Flash mxic mx25l640E with Ch341 not recognized
  • marce002
    • May 2018
    • 316
    • Argentine
    Hello
    Can anyone help me to identify why the programmer is recognized well without
    Introducing the memory... but as soon as I
    Put the (well soldered I think) chip in the programmer as in the picture the red led turns off and not recognized at all....
    Think pin1 is well oriented
    Soft supports the chip and programmer too.
    Does it need a mod to 3.3v or this is nonsense?
    Thanks a lot in advance.
    Marcelo J
  • Sephir0th
    • Oct 2020
    • 1289
    Re: Flash mxic mx25l640E with Ch341 not recognized
    I'm pretty Sure this one works with 3.3V. So what is left... replace the SPI Flash and See whether it helps.
    FairRepair on YouTube
    • Zibbo
      • Mar 2017
      • 205
      • Zimbabwe
      You have inserted the board in the programmer wrongly. Pin 1 is in the opposite direction
      • marce002
        • May 2018
        • 316
        • Argentine
        Hello .. pin 1 in chip soldered to pin 1 on the board why do you say is wrong... look:
        You are prety sure need 2 replace the spi ?? Do not understand... is the only one that i have.why replace?
        Marcelo J
        • diif
          • Feb 2014
          • 6978
          • England
          The chip is on the PCB correctly but the PCB needs rotating 180 degrees.
          • marce002
            • May 2018
            • 316
            • Argentine
            Ok.. saddly rotated like this and does not work... placed ok, on 25L eproms area too... still red led turns off after plugin in usb ... so not detected.
            Marcelo J
            • Sephir0th
              • Oct 2020
              • 1289
              I didn't noticed this before. Good eye @zibbo
              @marce002
              You probably Killed that IC by inserting it in the wrong direction. I believe now you have No other choice than Order an replacement...
              • marce002
                • May 2018
                • 316
                • Argentine
                chip is: MX 25 L 640E ZN I 12 G
                so it is:
                8-WSON 8*6mm 64Mb and 3v
                no need to do anything strange like 1.8v or 3.3 mod or void pin 8 and that stuff right?
                Marcelo J
                • marce002
                  • May 2018
                  • 316
                  • Argentine
                  Sephir0th placed back in board and seems to be operating fine because loading OS so do not think it is burned.. any other suggestion ...
                  Macbook a1466 3437 efi of my own. That is what i try to read and write
                  Marcelo J
                  • Sametbey
                    • Jan 2021
                    • 229
                    • Turkey
                    have you tried any other spi with the ch341 programmer ? your programmer may not be compatible.
                    I'm not happy to be so strong. because it's not humanly
                      • 22293
                      Have you checked to see if you need the 3.3V mod https://www.chucknemeth.com/usb-devi.../3v-ch341a-mod .Its also worth resoldering all caps,resistors and pins on the CH341 chip.I have 3 of these and 2 were DOA.
                      EDIT: try it with some alternative software as well
                      https://www.badcaps.net/forum/showpo...04&postcount=7 NeoProgrammer
                      https://www.badcaps.net/forum/showpo...6&postcount=10 AsProgrammer
                      • marce002
                        • May 2018
                        • 316
                        • Argentine
                        Thks sametbey it may not be compatible then.. .. weird thing is that in the specs this memory is listed as compatible.
                        Marcelo J
                        • marce002
                          • May 2018
                          • 316
                          • Argentine
                          yes sametbey I have tried other spi with the ch341 programmer ,,,, i have just read mxic 25L8006E ok
                          thanks SMDFlea I m going to your post to analyse it ..but remember that have No LED after plugin so not a soft issue.
                          Will go 4 the 3.3 mod .thanks again
                          Marcelo J
                          • marce002
                            • May 2018
                            • 316
                            • Argentine
                            Mmmm really If I was succeeded with 25L8006E I wonder why should I do any mod.... they seem to required identical parameters (Volt) to be programmed,,,, maybe I soldered wrong to the board... i will try again. and post
                            Marcelo J
                            • marce002
                              • May 2018
                              • 316
                              • Argentine
                              I would just like to know WHY the ch341a red led turns off when inserting that specific 25L memory, like if it would shorted..... any other non 8wson works fine
                              Marcelo J
                              • marce002
                                • May 2018
                                • 316
                                • Argentine
                                ok finally red led ok, no short but sitll not detected and forced read only reads nulls,,,,,soft i tried AsProgrammer, CH341A Mini Programmer (Black Edition) By_NSC and colibri
                                end for now, if anyone have another suggestion thks
                                PD
                                Maybe I meed an 1.8V adapter to flash this kind of 8WSON Mxic memory, is it?
                                but data sheet says 2.7 to 3.6 volt for read
                                GENERAL
                                • Single Power Supply Operation
                                - 2.7 to 3.6 volt for read, erase, and program operations
                                Marcelo J
                                • marce002
                                  • May 2018
                                  • 316
                                  • Argentine
                                  Re: Flash mxic mx25l640E with Ch341 not recognized **SOLVED**
                                  ok finally worked fine!!!, forget all the stupid questions regarding mods and the 1.8v adapter since it is a 3.3 vol chip..
                                  PROBLEM WAS : have not wson8 adapter so i had to manage the placement in the adapter that I have, and the CH341 detected the chip fine, read and write ok!!
                                  thanks to all
                                  /closed/
                                  Marcelo J
                                  • krissdmtz
                                    Can't write on mxic mx25l640E with Ch341 (WSON package)
                                    by krissdmtz
                                    So i found something strange, i have a mac a1370, already took the dump from the mx25l640E, i dont have the adapter but i managed to solder it on a board adapter with cables
                                    I can read from it
                                    I can erase it (VERY SLOW THO)
                                    but cant write on it, am using CH341 3v (came modded from where i brought it)
                                    Also using NeoProgrammer 2.1.0.19
                                    What can i do?...
                                    08-24-2023, 02:49 PM
                                  • ekozeko333
                                    [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                    by ekozeko333
                                    I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                    🔥 The Problem Started After Suspected ESD/PD Fault
                                    I experienced a power issue or ESD event through a USB-C charger
                                    After that, the NX20P5090 power switch was visibly burned and was replaced
                                    Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                    🧠 What I’ve Done So Far
                                    Flashed...
                                    06-21-2025, 02:48 AM
                                  • corrize
                                    Nikon D800 camera - flash don’t work and capacitor don’t charge
                                    by corrize
                                    Hello, I'm stuck in troubleshooting…
                                    The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                    In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                    When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                    10-01-2022, 10:02 AM
                                  • spmetroil
                                    Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                                    by spmetroil
                                    I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                                    The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                                    I have a CH341A programmer and I already attempted the following steps:
                                    1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                                    2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
                                    3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                                    08-19-2025, 09:23 AM
                                  • abajor
                                    Canon VIXIA HF S10 A read data from inernal flash memory.
                                    by abajor
                                    Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
                                    Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
                                    The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
                                    I think my best shot is to figure out a way to read the internal flash memory outside...
                                    07-20-2024, 12:04 AM
