820-2915-B missing pp5v_sus & pp3v3_sus
  • rtimots
    • Dec 2022
    • 11
    • Latvia
    Hello, I have a weird one today, I have a 820-2915-B board that had some issues, first of all I had pp3v3_s5 1,6v, changing the TPS51980 repaired that and now I have 3.3v, but the board didn't power on at this point, looking more I found that I don't have SUS voltages, first I tried to get 5v sus, PP5V_S5_P5VSUSFET_R- 5,05v and P5VSUS_EN_L - 0v , replacing U7940 fixed that, nov I have P5VSUS_EN_L - 4,94v, since I have vcc for this chip and the enable signal I thought that Q7840 was the problem, I changed it with a known good one, still I don't have pp5v_sus. And now starts the strange part, when I was looking around the board and checking voltages and shorts I checked again pp3v3_s5 by touching probe to r5040 and c7940 and suddenly the board turned on, I was shocked since the side I touched on these components was both pp3v3_s5, I started to investigate and replicate this, and for three times it started this way, I checked if I have voltages on both components and I have them, no shorts any where, replacing these r5040 and c7940 didn't fix this either and it dousing start, and now with changed components I can't replicate it any more. Is this a dead PCB or did I shorted sometime more that just one rail together. does anyone have an idea?
  • rtimots
    • Dec 2022
    • 11
    • Latvia
    Re: 820-2915-B missing pp5v_sus & pp3v3_sus
    Also regarding pp3v3_sus it tase the same thing as 5vsus, I have vcc and en signal but don't have sus voltage
    • rtimots
      • Dec 2022
      • 11
      • Latvia
      Could someone help with this? Haven't understood this problem till now either...
      • rtimots
        • Dec 2022
        • 11
        • Latvia
        So today i resolved this issue, when searching web for this problem many people mention to only test with genuine apple 85w power supply, and since i had exactly this i didn't wonder this is the fault, bet then remembered that i changed the wire from Ali express. Since i didn't have another, i used a cinema display with broken screen as the charger and this fixed this issue, so remember that if the wire has been changed it may not register as 85w charger
        • ugamazing
          820-02020 PPBUS_AON missing
          by ugamazing
          Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
          Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
          02-05-2025, 04:21 PM
        • jpreza
          Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
          by jpreza
          I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
          Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
          It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
          Looking at the card, it appears to be missing the following:
          1x 1.0uH inductor - orange square
          2x...
          11-01-2024, 10:54 PM
        • gurj1979
          Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
          by gurj1979
          Hey guys.
          Need help with this one.
          Fan not spinning due to missing PWN Fan signal.
          Also 5 seconds from powering up it freezes, unless in BIOS.
          But as soon as Windows starts to load, it will freeze.
          CPU is COLD / Room temp when it freezes.
          I've replaced the CPU, same problem.
          Replaced SIO/KBC IT8987e and reprogrammed - same problem.
          Replaced fan - same problem.
          Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
          Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
          08-19-2024, 05:22 PM
        • salopian
          Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
          by salopian
          Hello. I would need some advice please.
          My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
          He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
          I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
          I have already replaced the logic board with another...
          02-27-2021, 07:30 AM
        • ein_individuum
          Missing Capacitator Intel I9-12900KF CPU
          by ein_individuum
          I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
          I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
          Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
          08-06-2025, 01:36 AM
