Acer 4530 - powers on then shuts off 2 seconds later
    Acer aspire 4530 - powers on then shuts off 2 seconds later.
    This seems to be a fairly common problem among many manufacturer's laptops described on the web.
    Anyone know the cause / fix?
    Re: Acer 4530 - powers on then shuts off 2 seconds later
    Of what nature is the problem? Could you please elaborate?
    http://nishantpinto.blogspot.in/
      Does it get to POST first? If it doesn't get to POST it sounds like it may be a power supply issue.
        Nope - no post. no bios writing. tried three different external adapters - all good. no difference.
        Nature of the problem: Press power button.. blue LEDS do their 'go around thing' for about 1.5 seconds ... fan makes brief blowing noise .. no bios writing on screen ... unit shuts off. charging of battery & charging LED seem to function correctly. changed CPU. changed memory. disconnected all device loads - that is: hard drive, CD rom, modem, wifi, etc. DC jack seems good. same problem regardless of whether screen is connected. reapplied silver thermal paste on cpu. graphics chip heat transfer pad seems fine. same behavior regardless of battery connected or not. no obvious shorts in USB connectors or otherwise. 5V & 3.3V stand-by appear to be there. ...
          the consensus out there seems to be Nvidia video chip requiring reflow or reball.
          everybody agree?
            everybody agree?
            mine was acer travelmate 5320, similar symptoms, lots of lappys out there with similar symptoms, and no fixes or help
            your lappy like mine is NOT known to require reflow, like some lappys DO
            mine turned out to be CPU
            I was about to replace the bios chip before cpu
            reflow seems drastic at this stage (they dont seem to last anyway)
              My problem just same
              my laptop acer 4740 die after a few minit in win
              this pronlem like chipset over heat or fan run badly
              i still can't solve this problem
              all voltage in motherboard is good.
                hi
                for acer 4530 prob is around the nvidia chip
                reflow or reball is recommended
                its actually coprocessor not only vga
                u can just heat the chip for some time and check
                regards
                  tried it once but i'll try it again. thanx.
                    everybody agree?
                    YES!! i had one of these laptop's. stripped in down re heated the nvidia with hot air gun and also shimmed it with a dime, yes a dime, temporary fix. still working to this day no problems. did it 2 months ago. There..... put in my "10 cents" worth! Har Har...
                      first check with the another cpu... if problem is steel there then you will need to replace nvidia mcp77 bga chip
                      Regards
                      swanand
                        Nature of the problem: Press power button.. blue LEDS do their 'go around thing' for about 1.5 seconds ... fan makes brief blowing noise .. no bios writing on screen ... unit shuts off. charging of battery & charging LED seem to function correctly. changed CPU. changed memory. disconnected all device loads - that is: hard drive, CD rom, modem, wifi, etc. DC jack seems good. same problem regardless of whether screen is connected. reapplied silver thermal paste on cpu. graphics chip heat transfer pad seems fine. same behavior regardless of battery connected or not. no obvious shorts in USB connectors or otherwise. 5V & 3.3V stand-by appear to be there. .......
