Toshiba A665 blown MOSFET
  • Rolin
    • Apr 2007
    • 174
    Re: Toshiba A665 blown MOSFET
    Do I still need to measure the DC current between PIN 5 Q30 and Ground?
    LOL, I meant Pin4.... mistype..
      no, by the way, it is not pin 5 (That is Drain pin, it would have been big spark! if you do), it is pin 4 (Gate pin). You are OK, no need to do current test, too dangerous
        By the way, did you find out if you get the POST when you turn on the computer?
        • Rolin
          • Apr 2007
          • 174
          What do you think is causing the 19V at PIN4 then?
          Yes, I do get a POST. Almost feel like leaving PIN6 lifted on Q11 and run it! Probably not a good idea, but what would happen?
            I think the 200K is not 200K but 260K, but you already found the 47K resistor which is more important, it is the resistor at the bottom right of Q30 by pin 4 that you found, right?
            • Rolin
              • Apr 2007
              • 174
              In the picture, It's the black component to the right of PIN4 Q30 and just below PIN3 of Q11
              If I understand correctly, I just need to replace the Q11 at this point, correct?
              It's 1:30AM, I better get to bed or I'll fall a sleep on my keyboard! I'll read your answer tomorrow...
              Good night Bud!
                These resistors in circle, right?
                • b700029
                  Banned
                  • Sep 2010
                  • 640
                  #68
                  5VS will stay on even when the laptop is off, which means a lot of things powered when they shouldn't be, and some chips might be subjected to backflow of current through their protection diodes, not good at all. In addition it'll probably
                  If they didn't care about draining 5VS quickly when turning off, they wouldn't have Q11 discharge the rail. 5V into 470 ohms means ~10mA will be going through there.
                  At best you'll have a battery that drains faster, at worse it could cause long-term damage to more sensitive parts.
                  • Rolin
                    • Apr 2007
                    • 174
                    B700029: Yea, I suspected something like that - it would cause some sort of problem. I was kind of kidding - we're this far so I'll replace Q11 once I find one - the fact it's turning on again makes it very slightly tempted to leave it alone!- but I won't.
                    Q11 is such a small chip, I doubt I'll be able to find a replacement on one of my many scrap boards laying around here, so I'll order from digikey or somewhere.
                    Bud: I attached a picture of the R410 resistor area. Below the resistor it's a blank (nothing there, just two solder points). The item to the left is what appears to be a cap.
                      That is good that it is 47K, you are safe to install new Q11. We are almost done!
                      • b700029
                        Banned
                        • Sep 2010
                        • 640
                        #71
                        The schematic shows R413 with an "@" sign after it. I think this means the component was omitted because it was deemed unnecessary.
                        • Rolin
                          • Apr 2007
                          • 174
                          Ordered the MOSFET from Digikey. Will let you know what happens after the installation.
                          • Rolin
                            • Apr 2007
                            • 174
                            Just wanted to update the forum on this one. I installed Q11 and Q30 - everything is working properly. I want to thank everyone who helped on this laptop motherboard repair. I learned a lot, and had some fun. Thank you!!
                              Thank you for letting us know the result, great job getting it fixed.
                              • sayyid
                                • Oct 2012
                                • india
                                #75
                                sir i have dead notcharging toshiba satellite l10 i repair charging ok set is on but one problem sum time graphic ok after5minut gone lcd and sistem shutdown i check board a pq40 si4922mosfet vry heat schematic page no;27 how to get this mosfet
                                • duf duf
                                  • 3
                                  Originally posted by b700029
                                  A quick glance at the schematic shows that Q30 is for powering +5VS from the +5VALW rail (and possibly vice-versa, depending on how they designed the power sequencing).
                                  I suggest looking for the problem somewhere else. The weird behaviour you're seeing is just an artifact of rails being powered from backflows of voltages through other components like IC's protection diodes. I would not recommend trying to run the system in that state as they're not designed to take such large currents.
                                  P.S. in case you don't know already, MOSFETs are highly static-sensitive. You might've killed or damaged them if you weren't being cautious with ESD.
                                  How do I download these schematics. It keeps redirecting me to a page requiring authorization.
                                  Basically I need to know the part in slot PQ7. It burned out.
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #77
                                    Duf Duf -Please can you update your profile with state.
                                    • degutji
                                      • Dec 2012
                                      • 173
                                      • Indonesia
                                      #78
                                      Very educate, i can learn from this case, very interested.
                                      Here you are duf-duf
                                      • duf duf
                                        • 3
                                        WOW thanks folks for the speedy response. I see my part is on page 37 upper left hand, next to the Vin. Looks like a DMOS device.
                                        Now where do I order such part? Digi-key? I assume that AO4435_SOB, is A-oh not a-zero. And SOB?? OK noob question, what does SOB stand for?? I know what I think it stands for....
                                        • duf duf
                                          • 3
                                          Well this is what I ordered, hope it's right. No wonder these things blow out, the power cord comes in at 19 VDC and the chip is set for 20 V max.
                                          http://www.digikey.com/scripts/DkSea...4435&WT.srch=1
                                          • nubie
                                            Rosewill Tokamak 1200w blown mosfet 5R199P
                                            by nubie
                                            Rosewill 1200w blown APFC? Mosfet.
                                            I got this with a blown fuse. Replaced fuse and the APFC mosfet blew.
                                            Removed the mosfet and got 5VSB, then when I connected PWON to ground the Fuse blew again.
                                            So do I need to replace the mosfet? Or should I be looking elsewhere? Thanks.
                                            According to a review of the 1500w unit there is an option for 4 transistors instead of 3 and they are different: https://www.tomshardware.com/reviews...su,4823-3.html
                                            07-02-2024, 05:33 PM
                                            09-06-2024, 05:27 AM
                                            09-06-2024, 05:59 AM
