Dell Latitude D520 AC Charger LED Turns Off When Plugged In
  • Paul678
    • Nov 2011
    • 402
    I've checked the voltage on the charger, and it's a
    healthy +19.5V, but only when it's not plugged into
    the motherboard, which is now completely disassembled
    except for the memory. As soon as I plug it into the
    connector, the LED on the charger goes out, indicating
    short-circuit protection, and the laptop cannot be
    turned on. But when I probe for the short on the connector
    with my DMM, I cannot find the short....it's all high impedance.
    I also tried this with another, identical charger, and the
    same thing happens.
  • Paul678
    • Nov 2011
    • 402
    Re: Dell Latitude D520 AC Charger LED Turns Off When Plugged In
    same thing happens.
    ok, update:
    There is a short somewhere, but it's hard to
    figure out where, because it may be just one component
    on the power plane, which is making many MOSFETs
    and caps appearing to be shorted.
    I'm in the process of removing them one-by-one.
    Painstaking, yes, but I've got to give it a shot before
    I give up on this board.
    Sometimes you have to go into brute-force mode.....
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Questions:
      1. is this an OEM brick?
      2. if so, is it a PA-10? PA-12? Other model?
      sigpic
      (Insert witty quote here)
        Sometimes it is simpler to feed in 20V, current limited to 500mA or so (use a 39 ohm power resistor), and feel what component gets warm. The brute force way is to limit the current to 3A and see what smokes... wouldn't want to try that on a motherboard though!
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          I think the problem is with the brick (voltage source), not the laptop (voltage receiver). That wouldn't help.
          sigpic
          • Paul678
            • Nov 2011
            • 402
            Questions:
            Yes, these appear to be OEM.
            One is PA-10, the other is PA-12.
            Model # NADP-90kb and LA65NS1-00
            • Paul678
              • Nov 2011
              • 402
              But I tried 2 different voltage sources, and they both
              did the same thing. Also, there IS a short on the
              mother board, with MOSFETs reading a short both
              ways from drain to source, even after the gates have
              been shorted to ground. Also, nearby caps read short
              both ways as well, so something is up.
              To Tom: yes, I've already tried that. It kinda made the
              mosfets hot, so that's where I'm looking. I went up to
              about 2 amps, with my bench powersupply in current-limit
              mode, but if I get desperate, I'll try 3 amps! haha
              • Paul678
                • Nov 2011
                • 402
                Update:
                Ok, I found a shorted N-channel MOSFET:
                Ordered 4 from Newark, because I absolutely hate how
                Mouser and Digikey don't tell you what the final shipping cost
                will be up front! $10 total.
                I know this was the problem, because after I removed it,
                I was able to plug the charger in, and the LED remains on.
                As usual, I'm bracing myself for something else to be
                wrong besides this one MOSFET, but hope springs eternal!!
                haha!
                • Paul678
                  • Nov 2011
                  • 402
                  Update:
                  haha!
                  WORKS BABY!!!
                  It was just that one Mosfet!
                  I pretty much did this one myself, but thanks for
                  your inputs anyways!!!!
                  • Pacifist
                    • Apr 2013
                    Hey Paul678 first of all, congratulations on making it work . Please tell me the equipment you used to troubleshoot your board and the steps you took to fix it as I am in the same dilemma at the moment.
                    • spleenharvester
                      • Mar 2010
                      • 921
                      You got one that turns the adapter LED off too? I have a Studio 1537 doing it and it's driving me spare would also love to know!
                      Think I might just start taking components out of the chain and seeing which lines are at fault.
                      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                      • mpikou
                        • Jun 2013
                        • 58
                        • Greece
                        Greetings,
                        This was the only post about this model so I am sending my request here.
                        First of all, does someone know where I can get the schematics for this laptop? Latitude D520
                        Moreover, this is the part I need to clarify what exactly is in order to buy and replace it. I am attaching a photo.
                        Thanks in advance all!
                        • trebo
                          • 514
                          • Wales, UK
                          Originally posted by mpikou
                          Greetings,
                          looks like this could be the one, https://cdn.badcaps-static.com/pdfs/...88cf177dc8.pdf
                          they have them on ebay
