Macbook Pro A1989 (Touchbar), 820-00850-A, 20V 0A, Not Charging
  • KappaDev
    • Feb 2019
    • 41
    I have a Macbook Pro A1989 that had liquid spilled on a thunderbolt hub that was plugged into one of the USB-C ports. The laptop will now no longer charge.
    Hitting the power button displays the low battery icon and then goes off.
    Power meter shows 20V drawing 0A. The same voltage displayed and amperage drawing on all 4 ports. Since the board is relatively cheap on this model, is there anyway to force charge the battery or run the board with a DC power supply to simulate the battery to retrieve the data?
    Thanks.
  • mon2
    • 14731
    Re: Macbook Pro A1989 (Touchbar), 820-00850-A, 20V 0A, Not Charging
    What is the voltage of PPBUS_G3H ?
    https://repair.wiki/w/A1989_2018_13%...ar_MacBook_Pro
    • modtool
      Macbook Pro A1989 fallen, reboots if touchbar connected
      by modtool
      Hi to all,
      the owner of this macbook brought it to me after a fall, that hit the upper right corner of the top case.
      Luckily enough, the screen and all other parts of the machine haven't been damaged, only the touch bar wasn't lighting up anymore, and the macbook began to behave strangely, because it seems to start and work fine but suddendly it shutsdown (and at the same time the fans make a high rotation for half a second, as if an animal was annoyed by something...) at random times, sometimes after 2 minutes, sometimes after 5 minutes, but never over 10 minutes, then restarts...
      11-10-2023, 07:42 AM
    • flusher
      Macbook Pro 13 2019 A1989 touchbar cable capacitor value
      by flusher
      Got this waterdamaged where oxidation happened under shield on touchbar cable. It showed image but no touch. After I cleaned and resoldered everything except ic (it is sealed anyway) i am getting touches however i find it a bit hit n miss where it works but sometimes missing dragging. Tapping seems fine. I think it might be something to do with this big cap which might be LDO or something. I placed 10v 2.2uF cap there. Anyone could measure it from good/dead touch bar lying around ?...
      07-28-2025, 05:20 PM
    • drlarsen
      MacBook Air M1 A2337 battery/charging issue
      by drlarsen
      Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
      I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
      On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
      After some hours, the battery status did not improve. Restore via DFU did not help.
      I connected the power adapter to a Kill-a-Watt...
      07-17-2025, 02:35 PM
    • robka
      MacBook Pro 2018 - A1990 Dead - not charging - only 5V
      by robka
      my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
      I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
      The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
      After that the Macbook was dead. It isn't charging anymore.
      The USB-C Port where the charger was plugged is burned. Also The Cable and the...
      03-02-2024, 02:58 PM
    • Gueric
      Macbook Pro M1 (A2338) 820-02020 not charging.
      by Gueric
      I returned home from college. My MacBook battery was flat. Plugged it in. Nothing. Won’t boot. Waited for an hour. Nothing.
      When plugging the charger : 20v at 0.02 amps.
      pressing any key will make the « low battery » icon show up. Then switch to 5v and 420mA constant. Trackpad clicks, keyboard works.
      Decided to put the board into another M1 body with a charged battery, it’s booting perfect, still 5v and 420mA tho, and battery is not charging.
      I diode moded every pin of U5200 and they’re all fine. I know very little about Apple silicon machines...
      07-23-2025, 01:54 PM
