Acer 4530 - powers on then shuts off 2 seconds later
  • 12ax7a
    • Oct 2009
    • 21
    Acer aspire 4530 - powers on then shuts off 2 seconds later.
    This seems to be a fairly common problem among many manufacturer's laptops described on the web.
    Anyone know the cause / fix?
  • nish_pinto
    The Adventurist
    • Oct 2011
    • 83
    • India
    Re: Acer 4530 - powers on then shuts off 2 seconds later
    Of what nature is the problem? Could you please elaborate?
    http://nishantpinto.blogspot.in/
    • chosentestament
      • Sep 2011
      • 6
      Does it get to POST first? If it doesn't get to POST it sounds like it may be a power supply issue.
      • 12ax7a
        • Oct 2009
        • 21
        Nope - no post. no bios writing. tried three different external adapters - all good. no difference.
        Nature of the problem: Press power button.. blue LEDS do their 'go around thing' for about 1.5 seconds ... fan makes brief blowing noise .. no bios writing on screen ... unit shuts off. charging of battery & charging LED seem to function correctly. changed CPU. changed memory. disconnected all device loads - that is: hard drive, CD rom, modem, wifi, etc. DC jack seems good. same problem regardless of whether screen is connected. reapplied silver thermal paste on cpu. graphics chip heat transfer pad seems fine. same behavior regardless of battery connected or not. no obvious shorts in USB connectors or otherwise. 5V & 3.3V stand-by appear to be there. ...
        • 12ax7a
          • Oct 2009
          • 21
          the consensus out there seems to be Nvidia video chip requiring reflow or reball.
          everybody agree?
          • trebo
            • 514
            • Wales, UK
            everybody agree?
            mine was acer travelmate 5320, similar symptoms, lots of lappys out there with similar symptoms, and no fixes or help
            your lappy like mine is NOT known to require reflow, like some lappys DO
            mine turned out to be CPU
            I was about to replace the bios chip before cpu
            reflow seems drastic at this stage (they dont seem to last anyway)
            • hotkey
              • Jun 2011
              My problem just same
              my laptop acer 4740 die after a few minit in win
              this pronlem like chipset over heat or fan run badly
              i still can't solve this problem
              all voltage in motherboard is good.
              • specific
                • Oct 2011
                hi
                for acer 4530 prob is around the nvidia chip
                reflow or reball is recommended
                its actually coprocessor not only vga
                u can just heat the chip for some time and check
                regards
                • 12ax7a
                  • Oct 2009
                  • 21
                  tried it once but i'll try it again. thanx.
                  • starmaxpc
                    • Oct 2009
                    • 117
                    everybody agree?
                    YES!! i had one of these laptop's. stripped in down re heated the nvidia with hot air gun and also shimmed it with a dime, yes a dime, temporary fix. still working to this day no problems. did it 2 months ago. There..... put in my "10 cents" worth! Har Har...
                    • swanand
                      • Dec 2011
                      • 51
                      first check with the another cpu... if problem is steel there then you will need to replace nvidia mcp77 bga chip
                      Regards
                      swanand
                      • charlee_77
                        • May 2013
                        • Malaysia
                        Nature of the problem: Press power button.. blue LEDS do their 'go around thing' for about 1.5 seconds ... fan makes brief blowing noise .. no bios writing on screen ... unit shuts off. charging of battery & charging LED seem to function correctly. changed CPU. changed memory. disconnected all device loads - that is: hard drive, CD rom, modem, wifi, etc. DC jack seems good. same problem regardless of whether screen is connected. reapplied silver thermal paste on cpu. graphics chip heat transfer pad seems fine. same behavior regardless of battery connected or not. no obvious shorts in USB connectors or otherwise. 5V & 3.3V stand-by appear to be there. .......
                        • survivalbloke
                          Dell laptop powers up with kb backlight about 10 seconds, then shuts off
                          by survivalbloke
                          I've got a Dell Latitude 5580 which came in for no power. It's not exactly a no power issue though. The battery was puffy so I replaced that, but the symptom is that when the power button is depressed, the keyboard backlights will come on for about 10 seconds then go back off. Before depressing power button, I am drawing 112ma and oddly, there is no change in current draw once the button is pressed and the keyboard backlights illuminate.
                          Any ideas?
                          01-08-2024, 12:12 PM
                        • chaos-theory
                          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                          by chaos-theory
                          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                          03-14-2025, 05:37 PM
                        • APOPAP
                          Panasonic National NV-M3 VHS Camera shuts down after some seconds
                          by APOPAP
                          Hello everybody,
                          First post here. I have been reading posts here for some time now, but today I made my first account and post.
                          The same question is also posted on another site, here it is:
                          Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                          I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                          08-25-2025, 10:12 AM
                        • tec3000
                          Sony LED 65X9005A shuts down after few seconds - looking for help
                          by tec3000
                          Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                          I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                          03-20-2024, 07:29 AM
                        • lowpost99@gmail.com
                          Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
                          by lowpost99@gmail.com
                          I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
                          09-03-2024, 02:57 PM
