apple configurator padlock
  • luckydip
    • Aug 2016
    • 165
    • uk
    Guys,
    Been away from repairs for a few years, good to see many familiar names still around!
    Working on my first T2, short on PPVIN_G3H_P3V3G3HRTC_R, which is now sorted. Machine starts to recovery, don't have appleid/password so tried to reinstall Mac os just boots back into spinning globe/recovery.
    Tried to connect apple configurator, gets into DFU, starts process but after a few minutes shows padlock for both revive and restore. Tried different macs, usb cables still get the padlock. Any ideas?
  • luckydip
    • Aug 2016
    • 165
    • uk
    Re: apple configurator padlock
    Forgot to add - Macbook Pro 820-01987
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Once it shows padlock after DFU restore it means the restore was successful.
      sigpic
      MEOWING IN THE IMPOSSIBLE UNIVERSE!
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Connect a direct line Ethernet cable if WiFi is weird.
        sigpic
        • luckydip
          • Aug 2016
          • 165
          • uk
          ok thanks for the padlock clarification.
          Just got my new usbc/ethernet cable and tested on another macbook - works fine. When I connect to problem macbook there is no connection - just stays on the select wifi screen. Not sure if ethernet is unavailable in recovery?
          If I connect to wifi, it loads to select language screen, then have the option to activate with email/password which I don't have. At this stage the cable seems active as the lights are flashing on router.
          the only option I have is to erase mac, I select this, get the circle and the macboook reboots to recovery again. Seems like the erase/activation is not happening?
          • luckydip
            • Aug 2016
            • 165
            • uk
            Another thing I've noticed is that none of the keyboard boot commands are working like option to select boot, pram reset etc. I've tried another keyboard to rule that out.
            • ibo
              • Oct 2019
              • 105
              • Turkiye
              So there is a activation lock on it, pram reset doesnt work on never models like T2 M1.
              • luckydip
                • Aug 2016
                • 165
                • uk
                I think its a T2 intel, option to select boot should work,or has that gone as well?
                Is there any reliable place to check icloud status like Apple used to do with serial/IMEI?
                cheers
                • reformatt
                  • Feb 2020
                  • 1494
                  Newer machines don't use CMD + R, but now need to hold power button down to get to an options menu for recovery etc.
                  T2 default security disables boot from USB. You can't change this unless you know the admin password. So you are forced to connect to the internet to reinstall, and of course the activation lock is on Apple's side so you can't go further. You need to bypass the lock or get it removed.
                  Apple put a massive dint in the 2nd hand market because of these features. Most dead machines I buy for parts where I fix the boards are activation locked.
                  • luckydip
                    • Aug 2016
                    • 165
                    • uk
                    Thanks for this, once the original owner removed it, os installed fine.
                    Any tips on where I can check icloud status online?
                    • mon2
                      • 14660
                      Hi. Have a 2019 A2141 16" macbook with a damaged screen (customer damage) that is boot looping with a chime.
                      Ran, for my first time, the DFU process using the client's 2nd new macbook and this 'dark' unit was found and we were able to setup into DFU mode.
                      Ran REVIVE (as we need the client's data!!) and the remote computer ran a few steps (4 in all) and then the target computer rebooted.
                      Now the remote computer is showing a padlock and the target is back to the boot loop with the chime.
                      Any ideas on how to proceed? Client owns the computer so he will have passwords but should the boot loop with chime have halted with the DFU process? Or we facing another fault?
                      He needs his data off this A2141. Apple was of course useless to assist @ Somerset Mall (Michigan).
                      • mon2
                        • 14660
                        Suspecting the issue with this A2141 is a power cycling fault. The fan spins -> unit chimes -> few seconds later, fan turns OFF and the cycle repeats. Current draw peaks to around 2.7A before dropping to 0 and recycling.
                        • Stephen
                          Meow Meow MEOW!
                          • Apr 2020
                          • 674
                          I hate to be the bearer of bad news but a restore is the only option at this point. Had a similar issue with a A2141 to recover data. It would not revive properly, informed the customer he was ok with restoring it and the computer worked again. I would honestly download a previous patch and dropping it in AC2 and hit revive. If that fails it's gotta be restored
                          sigpic
                          • Stephen
                            Meow Meow MEOW!
                            • Apr 2020
                            • 674
                            cheers
                            Yes only site to check iCloud is imei.org that’s the site I use to check serials before taking in trade ins or purchasing boards that need repair. They charge like I think .05 cents to check. I don’t know how they do it but it works.
                            sigpic
                            • mon2
                              • 14660
                              [QUOTE=Stephen;n1872983]Re: apple configurator padlock
                              -- lost the full edit of this new post with MS Edge browser.
                              • kjchatman
                                820-01949 charges the battery but doesn't complete the restore in apple configurator
                                by kjchatman
                                this one was powering up but no display and i later found a cap that was shorted to ground on 1v1_s3. but before i found that short i reflowed some stuff now i can't get it to power up anymore but the battery will charge
                                03-22-2024, 02:30 PM
                              • a_p3rson
                                Apple Watch Charging Controller Schematics / Boardview - 820-02601
                                by a_p3rson
                                Hi there,
                                I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                                You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                                This daughterboard uses an interesting...
                                04-21-2025, 11:41 PM
                              • myth77
                                a1466 to a2141 apple configurator
                                by myth77
                                I am having issue with macbook pro a2141, 2019. It start with question mark, the only option is internet recovery but it will not go to disk utility mode..just stops on like 1/3 progress bar with apple logo.
                                When i insert usb disk it will not recognize it, but on usb ports it is giving picture on external screen. It is heating a lot.
                                I did all resets and only thing left is try to revive it (firmware reinstall) with apple configurator from another mac. I have only macbook air 1466 from 2013. I install apple configurator on macbook air but when i connect usb-c (mac 2019) to usb-a...
                                08-28-2022, 12:26 PM
                              • bobotheklown
                                Nerdtool Apple display angle sensor configurator bypass
                                by bobotheklown
                                Does anybody have one of these yet? It looks like it just has a $5 esp32-c3 processor and then a few resistors and other components..Probably $10 to get pcbway to print it out, but I need access to the firmware and haven't been able to find it anywhere online. This allows individual users to perform screen repairs on apple laptops by avoiding the need to use apple parts (and thereby gaining acces to their configuration utility) and retain the open/lcosed sensor capability for the screen. I'll post the circut board files here if I can get a copy of firmware, no point in doing the work until I have...
                                04-06-2025, 01:01 AM
                              • Flasman90
                                Macbook Pro DFU Restore Issues
                                by Flasman90
                                I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                                - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                                - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                                08-30-2025, 10:27 AM
