A2141 no signal on external screen while recovery
  • myth77
    • Feb 2017
    • 380
    • Croatia
    I dont do Macs, so i really dont know their specific behavior, but i received one (from the title) with smashed screen. It is turning on..but i dont want to buy a new screen to find out it is locked or dead or something. So, i removed lcd connector from motherboard and i am using adapter from usb-c to hdmi to connect laptop to external monitor. It seems that laptop is wiped because it goes to recovery (internet) and at first it seems all ok...i can see apple logo and downloading ios, then when it goes to installation i can see progress bar, and after couple of seconds it goes to "no signal" on external monitor?!
    I dont know is that normal? Do i need original lcd to see progress or? Maybe it is switching from internal gpu to another and one of them is dead? Or maybe i need some special usb-c to hdmi cabel, some original from apple?
    I checked voltages on the board and everything seems ok.
    For any help thx in advance.
  • mon2
    • 14779
    Re: A2141 no signal on external screen while recovery
    Try booting in safe mode.
    Could be a GPU issue:
    https://www.badcaps.net/forum/showthread.php?t=97535
    • myth77
      • Feb 2017
      • 380
      • Croatia
      can i boot into safe mode if ios not installed?
      • survivalbloke
        HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
        by survivalbloke
        SN: 8CG0213H8W
        ProdID 3C311UA
        This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
        05-08-2025, 12:21 PM
      • eurowill
        a2141 820-01700 internal display not working / external works
        by eurowill
        Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
        Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
        07-23-2024, 10:06 AM
      • plyanthony
        Razer Blade 15 no external display with attached screen disconnected from motherboard
        by plyanthony
        Computer in question : Razer Blade 15 2020 Base Model
        Model# RZ09-03286E22
        BIOS CHIP: WINBOND W25Q128BV
        What I'm trying to accomplish:
        I want the computer to properly boot with an external display with the attached display disconnected from the motherboard. I have a CH341A programmer and full capability of modifying the BIOS easily. I Have tried various setting changes to no Avail.
        What I've tried thus far: Too much to note and I really dont remember everything I changed but here it goes.
        W/Stock BIOS - 1.06:
        Disconnect the...
        02-01-2023, 09:35 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
