LA-E791P works in battery only
  • ashiq
    • Dec 2020
    • 20
    • india
    i have a unique issue that when battery is connected it works only in battery no adapter voltage is passed .when no battery it works in ac mode.
    when battery connected the ic drive the bat mosfet it will low the ac fet.
    i have changed the ic ,mosfet ,programmed io..
    any one have faced similar issue pls help!!!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: LA-E791P works in battery only
    Everyone of us has faced this type of issue but no one can help without any measurements.
    • ashiq
      • Dec 2020
      • 20
      • india
      is bq24725 and 725a same ???
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        No.
        • mon2
          • Dec 2019
          • 14664
          https://cdn.badcaps-static.com/pdfs/...10d99620ae.pdf
          • ramzi2019
            • Apr 2019
            • 56
            • tunisia
            I'm facing the same problem.
            The motherboard model is:
            CSL50/CSL52 LA-E791P
            REV:2.0
            2017-07-18
            I joined an image to the post with taken measurements ( The multimeter that I use is not perfect so excuse me for any mistake ).
            I'm using the schematic from this post
            https://www.badcaps.net/forum/attach...3&d=1634195060
            • mon2
              • Dec 2019
              • 14664
              ACDET voltage is too low. Are you using the official power adapter? Rated with enough power for this model?
              Review the datasheet for the charger ic and the details needed for the ACDET pin.
              • ramzi2019
                • Apr 2019
                • 56
                • tunisia
                Thanks for help.
                According to datasheet
                • 0: AC Adapter is not present (ACDET < 2.4V) <default @ POR>
                • 1: AC Adapter is present (ACDET > 2.4V), no deglitch time, read only
                I attached two images for the power adapter that I use.
                Can the two resistors R1 430k and R2 66.5k be the problem and need to be replaced ?
                • mon2
                  • Dec 2019
                  • 14664
                  Remove all power. Meter in resistance mode. Carefully measure the resistance of these 2 resistors. Post the measurements.
                  • ramzi2019
                    • Apr 2019
                    • 56
                    • tunisia
                    Thanks for your time.
                    I attached an image with the suspected resistors and measurements.
                    I think the R1 430k resistor need to be replaced???
                    • mon2
                      • Dec 2019
                      • 14664
                      Can you post a pic of your meter setting for these resistance checks?
                      • ramzi2019
                        • Apr 2019
                        • 56
                        • tunisia
                        This is a picture of my settings.
                        • mon2
                          • Dec 2019
                          • 14664
                          Use the 2M meter scale for R1 checking.
                          Use the 200k meter scale for the R2 66.5k checking.
                          Post the measurements again. It is possible that these parts are reporting a bad reading as they are soldered onboard but for the very low cost of resistors, suggest to replace both of them.
                          The resistors should be 1% tolerance and the same physical size as the original. Will check against the schematic and offer suggestions.
                          Do you have a local supplier for surface mount parts? Or you can buy through Digikey / Mouser or Aliexpress? Suggest Digikey if possible - perhaps RS Electronics in Europe.
                          The parts are 0402 in SMD size and 1% tolerance.
                          Be sure to purchase the same values as shown in the attached schematic. Purchase spares as they are easy to lose even with good motor skills and tweezers.
                          You must place the proper resistor value in the proper smd pad for this circuit to function. The higher resistor value is the one that mates with the +19 volts. Confirm this detail now before removing the old parts. Carefully check the voltage on the tips of the present resistors to confirm the +19v reaches the 'R1' resistor.
                          • ramzi2019
                            • Apr 2019
                            • 56
                            • tunisia
                            Thanks a lot for your help.
                            Because of multiple attempts to get a good measurement of R1, I destroyed it.
                            In any case, I will try to get another similar one from old motherboards because there are no nearby suppliers and purchasing from the internet is very complicated in my country.
                            I will inform you of the results as soon as possible.
                            Thank you so much
                            • mon2
                              • Dec 2019
                              • 14664
                              Ok. NP. From my little knowledge, I think our olive oil is sourced from your region. Very tasty.
                              These 2 resistors are not critical in their values but should be 0402 in size so you can solder them in place.
                              These 2 parts are building a resistor based voltage divider. So the values can vary but you must use a calculator to understand the target voltage.
                              See here:
                              https://www.digikey.ca/en/resources/...oltage-divider
                              Use 19 volts as the Vin and then apply the resistor values that you own or find on the donor boards.
                              The trick is to exceed the ACDET trigger voltage (ie. 2v7). So in the end, the R1 and R2 values can vary but the goal is to meet and exceed the threshold value.
                              Do post back before proceeding if there is any doubt.
                              • ramzi2019
                                • Apr 2019
                                • 56
                                • tunisia
                                See here:
                                Thank you for the addition on olive oil, this year the prices have been too inflated for ordinary citizens and the quality is unknown.
                                Let's hope that a quantity of the good product can reach good people like you.
                                In any case, for the repair of the motherboard, I will follow your instructions and I will inform you of the results.
                                Thank you for your time and kindness
                                • Bowline
                                  by Bowline
                                  06-11-2025, 10:13 AM
                                • bykanovm
                                  Thinkpad W541 Works from the mains and charges the battery only when it is turned off
                                  by bykanovm
                                  Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
                                  If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
                                  If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
                                  even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
                                  Also, the laptop does not turn on without...
                                  04-02-2025, 02:45 AM
                                • techfreak9356
                                  Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                  by techfreak9356
                                  I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                  09-14-2023, 11:10 PM
                                • ZixuTech
                                  Lenovo Ideapad 700-15ISK shuts down shortly after it starts. Works on battery
                                  by ZixuTech
                                  Hi Guys, a weird case here.
                                  This laptop came with damaged hinges, but no liquid signs.
                                  It will loop between battery charging/not charging/charging/... Now the original battery is completely drained it won't turn on with it. The orange light keeps blinking nonstop.
                                  I have replaced the battery with a newly charged battery and it turns on but doesn't charge. The orange charging light blinks three times indicating charging issues.
                                  I have replaced bq24780S battery charging chip, no difference.
                                  With a connected new battery,...
                                  04-03-2022, 04:03 AM
                                  NVDC charger configuration...
                                  11-05-2024, 03:28 PM
