ASUS PRIME B450 PLUS (rev 1.02) USB Overcurrent issue
  • ezenia
    • Jun 2020
    • 58
    • England
    So I bought a faulty ASUS PRIME B450 PLUS motherboard off eBay. They said it was water damaged and they cleaned it. The PC POSTs and displays a message that it's detected USB overcurrent and will shut off in 15 seconds. I verified this myself. So I did some checks at the ATX connector 1st to see if the resistance readings looked OK. I found the 3.3V rail measures just 179Ohms which seems way too low. It's been much higher on other AM4 boards I've worked on.
    So I did some Googling to see what the potential culprits are. It varies from bad protection diodes, bad ports or even the PCH. I went to the protection diodes (they are SOT23-6) and measured the resistances on the legs against GND. All looked OK, but one. One was reading close to the Ohms I was seeing on the 3.3V rail. I attached an image of the 2 readings on the chip:
    So I removed it to see if that changed anything. Unfortunately not, the resistance readings remain the same. It seems like only one port is affected. I checked the pins on the USB port at the back of the board, on 2 of the pins for one port, I get the same low ohm reading. On the other port, I don't see the same low ohm reading. The ports are USB 3.1 Gen 2. They're light blue.
    Before going further with this repair, I'd like to know if this issue is perhaps being caused by the PCH since the 3.3V rail is also reading low ohms. If it is the PCH, then there's not much I can do about that. If it's not the PCH, then I can continue to find where the issue is.
    Appreciate any help on this. It would've been nice if I had a boardview for this board, but couldn't find one (I've requested it in the appropriate section).
  • wisjg
    • Oct 2025
    • 3
    • China
    U74LVC1G86G
    • almirsilvestre
      ASUS PRIME B450 PLUS REV:1.02 bios
      by almirsilvestre
      Hi guys... Does anyone have the BIOS for the motherboard: ASUS PRIME B450 PLUS REV:1.02 If it is working... Because on the Asus website the file exceeds the chip's capacity.
      Thank you very much....
      04-22-2025, 04:58 PM
    • karlp028
      ASUS Prime Z390-A not starting up - possible issue with PCH
      by karlp028
      I'm working on an ASUS Prime Z390-A that isn't reacting to the power button. All of the standby voltages and signals are good. The PCH is receiving O_PWRBTN#, but it is not de-asserting SLP_S3#, SLP_S4#, or SLP_S5#. I started probing around and noticed the voltage on RTCX2 is around 1.5V, which seems crazy high. On RTCX1 it is around 300mV, which is normal. I don't see any waveform either. When the PCH is not powered, the resistance on RTCX1 is about 2.5M ohms and on RTCX2 it's about 8.5M ohms. When the PCH is powered on, RTCX1 shows about 7M ohms and RTCX2 shows OL.
      I suspect the...
      07-17-2025, 06:31 PM
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
      by rounin
      🛠 Original Issue
      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • ugamazing
      by ugamazing
      12-17-2024, 07:05 PM
    • Yolofolkss
      Asus X99-pro/usb 3.1 Usb overcurrent device reoccurring issue
      by Yolofolkss
      Hi this is a really odd case.
      I have removed all of the esd ic for USB 3.0 and 2.0
      I measured all of the data lines and 5v usb voltage lines there are no shorts
      all of the USB ports have no damage
      Clearing the bios using the jumper wont help.
      it is still showing USB overcurrent device
      the only temporary fix I've tried and worked so far is flashing the bios
      and the error is gone
      but when you start the motherboard with a USB device still attached
      the USB over current device error is back. the bios needs to be externally flashed...
      01-09-2023, 04:21 AM
