Hi.Motherboard is DV6 UT35UMADDR3. There was water damage so i checked and found out that PU5 and PQ4 was burnt so i replaced both and laptop is now working.The problem now is that the moment battery or adaptor is inserted the touch panel lights up together with HDD LED(amber light) without power switch being pressed, but the screen stays dark.(I noticed that the screen lights up together with panel and HDD LED when SPI EEPROM is removed from the board but when SPI EEPROM is on board the screen stays dark).I have cleaned the whole board with solvent.The board powers up fine but when it is powered off the panel LEDs and HDD LED (amber light) stay on which drains battery.Any help will be appreciated.Thanks.
DV6 QUANTA UT3 Touch Panel LEDs always on
Re: DV6 QUANTA UT3 Touch Panel LEDs always on
when you turn it off and it does that use your dmm to trace what is all getting power still, sounds like a controller chip somewhere is bad and stuck on, and it will read short when no power at all...Hi.Motherboard is DV6 UT35UMADDR3. There was water damage so i checked and found out that PU5 and PQ4 was burnt so i replaced both and laptop is now working.The problem now is that the moment battery or adaptor is inserted the touch panel lights up together with HDD LED(amber light) without power switch being pressed, but the screen stays dark.(I noticed that the screen lights up together with panel and HDD LED when SPI EEPROM is removed from the board but when SPI EEPROM is on board the screen stays dark).I have cleaned the whole board with solvent.The board powers up fine but when it is powered off the panel LEDs and HDD LED (amber light) stay on which drains battery.Any help will be appreciated.Thanks. -
by pniHi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
by alpersenOn the right bottom side it has a start/stop button (normally it is illuminated, when I took the picture it was blinking I took at the wrong time
). and the touch area there is not working, maybe if I am able to touch the most right bottom in a maybe 1 square millimeter area it works. also generally if I touch the normal place where the start stop icon is, the weight + and - areas register so there is a touch calibration problem in that area. All icons maybe 60% of the left side register correctly in their respective size. Siemens service recommends replacing the control pcb and screen (nearly...
by trepachkaI am trying to convert a HP EliteBook 840 G7 notebook from a non-touch to a touchscreen. I purchased a complete touch LCD assembly with a screen/back cover/bezel/video cable and swapped it out with the original non-touch LCD assembly.
The screen works but the touch does not. I know the new LCD assembly is completely functional because we tried it on a similar touchscreen EliteBook 840 G7 and the touch works there.
I contacted the seller and he said screen conversion like this will not work due some difference in the motherboard for non-touch and touch capable EliteBook 840 G7.
by ProttHello,
I have a question that's driving me a bit nuts recently.
Is the touch board on Surface Pro 4/5 somehow married to the motherboard? I have a few Surfaces that, after the touch board change, lost all touch functionality.
- I tried flashing the bios (simple ME clean from a known good bios, previous bios didn't have an intergrated hub enabled), reinstalling firmware, reinstalling windows and even new touch boards.
- In one instance, after I tried to troubleshoot by using a known good screen + touch pcb combo on a Surface that lost touch, the touch board... -
by howardc6449UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on... - Loading...
