Asus Rog Laptop new battery still 0% Biard issue?
  • irepair559
    • Dec 2022
    • 134
    Asus Rog gaming laptop no display ? Bios? dead cmos batt?
    Hello guys, can a dead cmos batt cause no boot? Or currupt bios ?
    have a rog 501 i believe, lights come on.. Sata drive spins.. Ssd drive gets warm but no display .. cpu/gpu are cold as if theyre not turning on?
    Board is a GM501GS
    THANKS
    • Stevedb
      Stevedb
      • Feb 2018
      • 624
      • Belgium
      #102
      Re: Asus Rog Laptop new battery still 0% Biard issue?
      Yes bad bios battery can cause no post it depend from architecture off the board.
      • irepair559
        • Dec 2022
        • 134
        let me get a bios battery then! lol
        I noticed a mosfet source and gate gets shorted
        aright after i install a new ine and plug in power? is that normal?
        maybe the issue lies here why the laptop doesnt boot fully..
        tried bios bin file on flash drive and ctr R and nothing comes up..
        Im almlst there hopefully with your expertise i can getbit to work..
        • irepair559
          • Dec 2022
          • 134
          ok tried new bios batt same thing
          there are some mosfets i think on the main 20v ppwer rail, that are measuring 1 ohm between source and gate , switch leads and same thing.. Removed mosfet and still same values on board.. so something on that line is causing that..
          Guys anyone have a the schematic for the board ? GM501GS
          • irepair559
            • Dec 2022
            • 134
            anyone??
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #106
              You can search for a schematic in a "Schematic Requests ONLY!" section:
              https://www.badcaps.net/forum/forumdisplay.php?f=41
              If you can't find one, just open a new request at the above subforum.
              Become a Badcaps supporter
              Thanks to all supporters.​
              • mkdj
                ASUS X571 no power : battery issue?
                by mkdj
                Mark and model: ASUS X571
                Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                Tests already made:
                - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                - I have removed...
                07-14-2025, 09:16 AM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • code share
                Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                by code share
                I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                Here's what I've tried so far:
                • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                • Booted successfully on AC power only with the battery disconnected
                • Visual inspection of the battery — no swelling, burn marks, or connector damage
                • Battery
                04-21-2025, 12:50 PM
              • huzo
                HP ELITE X2 1013 G3 weird battery issue
                by huzo
                Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                01-31-2025, 12:09 AM
              • danielsak
                Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
                by danielsak
                Hello, I have issue with Dell Inspiron 3542.
                Motherboard marking:
                Code:
                PWB FX3MC REV: A00
                The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
                1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
                1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
                10-11-2024, 04:36 PM
