Asus X53U: Instantly Cuts Off
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    Yet another laptop that cuts off as the power button is pressed.
    When you press the power button, its led is lit and after 2-3 seconds the laptop cuts out. Same issue with and without battery. Also same issue when the MM is out of the laptop's housing. Any tips on where to look?
    Regards
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    Re: Asus X53U: Instantly Cuts Off
    Just did a reball of the gpu and same issue. Just though a ball maybe grounding as this sort of issue is the same with most hp I have worked with. But wondering if the cpu needs reballing.
    • spidey
      climbs
      • Dec 2012
      • 644
      • Cyprus
      Check coils for a short.
      • speedypro
        • Feb 2013
        • 561
        • United Kingdom
        Yes. Thanks for the tip. Totally forgot about coils. So far two are shorted. See images:
        PL303:
        PL202:
        Any replacements around?
        • Francisco.s
          • 686
          • Spain
          Are you asking for coil replacement?
          How many ohms can you measure between coils and GND?
          • speedypro
            • Feb 2013
            • 561
            • United Kingdom
            Yes.
            PL202: 14.5 ohms
            PL303: 67.2 ohms
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              you need a ringer to test these for shorts.your ohmmeter will not spot 1 shorted turn.
              • speedypro
                • Feb 2013
                • 561
                • United Kingdom
                Many thanks for your support. How to locate these Ringer Testers? Any brand names?
                • jpdo
                  • Jul 2013
                  • 23
                  • Portugal
                  I have the same problem but in one toshiba, and i dont know the problem.
                  You try clean the logic board?
                  • fddizon
                    • Sep 2011
                    • 555
                    • Philippines
                    testing for shorts with reference to ground, does not mean a coil is shorted. 14 ohms is not shorted for me. you can isolate those coils from mobo, to determine which side of the coil has short. someone told me capacitors near the coils are the most common parts to fail. i see electrolytic caps, make some tests.
                    • speedypro
                      • Feb 2013
                      • 561
                      • United Kingdom
                      Originally posted by fddizon
                      ...someone told me capacitors near the coils are the most common parts to fail. i see electrolytic caps, make some tests.
                      Ok. I'll see what I can find and report back.
                      • speedypro
                        • Feb 2013
                        • 561
                        • United Kingdom
                        I have done another test. This cap beside the coil in red:
                        ...that tested at a very microfarad, 11uf; while others, same, are 200+uf. Could that be an issue?
                        • speedypro
                          • Feb 2013
                          • 561
                          • United Kingdom
                          I have removed the cap beside this coil. However, I get a short to ground on both sides of this coil. Does this means the coil is bad?
                          • DJduck
                            • Dec 2012
                            • 229
                            • Estonia
                            Replace it just in case it is bad
                            I can put text here?!
                            • speedypro
                              • Feb 2013
                              • 561
                              • United Kingdom
                              Ok but I have never bought those coils before. Searching with the number on the coils give me no information.
                              • fddizon
                                • Sep 2011
                                • 555
                                • Philippines
                                Nope. You need to remove the coil to determine which side of the pads has the short.
                                if one side is shorted to ground, check the parts connected to that line.
                                removing each part at a time and testing to ground after each removal. just remember to put back parts on the same spot and in correct orientation.
                                • speedypro
                                  • Feb 2013
                                  • 561
                                  • United Kingdom
                                  Thanks! Good tip. Based on the schematic, PL202 (pin 2) is connected to the cap (PC218) and +APU_CORE_NB. The cap was removed and same thing. What is this "+APU_CORE_NB"?
                                  • fddizon
                                    • Sep 2011
                                    • 555
                                    • Philippines
                                    speedypro,
                                    have you remove the coil to test which side is shorted?
                                    • speedypro
                                      • Feb 2013
                                      • 561
                                      • United Kingdom
                                      speedypro,
                                      Yes. While coil is off, pin 2 is short, that's the same connection (pin) where the +caps is on.
                                      See image PL202 and PC218:
                                      Also short is the cap's - and +. (Cap is removed)
                                      • fddizon
                                        • Sep 2011
                                        • 555
                                        • Philippines
                                        check pc222 and all caps along that line... doyou see it? pc222 line going down maybe more parts along that line
                                        can u post the schematic?
                                        • MakNCheese
                                          ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                                          by MakNCheese
                                          I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                                          Symptoms:
                                          • Severe lag across the system, including BIOS navigation.
                                          • Slow boot times and unresponsive performance in Windows.
                                          • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                                          • No error messages or BSODs, just extreme sluggishness.
                                          What I've Tried:
                                          • Replaced
                                          06-04-2025, 12:48 AM
                                        • lukkihapsi
                                          Asus Vivobook X515JA Weird Boot Issue
                                          by lukkihapsi
                                          Asus Vivobook X515JA Laptop
                                          Issue :
                                          Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                                          Tried :
                                          Cleaned inside for dust, applied fresh thermal paste. No Change!
                                          Removed keyboard, Trackpad, fingerprint sensor. No Change!
                                          Removed Internal SSD. No Change!
                                          Updated BIOS to latest version. No Change!
                                          Removed battery and pressing power button for 1 minute. No Change!
                                          Weird Part :
                                          Upon turning laptop ON, screen lights up - stays black,
                                          I...
                                          07-07-2025, 12:07 PM
                                        • ZixuTech
                                          Asus F1502Z BIOS issue? CPU gets hot but no other response. No blinking light
                                          by ZixuTech
                                          Hey guys, I got this model which stays black screen but CPU heats up. All voltages on board seems oK.
                                          Perhaps BIOS issue?
                                          Brand: Asus
                                          Model: F1502Z
                                          SN: R4N0CV11S622169
                                          Board: X1403ZA 2.2
                                          I have flashed this BIOS for test purposes and it lights up the ASUS but blank SN. https://www.badcaps.net/forum/troubl...21#post3593121
                                          Can you clean and enter SN for me please....
                                          03-31-2025, 05:04 PM
                                        • wishes2022
                                          ASUS UX3405CA bios issue(request)
                                          by wishes2022
                                          Hi buys,
                                          I have one ASUS ux3405ca bios file. but it can not extracted . I using extaract tools is AMI PFAT Extract,
                                          the tools is older version. ASUS Zenbook 14 UX3405CA, Core Ultra 9. me 18.1.15.2383
                                          can anyone help to share one extract tools ? bios from asus official website
                                          Thanks...
                                          08-10-2025, 10:36 PM
                                        • mkdj
                                          ASUS X571 no power : battery issue?
                                          by mkdj
                                          Mark and model: ASUS X571
                                          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                          Tests already made:
                                          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                          - I have removed...
                                          07-14-2025, 09:16 AM
