Asus E410M not charging battery
  • roman728
    • Jul 2018
    • 28
    • Slovakia
    Hello friends,
    I have this laptop with a not charging battery. This is the 3rd same laptop with exact same problem so there must be some manufacturing design problem. Windows says 0% (plugged in) and percentage doesnt increase. I tried with new battery and also with new BQ24780S charging IC. Laptop works only on DC power, after unplug immediately shut down.
    I measure BQ24780S with and withou battery and here are the results :
    without battery / with battery
    1 19.28 19.28
    2 19.25 19,25
    3 18.80 18.75
    4 24.71 24.26
    5 5.98 5.67
    6 2.63 2.62
    7 0 0
    8 0 0
    9 0 0
    10 5.1 0
    11 3.3 3.3
    12 3.3 3.3
    13 0.3 0.32
    14 6 6
    15 0 0
    16 3.4 3.4
    17 0.23 0.23
    18 0.26 0.26
    19 0.23 0.23
    20 0.23 0.2
    21 1.16 1.16
    22 0 0
    23 0 0
    24 6 6
    25 5.9 5.9
    26 0.23 0.23
    27 0.23 0.23
    28 18.97 18.97
    What to focus on next ?
    thanks for response.
  • mon2
    • Dec 2019
    • 14720
    Re: Asus E410M not charging battery
    Measure the voltage to ground of each pin on the battery connector while the battery is connected. Do attach the power adapter as well.
    Post each measurement.
    • roman728
      • Jul 2018
      • 28
      • Slovakia
      Battery connector with adapter plugged in :
      P- 0.0v
      R 3.03v
      C 3.28V
      D 3.28V
      P+ 0.23V
      • mon2
        • Dec 2019
        • 14720
        Is the battery a known good battery? If the battery is locked, it will not charge.
        Remove the battery and check the same pins again on the battery connector. Concerned about pin R voltage. One of these pins is used as a battery detect pin. The smbus pins look ok.
        • roman728
          • Jul 2018
          • 28
          • Slovakia
          I ordered new battery when the 1st laptop with this problem come. It is original asus battery. But i can order another one to try..
          • Sephir0th
            • Oct 2020
            • 1289
            Do you have voltage at Pin 27 & 28 with battery only (charger unplugged)?
            FairRepair on YouTube
            • roman728
              • Jul 2018
              • 28
              • Slovakia
              I dont have any voltage on pins 27 and 28 with battery plugged and charger unplugged.
              Without battery on battery connector i have voltages :
              P- 0V
              R 1,1V
              D 3,25V
              C 3,25V
              P+ 8,6V for a while ten decreased to 0,23V
              • mon2
                • Dec 2019
                • 14720
                Locate a sot23 (3 pin) dual diode near the charger IC. This dual diode will select either the adapter or battery voltage to power the charger IC (VCC pin).
                At this time, this dual diode maybe defective.
                Post pics of the area if not sure. Then remove all power. Meter in diode mode. Measure with red probe on the dual diode side with 2 pins = anode (+).
                Black probe on the side with the single pin, cathode(-).
                The diode should conduct. Repeat with red probe on the other pin. Should conduct.
                Reverse the meter probes. Should block for each test with OL.
                Confirm this. The battery voltage should reach this dual diode and pass the voltage onto pin. #28 when the adapter is removed.
                • Sephir0th
                  • Oct 2020
                  • 1289
                  This was my assumption, but after the battery has no voltage at all anymore, probably not the case ans if so, just a lucky finding. Should charge anyway.
                  Without some experience hard to solve. Likely need to dig into every Single resistor related to charging.
                  • mon2
                    • Dec 2019
                    • 14720
                    I am still suspicious if the battery is being detected by the charger IC. Some schematics hard wire the battery present pin to be always true so not sure if that is the case here. If there is a battery charge, it must reach the VCC pin else diode is blown.
                    • roman728
                      • Jul 2018
                      • 28
                      • Slovakia
                      Thanks guys, i will try to measure diode yesterday and post resulst here.
                      • roman728
                        • Jul 2018
                        • 28
                        • Slovakia
                        New battery came today, it is charging and working. Case closed, thanks for help.
                        • huzo
                          • Sep 2014
                          • 187
                          • CROATIA
                          But why does the batteyry fail? i opened the battery and all three cells have 3.7V,but the battery isn't working...
                          • mon2
                            • Dec 2019
                            • 14720
                            Between the battery connector that mates to the motherboard and these cells is the BMS module (battery module system). It is possible that the BMS module is in a locked state, for safety reasons.
                            • huzo
                              • Sep 2014
                              • 187
                              • CROATIA
                              Yeah,but why did it lock itself? The cells are fine,and i read all over the web that people are having issues with this model...
                              • mon2
                                • Dec 2019
                                • 14720
                                Test the voltage to ground on the battery pack with the power adapter attached. Is the voltage higher than the marked battery pack voltage? It should be slightly higher than the battery pack voltage. If yes, the battery pack should charge unless it is defective.
                                • huzo
                                  • Sep 2014
                                  • 187
                                  • CROATIA
                                  The battery is defective,that is true,and new battery works fine...The old battery gets 8.6V while the charge starts for a few seconds and the 0V, altough the battery is 11.55V nominal value it gets only 8.6V, So the old battery probably locked out because something..I forgot to measure the voltage on the new battery while charging but it wen't from 76% to 100%...So the issue is the old battery,but why,since the three cells inside are at 3.7V,so not like one of them died...Is it planned obsolecence?
                                  • Bowline
                                    by Bowline
                                    06-11-2025, 10:13 AM
                                  • mkdj
                                    ASUS X571 no power : battery issue?
                                    by mkdj
                                    Mark and model: ASUS X571
                                    Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                    Tests already made:
                                    - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                    - I have removed...
                                    07-14-2025, 09:16 AM
                                  • techfreak9356
                                    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                    by techfreak9356
                                    I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                    09-14-2023, 11:10 PM
                                    NVDC charger configuration...
                                    11-05-2024, 03:28 PM
                                  • ferah831208
                                    Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                    by ferah831208
                                    Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                    03-18-2025, 01:18 AM
