Dead hp dv6 (quanta ut3)
  • v1406
    • Sep 2012
    • 16
    • india
    Dear All,
    Hello !
    I am looking for a solution to a dead HP DV6-1235ee laptop with the following motherboard:
    Foxconn
    ML1-H94V-0E253117
    168UT30001-094D
    quanta ut3 schematics
    PU1:: ISL6262
    PU2:: RT8206B
    PU3:: 8119LN
    PU4:: P2805
    PU5:: ISL6251
    som of the voltages i measured:
    DC jack = 19.93V
    +VA = 19.90V
    +VAD = 19.71V
    +VIN = 19.71 V
    +5VPCU = 5.25V
    +3VPCU = 3.45V
    +5VALW = 5.25V
    +12VALW = 8.70V ?? is it fine or is overloaded somewhere?
    Voltages At EC (KB3926)
    9, 22, 33, 67, 96, 111, 125 (3VPCU) = 3.4V
    037 3920_RST# = 3.3V
    127 LID_EC# = 3.25V
    086 ACIN (ACIN_1) = 3.1V
    019 NBSWON#1 =3.4 / 0V (before /after power button)
    090 DNBSWON#1 3.4 / falls to 0.2V gradually rises to 0.5V and settles there
    95 RSMRST# 0V / 2.8 V only for half a second when you press the power button and then falls back to 0V
    16 SUSC# 30 mV / 275mV again falls to 30 mV
    06 SUSB# 30 mV / 550 mV again falls to 30 Mv
    BIOS ( U22 sheet no 34)
    Pin no. name voltage
    1 BIOS CS# 0.18 V isnt it too low?
    2 BIOS RD# 1.64 V
    3 SPI 3P 3.4 V
    4 VSS 0 V
    5 BIOS WR# 0.25 V
    6 SPI CLK 1.5 V
    7 SPI 7P 3.4 V
    8 VDD 3.4 V
    I would request you to kindly let me know what is going wrong which is preventing the rsmrst voltage from getting high. it tries to go high but falls down immediately to zero.
    I dont know what to do now. kindly show me the path to tread.
    thanks in advance.
  • v1406
    • Sep 2012
    • 16
    • india
    Re: Dead hp dv6 (quanta ut3)
    Looking forward to a few comments from all of you.....
    thanks
    • v1406
      • Sep 2012
      • 16
      • india
      • v1406
        • Sep 2012
        • 16
        • india
        Originally posted by v1406
        come on badcaps forum users......... it has been two days and not a single comment?
        please give some feedback
        thanks
        • trebo
          • 514
          • Wales, UK
          thanks
          Have you read this one
          https://www.badcaps.net/forum/showth...ghlight=hp+dv6
          • v1406
            • Sep 2012
            • 16
            • india
            still no response from such an active forum ........ unbelievable !!
            • v1406
              • Sep 2012
              • 16
              • india
              is it a forum NOT FOR TECHNICIANS ??
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Look at post number 5.
                Muh-soggy-knee
                • v1406
                  • Sep 2012
                  • 16
                  • india
                  had a good look at that reply no 5. but that is something different....
                  if you want pictures , i can upload those but vissibly there is not any burnt component or dry solder....
                  hopefully someone can tell me how to troubleshoot it by measuring voltages in a logical sequence
                  thanks for your input.
                  • v1406
                    • Sep 2012
                    • 16
                    • india
                    sure many of you know where the problem is........ you just need to share your knowledge with others.
                    waiting for your reply
                    • dycc
                      Vision
                      • Nov 2011
                      • 625
                      • CĂ´te d'Ivoire
                      when you press the power switch button the power on led is lit or not .
                      • dycc
                        Vision
                        • Nov 2011
                        • 625
                        • CĂ´te d'Ivoire
                        do you have the power on sequence of this laptop ????
                        why do you think RSMRST# is the guilty ????
                        RSMRST can be an impulse !!!!
                        i suspect the southbridge and the kb3926 . first reflow the southbridge and if it is not OK , you must change the kb3926.
                        good luck
                        • olegi
                          • 63
                          Basically when you press power ON (NBSWON#1) what happen ?
