A2141 Boot Loop Issue
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 676
    Board has no signs of water damage. Board had the APPLE error logo when recieved, reset with DFU and restored and installed new os.
    OS installed but then it would not post and boot loop with a hard fan spin over and over. The apple logo will not appear and the bar will only reach about a quarter of the way and loop again. I tried DFU again with REVIVE and it still continues.
    Attempted Safe Mode and the computer does however boot into safe mode.
    So the computer boots into safe mode but will not post normally. Any suggestions? This is new to me and would love the knowledge for this and a fix.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 676
    Re: A2141 Boot Loop Issue
    Booting into safe mode and the computer boots into safe mode. It allows me to see the error:
    panic(CPU 4 caller) GPU PANIC: mux-regs 5 3 7f
    so forth...
    I looked online and this seems to be a GPU issue these are now being known for? Anyone solve this issue or is this a bad GPU?
    sigpic
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 676
      Bump
      sigpic
      • mon2
        • Dec 2019
        • 14795
        https://discussions.apple.com/thread...22#31602727022
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 676
          Hey mon2,
          That program is for a 15" 2011 MBP. I see nothing in that discussion about the 16" 2019
          sigpic
          • mon2
            • Dec 2019
            • 14795
            Appears to be a GPU fault cover up on this logic board. The keyword search pointed to the same shared link and issue.
            Here is another:
            https://discussions.apple.com/thread/251459049
            Sad engineering.
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 676
              Yup we are back at the AMD GPU nightmare again. 2011 repeats itself again in 2019 MBP. Hopefully there is a program for these models soon. They are saying its a faulty software issue which is odd because a lot of 16" do not have this issue but a batch of them do. I am considering doing more research on this and hopefully it could be something as simple as a bad cap or resistor that needs to be replaced near the GPU. Wont know till I do a little more digging, worst case it is the GPU itself and it needs to be honored under a new program.
              sigpic
              • moderator
                • May 2020
                • 33
                • India
                Facing the exact same problem..an one found the solution yet?
                • rediii
                  h???, spurrrn
                  • Mar 2018
                  • 504
                  • somewhere in europe
                  same here, 4000 $ garbage...
                  • abajor
                    Alienware Area-51 R2 Boot Loop issue.
                    by abajor
                    I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
                    It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
                    To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
                    Right now I'm trying to dig through the PDF schematics and Board...
                    03-08-2024, 10:08 PM
                  • javierwilliam
                    Boot loop issue with LCD TV
                    by javierwilliam
                    I am experiencing boot loop issues with my LCD TV. When the TV briefly displays the logo, such as LG or Philips, and then shuts down only to repeat this cycle, it indicates a boot loop problem. The challenge lies in the inability to install new software under these circumstances.
                    Should I consider replacing the mainboard as a solution, or are there alternative approaches to address this issue?
                    Thanks in advance!​
                    08-29-2024, 04:06 AM
                  • ACS-Repair
                    MacBook Pro A2141 820-01700 Boot loop
                    by ACS-Repair
                    Hello All,
                    I was handed a 2019 MacBook Pro A2141 that is boot looping. There is never a display or backlight but there is a chime about every 8-10 seconds.
                    I plugged in a USB-C meter and it see that it is negotiating 20 volts but there is no current draw at all. Voltage is stable, no resets.
                    It appears that the battery has a charge but possibly is not charging.
                    The following voltages are present:
                    PPBUS_G3H = 12.61V
                    PP3V3_G3H = 3.33V
                    PP3V3_GH3HRTC = 3.33
                    I haven't worked n one of these before so I have limited experience with...
                    02-04-2025, 07:48 PM
                  • blaster_
                    Samsung UE49MU6105K - boot loop, horizontal lines
                    by blaster_
                    Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                    Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                    06-22-2022, 05:19 PM
                  • luis71
                    PANASONIC TX-43HX580E VESTEL 17mb230 Boot Loop issue
                    by luis71
                    Hello,i have panasonic TX-43HX580E,I tried to enable 48 bit color,HDR10+ and ALLM and stuck at boot loop screen.I have modified edid.edid.
                    I have backed up PQ,SPI,and Profile if anyone want
                    Which usb_auto_update_??.txt can i use to dump firmware?
                    I would be grateful if anyone could help me to find the firmware for USB recovery.
                    11-05-2023, 06:31 AM
