Macbook 820-3115 Missing hard Disk
  • Instafixx
    • Jul 2022
    • 374
    • India
    I have a Macbook 820-3115 with the question mark sign.
    Replaced the cable.
    Tried a New SSD.
    Issue Persists.
    Cleaned the and Soldered the Connector of the Hard Disk on the board. It worked once and then again the same.
    Went ahead and replaced the connector. Still the same.
    What can be at fault here.
  • ACS-Repair
    • Feb 2021
    • 204
    Re: Macbook 820-3115 Missing hard Disk
    I had one of these once. Couldn't figure it out until I replaced the cable that runs from logic board to the drive. it's apparently a well know issue.
    it looks like you have done this already but if the cable is not new, it may also be a bad cable.
    • mon2
      • 14677
      Ditto the above comments by @ACS. Do NOT, repeat do NOT sharp crease the flex cable between the SSD / drive and the motherboard. The contacts will break and cause the fault. Found our tech was doing this repeatedly to get a nice bend of the shape of the cable. The client kept bringing back the unit with the same fault. Only after observing his installation procedure - told him to stop. It was like cleaning wrinkles out of a shirt - he kept applying pressure on the cable.
      The last time, he did not do this and the unit worked fine.
      • rookieme
        • Oct 2014
        • 399
        • Greece
        It was always the cable to me at same situations.
        I never bothered to bend the new one at the corners so never had issues after replacing them.
        • Eleways
          Apple Macbook A1707 Hard disk
          by Eleways
          Hi
          I've an Apple macbook A1707 with Hdd defect.
          This product don't work with a normal Hard disk, but the hard disk it's a BGA component on the logic board.
          My question is:
          Can i exchange the hard disk, by desolder the bga Hard disk and replacing this?
          Can i replace with a different one (es 500 gb instead of 250 gb)
          This Macbook has T1 security check.
          Thanks and best regards
          Luca
          02-18-2022, 04:23 AM
        • madura2010
          DAY11AM6E0 hard disk drive and optical disk drive not detected
          by madura2010
          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
          i checked the connectivity of ribbon=good communication with hard and motherboard
          changed hard disk and checked=3f0 error persist
          sata power=+5v available
          Then checked data capacitors=all good
          Then checked data lines path connectivity to pch=all good
          reflashed...
          03-12-2023, 09:09 AM
        • mkdj
          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
          by mkdj
          Dear all,
          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
          Here the steps I have taken to fix the laptop:
          - downloaded latest BIOS from Lenovo Website...
          10-18-2025, 03:43 AM
        • Adogabriel100
          Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
          by Adogabriel100
          Hey! This is a A1278 macbook 2011.
          Problem: Not turning on / No green light
          Im using by3200s charger.
          Voltajes:
          PPBUS_G3H = 12.26v
          SMC_RESET_L = 3.3v
          PP3V42_G3H = 3.42v
          U7000 =
          Pin 1 CHGR_AGATE = 0v
          Pin 2 CHRG_DCIN = 19v
          Pin 3 CHRG_ACIN = 4.6v
          Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
          Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
          Pin 12 PP3V42_G3H = 3.42v
          Pin 13 CHRG_RST_L = 3.3V
          Pin 14 SMC_BC_ACOK = 0.8V
          Pin 19 PP5V1_CHRG_VDD = 5.05V
          Pin 20 PP5V1_CHRG_VDDP = 5.03V...
          04-01-2024, 01:02 PM
        • envym
          by envym
          Hi everyone!
          06-27-2025, 08:54 AM
