Can't write on mxic mx25l640E with Ch341 (WSON package)
    So i found something strange, i have a mac a1370, already took the dump from the mx25l640E, i dont have the adapter but i managed to solder it on a board adapter with cables
    I can read from it
    I can erase it (VERY SLOW THO)
    but cant write on it, am using CH341 3v (came modded from where i brought it)
    Also using NeoProgrammer 2.1.0.19
    What can i do?
    Forced to love badcaps.net
    Re: Can't write on mxic mx25l640E with Ch341 (WSON package)
    Is the mx25l640E supported in your programmer software?
      It is and is also listed on autodetect mode
        What is the voltage to ground of pin #3 (WP#) on this IC?
        If it is a logic low = ~0 volts, then the memory IC is write-protected. You can hardwire this pin #3 to the Vcc (3v3) pin #8 to remove this hardware write-protect feature.
        That is, on the chip, directly wire pin #3 to pin #8 - do not feed pin #3 back to the programmer circuit.
          The Pin 3 is already hardwired on the programer itself with Pin 8 and Pin 7 too
            So WP# is always getting 3.3v
              So that is not the fault. Is the flash memory a brand new device or was pulled from a donor board?
              Another thread on this forum reported success in r/w/e of the same device.
                Which software and version are you using? The other user was using a different tool. Let me find the thread.
                https://www.badcaps.net/forum/showthread.php?p=1041408
                  It was pulled from a board, previously was working but had EFI password
                    Just tried CH341A software but same result
                    I mainly use Neoprogrammer 2.1.0.19
                      After erasing a sector, try writing 55 AA pattern. Then verify the pattern wrote.
                        Latest version of the program is 2.2.0.10, try it:
                        https://www.badcaps.net/forum/showth...11#post1215111
                        Become a Badcaps supporter
                        Thanks to all supporters.
                          Sorry for not answering, i've just found that bios chip is damaged, i switched to another and is working well, thank you so much, anyway the new software version is usefull for me, thanks alot
                            You're welcome.
