the motherboard backlight circuit on this board?
                • sebulica
                  Beginner
                  • Mar 2014
                  • 50
                  • Romania
                  apparently the bios is the problem.sorry for "Reviving" the thread but maybe someone will need the info
                  • glovecaps
                    Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                    by glovecaps
                    I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                    My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                    The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                    11-25-2024, 04:23 PM
                  • dhenion
                    Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                    by dhenion
                    I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                    The original board was:
                    ASUS X510UNR REV 3.0 A
                    The replacement board is:
                    ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                    It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                    01-30-2024, 01:45 PM
                    ASUS P5GC-MX motherboard recap
                    by momaka
                    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                    So here is what the motherboard looked like with its original caps:
                    CPU VRM area up close…...
                    01-27-2021, 11:59 PM
                  • ktmmotocross
                    Asus G513QE keyboard and backlight not working
                    by ktmmotocross
                    Have this Asus G513QE with keyboard, keyboard backlight and Led backlight not working. other works ok.
                    i measure all voltages ok on keyboard, KB backlight and Led backlight. looks like a kbc error.
                    but as laptop works i think it cannot be bad. maybe its FW. have anybody some hint for this?
                    08-08-2025, 06:29 AM
                  • MakNCheese
                    ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                    by MakNCheese
                    I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                    Symptoms:
                    • Severe lag across the system, including BIOS navigation.
                    • Slow boot times and unresponsive performance in Windows.
                    • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                    • No error messages or BSODs, just extreme sluggishness.
                    What I've Tried:
                    • Replaced
                    06-04-2025, 12:48 AM