                          Power +5VPCU = 5.25V; +3VPCU = 3.45V; +5VALW = 5.25V it is a bit high .Any trace of liquid.
                          • fddizon
                            • Sep 2011
                            • 555
                            • Philippines
                            v1406,
                            you said +12VALW but you have 8.70V. check capacitors connected to this line.
                            you said when you press power on, rmsrst got normal voltage, but goes to ov. check destination part. i suspect that when current reaches the components along its path, it goes off.
                            • xaviero1412
                              • Apr 2009
                              • 56
                              for 12v and become 8.7v , it usually the ic that supply that voltage gone wrong, try reflow the ic first, or replace with new one.
                              • fddizon
                                • Sep 2011
                                • 555
                                • Philippines
                                12v regulator IC?
                                • lucco85
                                  • Feb 2012
                                  • 20
                                  • Hrvatska
                                  Check SUSB# and SUSC# when DNBSWON is low
                                  Bios CS#, RD# should check the waveform, do you have a constant waveform at these pins
                                  As I can see, no need for a 12v start board!?
                                  • v1406
                                    • Sep 2012
                                    • 16
                                    • india
                                    Thanks for your comments.
                                    Frankly speaking, I had left the hope of receiving any worthy comments after a few days of lull.... but i am glad i was totally wrong. it took some time but by now there are plenty of them.
                                    thanks again.
                                    coming to the point, i have already mentioned the low state of susb and sus c in my original post.
                                    127 LID_EC# = 3.25V
                                    2 BIOS RD# 1.64 V
                                    3 SPI 3P 3.4 V
                                    4 VSS 0 V
                                    5 BIOS WR# 0.25 V
                                    6 SPI CLK 1.5 V
                                    7 SPI 7P 3.4 V
                                    8 VDD 3.4 V
                                    I am sorry to report that i dont have any cro so cant check the waveforms.
                                    is there an easier way out there??
                                    someone suggested to remove the bios totally and then try to power on. is that alright??
                                    basically i want to know what is preventing the rsmrst to get to high state. it tries to get high but something shuts it down again. that something ...is the culprit ... which i want to trace.
                                    also 12 v ... is it designed that way ....to be low in the begining and gain full strength at power on??
                                    its getting lengthy so i will stop here and wait for your reply..... and then we will interact more
                                    thanks once again for your interest
                                    • v1406
                                      • Sep 2012
                                      • 16
                                      • india
                                      thanks for your interest
                                      there is no liquid spillage.
                                      it was a bit dusty but i have cleaned that all.
                                      the voltages will drop down with rise in current demand.
                                      thanks again
                                      • v1406
                                        • Sep 2012
                                        • 16
                                        • india
                                        thanks for your comments. sorry i could not reply earlier.
                                        in these dv6 laptops there is an LED just around the dc jack. that lights up as soon as you plug in the adapter. that LED is glowing .
                                        but the LED that comes on after pressing the power button tries to glow......... very faint pulse of light comes when i press the power button but in less than half a second that goes off.
                                        ....... just like the rsmrst signal
                                        thanks again
                                        • xenotic
                                          [HELP] Quanta DAG7BMB68C0 Motherboard Dead, No Video, Power LED ON
                                          by xenotic
                                          HP 15-CS3067nl Quanta DAG7BMB68C0 Rev C Motherboard
                                          Hello, can someone please help troubleshoot and verify voltages on this HP board,
                                          It won´t boot, no video, just power LED lights up when button is pressed.
                                          Inductors resistance to ground is:
                                          1R5 =3,4V
                                          2R2=0,0V
                                          1R0=0,0V
                                          R47=11,35V
                                          R24=0,0V
                                          R24=0,0V
                                          R22=0,13V
                                          1R0=0,0V
                                          R33=0,0V...
                                          02-28-2023, 09:16 AM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • lpraderi
                                          Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
                                          by lpraderi
                                          Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
                                          In some cases to use LVDS screen PCB use converter IC RTD2132/6
                                          Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
                                          at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
                                          Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
                                          11-25-2023, 09:31 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
