Presario CQ62 Dead Board Help
  • NTO7
    • Mar 2013
    • PHILIPPINES
    No lights on charging
    no power with charger and battery
    Anyone can give me schematic on this board?
    Last edited by kc8adu; 03-27-2013, 06:46 AM. Reason: facebook link crap.upload a good picture here for best results.
  • vvacl
    • Jun 2012
    • 22
    • VietNam
    Re: Presario CQ62 Dead Board Help
    What's the plate number of the motherboard?
    • scobie_21
      • Jul 2011
      • 144
      I had one the same a while ago was a faulty bios chip, even after reflashing and would fail verification. put new chip in and reflashed and was fine after that.
      • speedypro
        • Feb 2013
        • 561
        Where is this bios chip on the CQ62?
        Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
        • dycc
          Vision
          • Nov 2011
          • 625
          • Côte d'Ivoire
          Bios chip issue . Reflash the bios and all will be ok .
          • speedypro
            • Feb 2013
            • 561
            Hi. Where is the bios chip on the CQ62? Also you've attached a file but how to update the bios when there is no power?
            Regards
            • Francisco.s
              • 686
              • Spain
              Regards
              You need to de-solder the 8 pin chip and reprogram it with an external programmer.
              This link shows a cheaper programmer:
              http://www.ebay.es/itm/NANO-BIOS-Pro...-/270449469749
              • speedypro
                • Feb 2013
                • 561
                Thanks for that information, but where is the chip? Im using a Compaq CQ62.
                I could not find a schematic to locate it.
                • Francisco.s
                  • 686
                  • Spain
                  We don't know the model of your motherboard, I attach the schematic of the HP G62 COMPAQ PRESARIO CQ62 - QUANTA AX2_7 - REV 1A. (AMD cpu)
                  See page 32, chip U17. (MX25L1605DM2I-12G)
                  It is the one you should reprogram. (if motherboard is the correct one)
                  • speedypro
                    • Feb 2013
                    • 561
                    Thanks for your very help. Our model is Hp Compaq CQ62-220SA. We have found the Bios: Winbound 25q80bvsig. We've found a supplier with this chip already programmed; fingers crossed. We will update when part arrived and fitted.
                    • camelion
                      Banned
                      • May 2013
                      • 35
                      • safi
                      Good replay you flash chip
                      • speedypro
                        • Feb 2013
                        • 561
                        HI all. The German company messed about and customer is getting angry. I may go the other route by purchasing a bios programmer. Can this do the trick?
                        Also we have found this Russian page with the bios program. Will that work also?
                        Thanks.
                        BTW. Our CQ62 model is 220SA and motherboard number: AX35E.
                        • kev4eva
                          • Mar 2012
                          • 37
                          • jamaica
                          what company did you find the chip from that was already programmed?
                          • speedypro
                            • Feb 2013
                            • 561
                            This guy here. His website is rubbish. We had to ask for a refund.
                            • kev4eva
                              • Mar 2012
                              • 37
                              • jamaica
                              am looking a similar chip if i could get it already programmed from another seller that would be good
                              • speedypro
                                • Feb 2013
                                • 561
                                Hi. Our Nano Bios Programmer just arrived. Mounted the IC correctly and used your firmware but the cq62 is still dead. Our MM is a cq62-220sa. Name on MM is AX35E. Any other firmware to try?
                                • bazzbarro
                                  • Dec 2012
                                  • 25
                                  • kenya
                                  Hi speedypro did you manage to sort out this couze am experiencing the same thing you are expiriencing but have not replaced bios yet
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3628
                                    • slovakia
                                    of course is dead. charging must work even with bad bios.
                                    check charging and power circuit
                                    • tzoupkas
                                      • Jun 2014
                                      • 14
                                      • Greece
                                      Exactly as ktmmotocross said previously 5V and 3V are always on try to measure them first next all the others. A quick way to do it is by measuring the pins voltage at the battery adapter if no one in giving 3.3 V than the problem is somewhere else.
                                      • Melrin
                                        • Jun 2013
                                        • Czech republic
                                        Hi ,
                                        I have same bios issue as Speedypro, CQ62-220sa with M/B AX35E.
                                        Mainboard was totally dead, charging LED not lights.
                                        I have removed bad flash chip EON EN25F80 8mbit , and replaced by new
                                        flash chip programmed by F37 version.
                                        Now M/B is charging, LED lights, system is ON doing POST, but blank screen.
                                        POST is ending on POST code " C7 - Initialize notebook dock late."
                                        Any idea about this code, please ?
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • k370
                                          Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                                          by k370
                                          I have a NM-A321 board that is dead, with no power at all.
                                          When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                                          With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                                          • +3VALW
                                          • +5VAUX
                                          • 1.2VSUS_PWRGD
                                          • 3VALW_PGD
                                          • 1.05VAUX_PWRGD
                                          Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                                          The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                                          09-23-2024, 11:57 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • corrize
                                          Nikon D5 – dead, power board issue ?
                                          by corrize
                                          Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                                          When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                                          I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                                          Now, I try to understand how it works.
                                          There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                                          04-03-2023, 09:13 AM
                                        • Asraf Atb
                                          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                          by Asraf Atb
                                          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                          01-27-2025, 05:02 PM
