Can't write on mxic mx25l640E with Ch341 (WSON package)
  • krissdmtz
    Laptop burner
    • Aug 2021
    • 15
    • México
    So i found something strange, i have a mac a1370, already took the dump from the mx25l640E, i dont have the adapter but i managed to solder it on a board adapter with cables
    I can read from it
    I can erase it (VERY SLOW THO)
    but cant write on it, am using CH341 3v (came modded from where i brought it)
    Also using NeoProgrammer 2.1.0.19
    What can i do?
    Forced to love badcaps.net
  • mon2
    • Dec 2019
    • 14258
    Re: Can't write on mxic mx25l640E with Ch341 (WSON package)
    Is the mx25l640E supported in your programmer software?
    • krissdmtz
      Laptop burner
      • Aug 2021
      • 15
      • México
      It is and is also listed on autodetect mode
      • mon2
        • Dec 2019
        • 14258
        What is the voltage to ground of pin #3 (WP#) on this IC?
        If it is a logic low = ~0 volts, then the memory IC is write-protected. You can hardwire this pin #3 to the Vcc (3v3) pin #8 to remove this hardware write-protect feature.
        That is, on the chip, directly wire pin #3 to pin #8 - do not feed pin #3 back to the programmer circuit.
        • krissdmtz
          Laptop burner
          • Aug 2021
          • 15
          • México
          The Pin 3 is already hardwired on the programer itself with Pin 8 and Pin 7 too
          • krissdmtz
            Laptop burner
            • Aug 2021
            • 15
            • México
            So WP# is always getting 3.3v
            • mon2
              • Dec 2019
              • 14258
              So that is not the fault. Is the flash memory a brand new device or was pulled from a donor board?
              Another thread on this forum reported success in r/w/e of the same device.
              • mon2
                • Dec 2019
                • 14258
                Which software and version are you using? The other user was using a different tool. Let me find the thread.
                https://www.badcaps.net/forum/showthread.php?p=1041408
                • krissdmtz
                  Laptop burner
                  • Aug 2021
                  • 15
                  • México
                  It was pulled from a board, previously was working but had EFI password
                  • krissdmtz
                    Laptop burner
                    • Aug 2021
                    • 15
                    • México
                    Just tried CH341A software but same result
                    I mainly use Neoprogrammer 2.1.0.19
                    • mon2
                      • Dec 2019
                      • 14258
                      After erasing a sector, try writing 55 AA pattern. Then verify the pattern wrote.
                      • Vesko356
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        Latest version of the program is 2.2.0.10, try it:
                        https://www.badcaps.net/forum/showth...11#post1215111
                        Become a Badcaps supporter
                        Thanks to all supporters.
                        • krissdmtz
                          Laptop burner
                          • Aug 2021
                          • 15
                          • México
                          Sorry for not answering, i've just found that bios chip is damaged, i switched to another and is working well, thank you so much, anyway the new software version is usefull for me, thanks alot
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            You're welcome.
                            • eggman2112
                              840 G2 Macronix (MXIC) MX25L12873F Read Write Issues
                              by eggman2112
                              Sorry not sure if this is the right section for this.
                              840 G2 Macronix (MXIC) MX25L12873F Issue with flashrom on Raspberry Pi or TL866II Plus with Xgpro.
                              I have no problem reading and writing and using hpunlocker with WinBond chips.
                              When I try the Macronix MX25L12873F then flashrom would be unable to detect the chip and Xgpro would fail the verify right away when trying to write back.
                              I also noticed the Xgpro is getting Device ID differences as shown in screenshots:
                              When autodetecting the chip I see Device ID: C2 20 18....
                              06-01-2021, 11:25 AM
                            • ChaosLegionnaire
                              bug of the month: write caching setting for the hard drive in device manager
                              by ChaosLegionnaire
                              i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
                              so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
                              10-06-2019, 01:39 PM
                            • Normunds
                              Gs66 10sfs bios issue
                              by Normunds
                              I tried to update bios with ch341 and normally all is good.
                              now it says that buffer size is not equal to ic size.
                              I downloaded bios and ec from msi website.
                              Laptop model - GS66-10sfs
                              mobo model - MS-16V11 ver 1.0
                              Programmer used: ch341
                              ec chip - Mxic mx 25l12872f
                              bios chip - winbond 25q16jvnic
                              Tried ch341 programmer software and other softwares. I can read and write but buffer size is not the same as chip. Looms lije file is larger than chip can handle. Maybe need to trim file...
                              04-23-2025, 07:18 AM
                            • barbas
                              Replacing BIOS Windond chip, present in MSI GE78HX laptop for and MXIC and what is Quad SPI
                              by barbas
                              Hi. In the process of troubleshooting an MSI GE78HX laptop that does turn on (on its own), turns on the backlight on and off in infinite cycle, turns on RGB keyboard backlight and light bar. The CPU gets hot, and its fan spins.
                              The laptop charges the battery, turns on charging lights, which leads me to think the EC (ITE5571E) is ok. Laptop has no shorts, apparently. Memory is ok, tried it in another machine. Tried 5 different sticks in this machine as well, does the same. Memory connector seems ok, no pins bent.
                              First, I am going to try to backup and reflash its BIOS,...
                              05-14-2024, 02:01 AM
                            • vbogoev
                              Lenovo S6000 won't turn on. Data recovery needed.
                              by vbogoev
                              Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
                              Code:
                              [PWRAP] pwrap_init_preloader
                              [PWRAP] pwrap_init
                              [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
                              [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
                              [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
                              [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
                              [PMIC_WRAP]wrap_init pass,the return
                              06-20-2023, 06:36 AM
