820-2915-B missing pp5v_sus & pp3v3_sus
  • rtimots
    • Dec 2022
    • 11
    • Latvia
    Hello, I have a weird one today, I have a 820-2915-B board that had some issues, first of all I had pp3v3_s5 1,6v, changing the TPS51980 repaired that and now I have 3.3v, but the board didn't power on at this point, looking more I found that I don't have SUS voltages, first I tried to get 5v sus, PP5V_S5_P5VSUSFET_R- 5,05v and P5VSUS_EN_L - 0v , replacing U7940 fixed that, nov I have P5VSUS_EN_L - 4,94v, since I have vcc for this chip and the enable signal I thought that Q7840 was the problem, I changed it with a known good one, still I don't have pp5v_sus. And now starts the strange part, when I was looking around the board and checking voltages and shorts I checked again pp3v3_s5 by touching probe to r5040 and c7940 and suddenly the board turned on, I was shocked since the side I touched on these components was both pp3v3_s5, I started to investigate and replicate this, and for three times it started this way, I checked if I have voltages on both components and I have them, no shorts any where, replacing these r5040 and c7940 didn't fix this either and it dousing start, and now with changed components I can't replicate it any more. Is this a dead PCB or did I shorted sometime more that just one rail together. does anyone have an idea?
  • rtimots
    • Dec 2022
    • 11
    • Latvia
    Re: 820-2915-B missing pp5v_sus & pp3v3_sus
    Also regarding pp3v3_sus it tase the same thing as 5vsus, I have vcc and en signal but don't have sus voltage
    • rtimots
      • Dec 2022
      • 11
      • Latvia
      Could someone help with this? Haven't understood this problem till now either...
      • rtimots
        • Dec 2022
        • 11
        • Latvia
        So today i resolved this issue, when searching web for this problem many people mention to only test with genuine apple 85w power supply, and since i had exactly this i didn't wonder this is the fault, bet then remembered that i changed the wire from Ali express. Since i didn't have another, i used a cinema display with broken screen as the charger and this fixed this issue, so remember that if the wire has been changed it may not register as 85w charger
        • ugamazing
          820-02020 PPBUS_AON missing
          by ugamazing
          Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
          Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
          02-05-2025, 04:21 PM
        • jpreza
          Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
          by jpreza
          I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
          Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
          It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
          Looking at the card, it appears to be missing the following:
          1x 1.0uH inductor - orange square
          2x...
          11-01-2024, 10:54 PM
        • gurj1979
          Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
          by gurj1979
          Hey guys.
          Need help with this one.
          Fan not spinning due to missing PWN Fan signal.
          Also 5 seconds from powering up it freezes, unless in BIOS.
          But as soon as Windows starts to load, it will freeze.
          CPU is COLD / Room temp when it freezes.
          I've replaced the CPU, same problem.
          Replaced SIO/KBC IT8987e and reprogrammed - same problem.
          Replaced fan - same problem.
          Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
          Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
          08-19-2024, 05:22 PM
        • salopian
          Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
          by salopian
          Hello. I would need some advice please.
          My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
          He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
          I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
          I have already replaced the logic board with another...
          02-27-2021, 07:30 AM
        • reessi
          HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
          by reessi
          I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
          It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
          What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
          I have checked these lines in diode mode and they seam normal -> 600.
          I have checked to see if they come on for even a fraction of a second...
          07-15-2025, 09:14 AM
