[REQUEST] Asus S413DA battery connector : Pads issue
  • kurtspirit
    • Feb 2019
    • 112
    • France
    Good morning,
    I have a friend who dropped off his Asus just now. He tried to change the battery but tore off the connector.
    I can catch up on both tracks but I'm missing two pads that don't have visible tracks to bridge.
    Can you help me please ?
    Thanks in advance.
    The laptop is a S413DA , i don't find any boardview.
  • Sephir0th
    • Oct 2020
    • 1283
    Re: [REQUEST] Asus battery connector : Pads issue
    These are probably simply not connected then. Any clue from the battery pins?
    FairRepair on YouTube
    • kurtspirit
      • Feb 2019
      • 112
      • France
      Ah yes, I feel stupid for one out of the two... Indeed, the first from the left is not connected, on the other hand, the one on the right is on a blue wire on the battery side.
      I tried before desoldering everything to connect the battery without these pads and it does not work.
      I wonder if it's not connected to this track but I wouldn't want to do that randomly.
      Thank you for the answer
      • Sephir0th
        • Oct 2020
        • 1283
        From my experience, without "via" not connection. And I don't see either a via nor a broken track related to these two pads. Does the boards has other issues beside battery not working right now?
        • kurtspirit
          • Feb 2019
          • 112
          • France
          The card works well on the mains, the PC shows no other signs but perhaps the problem comes from the load management chipset?
          He changed the battery with an original manufacturer because the previous one no longer worked.
          Why have a blue wire on the battery and not a blank like on the other side if there is no connection?
          Do you know what this thread represents by any chance? It's just for my personal culture
          Thanks again.
          • kurtspirit
            • Feb 2019
            • 112
            • France
            Re: [REQUEST] Asus S413DA battery connector : Pads issue
            All is allright now. You're right, the pads wasn't importants.
            Thank you.
            • mkdj
              ASUS X571 no power : battery issue?
              by mkdj
              Mark and model: ASUS X571
              Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
              Tests already made:
              - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
              - I have removed...
              07-14-2025, 09:16 AM
            • huzo
              HP ELITE X2 1013 G3 weird battery issue
              by huzo
              Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
              01-31-2025, 12:09 AM
            • danielsak
              Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
              by danielsak
              Hello, I have issue with Dell Inspiron 3542.
              Motherboard marking:
              Code:
              PWB FX3MC REV: A00
              The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
              1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
              1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
              10-11-2024, 04:36 PM
            • irepair559
              Asus Rog Laptop new battery still 0% Biard issue?
              by irepair559
              Hello, i have a 2020 Asus Rog Gaming laptop powers on but always 0% doesnt charge? Bought a used oem battery ( they said only couple of cycles like new ) and same issue with new batt zero %.. I measured battery terminal on board and 2 center pins measure 3v each and the 3 pins to the right measure 0.8v each so total output of Board batt term is only around 8v ? Is that normal when no battery plugged in?
              When Battery plugged in then the numbers even are lower. There was a cap that shorted out but on other side of board not near battery terminal. Would that affect it? Laptop turns on and...
              02-16-2023, 10:43 PM
            • Simone Vergani
              Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
              by Simone Vergani
              I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
              To assist with troubleshooting, I'm attaching two power circuit schematics:
              • Power
              03-05-2025, 02:25 PM
