acer 2920 blinking power source
  • wideon
    • Feb 2013
    • 15
    • england
    acer 2920 blinking power source just flashing no power getting to main baord
    it just flashes the power suppier unit is connected and not getting voltage it gets like 3v then flashes and turns off
    laptop dose not start i can see the board has no water damaged
    its like a full short is there ant common caps that cause a short
    i have fully stripped the laptop and im guessing there bad caps somewhere in the board maybe someone has an any idea how how i can get this board running again
    please any info would be great
    just found this website looks a really cool site
    i know acers are bad for this but where to start ?
    also have checked all usb and stuff like for simple shorts
    as i said the board here in front of me and awaiting info
  • selldoor
    Slow Learner
    • 7870
    Re: acer 2920 blinking power source
    Better - anyway have you tested the power supply.
    (output voltage with load)
    Have you tested the laptop with another supply.
    • wideon
      • Feb 2013
      • 15
      • england
      i have tested with a another power surpire and same results
      19v strong on the muilt voltage belkin muilt power suppire i use as a tester
      • selldoor
        Slow Learner
        • 7870
        I know very little about laptops- is it totally dead - no lights -no fan.
        have you tried with no ram {unless fixed) no hard drive.
        Did you try continuity (ohms test) around the power socket to see if it has become detached.
        Most people start at the power in socket and trace voltage if any.
        A good clear picture of the area around the socket might help.
        Hopefully someone having practical experience of acers will be able to help
        • wideon
          • Feb 2013
          • 15
          • england
          that's what i am hoping yes i everything with everything removed and the same
          i need a acer expert to help
          impossible to trace the power as it flicks on and off so to trace the power is impossible really it has to be shorted
          • selldoor
            Slow Learner
            • 7870
            How about the picture? - Is english not your first language?
            • wideon
              • Feb 2013
              • 15
              • england
              picture of what
              yes English is my first language
              but my spelling is very bad
              • selldoor
                Slow Learner
                • 7870
                "A good clear picture of the area around the socket might help." - post4
                Ok had to ask, then allowance can be made - read through what you type before you post it. "yes i everything with everything removed" means nothing - remember the people helping may not be able to decipher what you mean and will just give up.
                English may not be the first language of a number of our laptop experts.
                • wideon
                  • Feb 2013
                  • 15
                  • england
                  here is a picture as requested
                  the 2 red ringed ic are getting very hot when power supply is added
                  board is empty nothing attached like cpu , memory nothing
                  there marked u2 and u3 dose anyone have any idea what there used for and can this ic cause a short ..... i.e flashing power supply on and off
                  think there called mosfet but have no idea as cant see the print on the ic
                  anyone have a idea what thay are called and will that cause this problem
                  • selldoor
                    Slow Learner
                    • 7870
                    They look like mosfets - we will need to know the part number off them to check.
                    The smaller black rectangular component at D1 is a diode and q1 looks like a small switching transistor ( What is its part number)
                    The diode you can test - NO Power to the board meter on ohms 2000 test with leads on one way and record the result then swap the leads over and record the result.
                    If your meter has Diode test you can do the same test using that - tell us which you have done. I am shutting off now but its soon evening in the US.
                    • wideon
                      • Feb 2013
                      • 15
                      • england
                      ok when are you back online as i really need to get this sorted
                      is on the mofsets
                      p2003evg
                      • wideon
                        • Feb 2013
                        • 15
                        • england
                        2000k ohms one way 301 other way 299 readings
                        on diode
                        • wideon
                          • Feb 2013
                          • 15
                          • england
                          i found this too is a schematic for my noard is anyone can help me out
                          acer_aspire_2920_-_wistron_calado.pdf
                          • wideon
                            • Feb 2013
                            • 15
                            • england
                            but i see U2 in there but no U3 would i have to repace both of these as thay both are getting very hot
                            • fddizon
                              • Sep 2011
                              • 555
                              • Philippines
                              I want to help but i need to know first what is your skill in using your tester. Do you know how to test a component?
                              Does your tester has diode tester with sound?
                              • wideon
                                • Feb 2013
                                • 15
                                • england
                                yes it has that please advice
                                • wideon
                                  • Feb 2013
                                  • 15
                                  • england
                                  ok as advised i removed U2 and now there power getting in to the board 19v so i just need to replace that any idea where i can get one or can i get one from a old laptop as there no stock based in the uk
                                  • dj_ricoh
                                    • 2073
                                    hello
                                    that U2 its a P-Channel transistor 30v from that schematics you putt here.
                                    but the schematics did not show the u3.
                                    you can search the web for similar transistor from another motherboard and replace it but you need to put the same.
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      Here is a link to the datasheet
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        They are available at ebay but china so 4-5 weeks delay
                                        http://www.ebay.co.uk/itm/5PCs-NIKOS...item4ac05868df
                                        This may be a suitable alternative you need to compare the data sheets also make sure physical size will fit.
                                        http://uk.farnell.com/international-...so8/dp/1857354
                                        https://cdn.badcaps-static.com/pdfs/...9064ed45bf.pdf
                                        Also at RS
                                        http://uk.rs-online.com/web/p/mosfet...633D424F544826
                                        As you didnt bother to say where you are in the England I dont know if there are any trade counters near you
                                        First you should test off the board.
                                        That diode does not look correct - read up on testing diodes.IT may be that only the diode is shorted and not the mosfet.
