Asus X53U: Instantly Cuts Off
Re: Asus X53U: Instantly Cuts Off
When you say pin 2 is short, are you saying short= zero ohms?
If there are more than 1 ohm, then 99 per cent sure the circuit is good.
These low ohms is due to the high amperage the circuit eats.Comment
No. I mean when tested to ground.
Last edited by speedypro; 07-19-2013, 05:14 AM.Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails DeveloperComment
To partially wrap things up, I have removed the CPU, since that is the APU. On removing and testing the + side of the cap (PC218) or PL202 to ground, there is no more sort so it's clear that a reball of the CPU is needed. I'll confirm within two weeks as we need the EME450GBB22GV reballing stencil from e-best.
When I say short, I mean setting the multimeter to diode or continuous; like testing a fuse.
Many thanks for all the effort and support guys.Last edited by speedypro; 07-19-2013, 10:25 AM.Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails DeveloperComment
When I say short, I mean setting the multimeter to diode or continuous; like testing a fuse.Comment
I did set it to ohms setting and it read 0.2 ohms. I haven't tested in ohms setting while cpu chip was off. I'll see what it reads tomorrow at work.Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails DeveloperComment
While cpu chip is still off, all coils now have high values in Ω so it's perfectly clear that the cpu was the culprit. I'll update when I receive the stencil for the reball.Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails DeveloperComment
Measure all caps on top of the APU chip before attempting to reball it, the chip could be dead. If any read short (under 1 ohm), the chip is busted.
I used to have one of those APUs on my keychain until it broke and fell off - it was dead short. Came from a Sony Vaio that took a very heavy fall, and there was no plastic foil between the sides of the chip. Due to the impact, the heatsink hit the caps and shorted them out while the laptop was running, and killed the chip.Last edited by Th3_uN1Qu3; 07-21-2013, 08:19 AM.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
I used to have one of those APUs on my keychain until it broke and fell off - it was dead short. Came from a Sony Vaio that took a very heavy fall, and there was no plastic foil between the sides of the chip. Due to the impact, the heatsink hit the caps and shorted them out while the laptop was running, and killed the chip.Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails DeveloperComment
by MakNCheeseHi everyone,
I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
Symptoms:- Severe lag across the system, including BIOS navigation.
- Slow boot times and unresponsive performance in Windows.
- Battery charges very slowly (e.g., ~5% in 2–3 hours).
- No error messages or BSODs, just extreme sluggishness.
What I've Tried:- Replaced
by lukkihapsiAsus Vivobook X515JA Laptop
Issue :
Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
Tried :
Cleaned inside for dust, applied fresh thermal paste. No Change!
Removed keyboard, Trackpad, fingerprint sensor. No Change!
Removed Internal SSD. No Change!
Updated BIOS to latest version. No Change!
Removed battery and pressing power button for 1 minute. No Change!
Weird Part :
Upon turning laptop ON, screen lights up - stays black,
I... -
by ZixuTechHey guys, I got this model which stays black screen but CPU heats up. All voltages on board seems oK.
Perhaps BIOS issue?
Brand: Asus
Model: F1502Z
SN: R4N0CV11S622169
Board: X1403ZA 2.2
I have flashed this BIOS for test purposes and it lights up the ASUS but blank SN. https://www.badcaps.net/forum/troubl...21#post3593121
Can you clean and enter SN for me please....-
Channel: BIOS Requests ONLY!
by mkdjHello everyone,
Mark and model: ASUS X571
Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
Tests already made:
- Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
- I have removed... -
by SafioHello
My asus rog strix g15 g512 keeps repeating the "Republic of Gamers" animation and won't power on. Anyone know what could be wrong with it?
i tried to install new system on it but it is same issue , does the same thing when i try to boot from usb or externals hard drive, flashed bios still same issue , if its a hardawre issue please share your experience
thank you
06-08-2024, 08:43 PM - Loading...
