HP Compaq 6735S - No power / No charge
  • mushy408
    • Nov 2010
    • 9
    Hey all! Firstly, this site is amazing! I've been looking for something like this for a while. I hope I can input some of my knowledge to others as I have quite a bit of experience with laptop motherboards.
    I've been working for a PC shop for over 12 months now repairing laptops & consoles at component level so I've learnt quite a bit.
    I've been trying to isolate a fault on this laptop board for some time now.
    The laptop in question is:
    HP/Compaq 6735S
    Original fault was a dry joint on the DC socket. I've been trying to get this laptop (buy it) off my friend for ages. Since then he's had "Someone who knows about computers" have a look at it.
    Anyways, I've got it now. No power, not even from battery. I've stripped it down and traced the input voltage around the board to various areas.
    I've resoldered the DC socket & also replaced a LM393 which was burnt. Still not getting any charge/power LEDs.
    Whilst 'probing' I felt a hotspot with my hand - TPS51120 - Synchronous Buck Controller (charge controller) This IC gets HOT as soon as power is inserted.
    From looking at the datasheet, it seems that this IC is is responsible for charging the battery and switching to AC when charged (duh!)
    My first few tests had me checking the surrounding caps - 1 short
    I removed the shorted Cap and still have a short across the pads which to me indicates the IC is damaged - hence the heating up
    I have seen a number of laptops with similar problems ESPECIALLY after having a bad DC socket. The constant switching of the power supply (Charger making contact, then breaking) over a space of time slowly burns out these controllers until either the battery refuses to charge, or the laptop refuses to power up.
    What I'm asking is has anyone else had this problem? What/how did you repair it? This isn't MOSFET or TRENCHFET related
    I can upload pictures if needed.
    Thanks!
  • meanderer
    • Jul 2010
    • 50
    Re: HP Compaq 6735S - No power / No charge
    repairing laptops at component level? good skills you have there.
    • sebuncle
      • Jun 2010
      • 46
      • France
      Hello,i have the same problem on a hp 6735b .It will not start no lights.
      I looked on Q500 after power connector pins 1 to 4 have 19v and pins 4 to 8 have 0v. If I shunts pin 1 with 5 the laptop starts and works normally with the power button. If I remove the shunts intensity drop and the laptop shutdown . i don't find the real failure
      JOVY RE7500
      • marcellodj
        • Nov 2010
        • 99
        i have similar issues with this model; power on, leds on, but no sign of life.Battery led is off, i tried to reflow all bga on the board, without success, so may be power ic related.Any help?
        • Dave24v
          • Aug 2013
          • 6
          • England
          Did anyone ever find out this problem in the end?
          I have the same problem on mine, ... No light's , no power, no nothing!!
          I've checked for dry solder joints etc, but still can't work out why it won't fire up!!
          • alihomee
            • Dec 2012
            • 1593
            • malaysia
            first of all check for 3v and 5valws on mobo .and also check 3v around bios chip
            • fddizon
              • Sep 2011
              • 555
              • Philippines
              find whats holding the pin 4 (gate) voltage. it should have 3 to 5 volts
              • spleenharvester
                • Mar 2010
                • 921
                Check the comparator circuit. Are you using a genuine HP adapter? It sends some kind of special signal which pulls a line (I think it's [edit see below]? but I can't remember) low, which allows VIN to reach the rest of the laptop.
                Though personally, I have worked with several of these boards, and they are all utter crap. They will quit working completely if you sneeze on them.
                EDIT: Just found my old thread, it's LIMITsignal:
                Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                • majoras54
                  • Mar 2017
                  • 3
                  • algeria
                  HP Compaq 6535s 6735s Laptop Schematic
                  • majoras54
                    • Mar 2017
                    • 3
                    • algeria
                    • hyditech
                      • 272
                      • nigeria
                      Change the kbc chip
                      • ipatch
                        troubleshooting microsoft surface pro 4 no power no led charge light
                        by ipatch
                        hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                        10-05-2023, 11:59 AM
                      • proxneo
                        iPad A2197 no power, A10 and other IC become warm, only 0.5A charge
                        by proxneo
                        Dear reader
                        TL;DR: iPad not turning on, A10 and power IC become (very) warm when attempted to turn on but this power-on cycle has a 'cooldown' period wherein powering on doesn't work, does not take more than 0.5A charge.
                        I am working on an iPad 7th generation 2197 from >2019 with no / limited charging and no boot issues. It is a refurbished purchase made in 2021. It appears the 'refurbish' company has either done prior motherboard work (all protective component shield layers are gone) or is one of the many trash refurbish companies (little screen adhesive left, component...
                        12-01-2023, 04:14 AM
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
