dag37amb8d0 rev d no +3.3vs5
  • trmrtts
    • Jan 2014
    • 38
    • turkey
    hi everyone
    i have dag37amb8d0 rev d hp mother board.i havent +3.3vs5 pu2001
    5 pin have 3.3v
    1 pin 0v
    2pin 0v
    8pin 20v
    when i remove bios chip +3.3vs5 coming.
    i changed i/o an reprogram
    i changed pu2001
    when i pres on/off buton dc jack led blink 1 time
    whats my problem
    Mod Edit - attached schematic removed.
    Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
    Last edited by Vesko356; 09-13-2023, 12:46 PM. Reason: Attached schematic removed.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: dag37amb8d0 rev d no +3.3vs5
    check AD_ID
    • trmrtts
      • Jan 2014
      • 38
      • turkey
      i checked already0.6v
      • trmrtts
        • Jan 2014
        • 38
        • turkey
        Originally posted by trmrtts
        hi everyone
        5 pin have 3.3v
        1 pin 0v
        2pin 0v
        8pin 20v
        i changed pu2001
        whats my problem
        dc jack led ok
        • questore
          • Dec 2015
          • 563
          • csongrád
          0,6v on AD_ID is low. about 120W charger there should be aroun 1.8V
          see solution on
          Technical discussions covering any type of laptop, notebook, netbook, tablet, or smartphone. Any and all brands and models welcome. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            AFAIK, 3v will rise only after power button press.
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
              HP Omen 17-w DAG37AMB8D0 Boardview
              HP Omen 17-w DAG37AMB8D0 Boardview...
              10-26-2024, 04:12 AM
            • panoss
              Samsung LS19A100, slowed down, colors changed, lines not very crisp
              by panoss
              In the above mentioned monitor, I removed the plug a few times and this resulted no power.
              I opened it, soldered the dc jack and worked again.
              But since then colors have changed, too bright (or something like this) and lines, eg letter, are not very crisp as they used to be, they are vague, like faded out.
              I checked voltages on the main board, they look ok (according to the service manual. It' attached at the bottom):
              IC600 (D9329)
              pin 1 (BST) 9.6V
              pin 2 (VIN) 13.5V
              pin 3 (SW(Switching output)) 4.8V
              pin 7 (EN)
              pin 8 (SS) 2.6V
              IC601...
              10-13-2024, 10:21 AM
            • ivtec
              Win 10 home edition changed to Win 10 pro help
              by ivtec
              Hi guys; i have installed win 10 Home Edition from a DVD iso and it changed to Win pro ,how i change it back to Home edition without reinstall again ?Thanks
              06-21-2024, 08:43 AM
            • Ferimonka
              Dell Latitude 7420, 7320 voltage changed
              by Ferimonka
              Hi there,
              I got 2 Dell laptops with a locked bios (dell management protection).
              When I sent the dumps to this forum I got unlocked .bin files.
              The issue I am getting the voltage on the bios chip pins has changed once I soldered the chip back (with the unlocked even original bios file) and doesn't turn on anymore.
              Before I started to re-program the chip the voltage on the pins were 3.3V almost on each pin. Once I soldered the chip, voltage changed to 1.9V or 1.3V on few pins. No 3.3V anymore.
              I appreciate any help to get me this...
              07-18-2022, 02:11 AM
